Question about Palm Treo 750 Smartphone
Block calls from unidentified callers
Palm Treo 755p How do i block caalls from Blocked Caller ID or Private #?
If you dial *67 and the number it should block the call. You can also call your phone company .. sprint etc and they will gladly permanently block the number for you.
Posted on Jun 12, 2008
WIFE`S CELL PHONE # IS BLOCKED, BUT IS NOT IN BLOCKED #S
Have her dial *82 before she dials the home number. If that works she has the cell phone set to block her number. *82 should unblock it for just that one call.
Aug 25, 2014 | Asavings Panasonic KX-TGEA20S Dect 6.0 1...
How to block calls on home phone that show up as private caller
You would have to subscribe to that feature from your local phone company, then when a number like that calls they will get a recording that states you do not accept blocked calls...
Jun 13, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
How to block a particular number from calling our casio ravine cell?
There is no option on this phone to restrict the caller ID.
If the number is XXXXXX up as 'Restricted' then it can only happen if you dial *67 at the beginning of the number you want to call to block you caller ID information. Or, you can also call Verizon and have caller ID blocked for every number.
If this is happening for every number, then you will need to call Verizon and have them deactivate the caller ID restriction.
May 29, 2014 | ooVoo
How could i block my Cell Phone Number From Caller ID
  1. Just dial *67 before the phone number on your cell phone. This code is the universal command to deactivate caller ID.
    For example, placing a blocked call would look like*67 555 555 5555 (without the spaces). On the receiving end, caller ID will usually display "private number" because it has been blocked.
    Though you won't hear or see a confirmation of a successful caller ID block, it will work.
Dec 12, 2010 | Sony Cell Phones
Texting and emailing are working, but when I place a call on Treo/Sprint 755p, I hear nothing, no ringing, etc. Also, when someone calls me, I hear it ring and nothing is there when I answer. The caller...
try to Restore your unit to original factory setting, 80% chances it may solve the issue.
It still not working your gonna need to replace the earpiece and the mic
Oct 31, 2009 | Palm Treo 755p Smartphone
If you block a number does the caller know?
Yes, if the person has caller-ID. Depending on the phone and phone service, the person you call will see either "Blocked Number" or "Private Call".
Oct 21, 2009 | Lands Phones
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
BLOCKED CALLS
If you subscribe to a caller ID service through your phone provider, you can block
specific fax numbers so the device does not print faxes received from those numbers.
When an incoming fax call is received, the device compares the number to the list of
junk fax numbers to determine if the call should be blocked. If the number matches a
number in the blocked fax numbers list, the fax is not printed.
Set the junk fax mode
By default, Block Junk Fax mode is turned On. If you do not subscribe to a caller ID
service through your phone provider, or do not want to use this feature, you can turn
off this setting.
To set the junk fax mode
▲ Some models have a Block Junk Fax button. Depending on the model you have,
do one of the following:
Block Junk Fax button: Press the Junk Fax Blocker button, select the Block
Junk Fax option, and then select On or Off.
Color display menu: Press Setup, select Basic Fax Menu, select Junk Fax
Blocker Setup, select Block Junk Fax, and then select On or Off.
Add numbers to the junk fax list
There are two ways to add a number to your junk list. You can select numbers from
your caller ID history, or you can enter new numbers. The numbers in your junk list are
blocked if Block Junk Fax mode is set to On.
Feb 11, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
this would be done if you put a request to your service provider.
Dec 16, 2008 | Samsung SGH-G600 Cellular Phone
LG KU990 Caller ID
  • If you answer the call, the number (or number and name) stays on the display until either you or the caller hangs up.
  • If you do not answer the call, most display units keep a record of the calls received, including the phone number (or number and name), date, and time.
  • If the letter P, priv, private, or a similar term appears, the caller may have blocked the display of his or her number.
  • If the letter O, ????, out of area, or a similar message appears, the caller either is in an area that does not support Caller ID or has placed the call using operator assistance.
  • Caller ID comes with Anonymous Call Rejection, which, when active, allows you to reject calls from callers who block their number. Your phone does not ring, and the caller hears a message saying blocked calls will not go through.
    • To turn on Anonymous Call Rejection, press
      *77 on a touch-tone phone (or dial 1177 on a rotary phone)
    • To turn off this service, press
      *87 on a touch-tone phone (or dial 1187 on a rotary phone)
or go through
http://www.decommunications.com/support/topics/repairs/phone/no-id-name.php
Oct 13, 2008 | LG KU990 Viewty
Palm Treo 750 Smartphone Logo
235 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
