Question about HP Officejet J5780 All-In-One Printer
Error contiually flashes
I have a HP J5780 all in one that suddenly keeps flashing with the error
'turn power off then on'
when I do this on the machine, or power point, etc, the error just keeps re-appearing. As we are a business, we do rely on our fax a lot so it would be great if you could help
regards
Shane
  • Anonymous Sep 08, 2008
    Exact same problem. Tried the solutions but to no avail
  • Anonymous Oct 11, 2008
    I have pretty much the same problem.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Once power cycle the all-in-one to remove the static power in the all-in-one.
Perform below steps to power cycle the all-in-one.
  1. Verify that the unit is switched on.
  2. Remove the power cable from the back of the machine.
  3. Wait 20 seconds
  4. Press and hold the POWER button on the front panel
  5. Reinsert the power cable in the backside of the unit. Wait until the HP Officejet powers up.
If the issue still persists then reset the all-in-one by following the below steps.
  1. Use the On button to turn on the product.
  2. Remove the power cord from the product.
  3. Press and hold the # and 6 buttons.
  4. While holding the buttons down, connect the power cord to the product.
  5. Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
  6. Use the On button to turn on the product. The reset information appears on the display.
Posted on Jun 04, 2008
    Master:
  • 638 Answers
May be try to check ur cartidges or replace them with new ones or check out if there is any paper jam.
Where is the CMOS battery located on an HP Officejet J5780?
It does not have a cmos battery. the printer has flash memory so no need for battery
can't help with factory reset or bios flash sorry
Jun 21, 2015 | HP Officejet J5780 All-In-One InkJet...
Error and loud beeping
Hi Cathy, Unfortunately I am not familiar with the J5780 machine. Sorry I could not help. Kind regards Printdesigns
Nov 29, 2011 | HP Officejet J5780 All-In-One Printer
Hello, my 8gb Sandisk light is keep flashing and is not bieng reconized by my laptop.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this helps someone fix that pesky "USB device not recognized" Windows error!
good luck.
Feb 17, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
The power button and exclamation light keeps flashing turn power off and then on?
Rebooting is always the easiest fix,it allows everything to be reset to original settings that work before the error.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=16927&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3301296
This is the self help page for errors.Hope this helps?If not click the "ask HP" button on the page.
Jan 23, 2010 | HP Officejet J5780 All-In-One InkJet...
Hello, My J5780 Has Just Atarted Printing
In printer properties and then in printing preferences, look for and turn off mirror image printing, it's there for printing transfers to shirts and things that you need reversed.
Dec 04, 2009 | HP Officejet J5780 All-In-One InkJet...
HP J5780 printer is printing backwards
You may have the Mirror image turned on.
Open a job to print. Select File>Print. When the Print window opens, select Preferences, then click on the Advanced tab.
Look for the Mirror Image option. If it says ON, click on it and change it to OFF. Then click OK.
Mirror Image is mainly for iron on transfers.
Thanks for using Fixya.
Nov 20, 2009 | HP Officejet J5780 All-In-One InkJet...
Turn on green light flashes
Count the flashes before a pause. A steady on is bad ground or loose igniter. 2 flashes is either low gas pressure, bad flame sensor, gas valve wires loose or bad ignitor. 3 flashes is a bad pressure switch, or blocked vent. 4 flashes is a bad roll-out switch or open contact. 5 flashes is bad wiring to gas valve or flame sensor, 6 flashes is either a bad control board or bad thermostat.
Oct 13, 2009 | Sterling RF75 Natural Gas Heater (75,000...
HP Officejet J5780 scanner communication error
I had this problem too, and after a while just gave up on the uesless HP interface, and went to the simple but efficient Windows Fax and Scan program on the Start>Programs menu.
Jul 09, 2009 | HP Officejet J5780 All-In-One InkJet...
Power and attenion keeps flashing says turn power off then on
Perform a partial reset of the HP All-in-One
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 30, 2009 | HP Officejet J5780 All-In-One InkJet...
HP Officejet J5780 All-In-One Printer Logo
254 people viewed this question
Ben Johnson
