Question about Panasonic Audio Players & Recorders
I have a Panasonic sa-hm42 cd, cassette, record player. the power led turns on and off but nothing else works there is no power to the radio tuner and cannot change between cd, radio etc using the remote from the unit
  • 83 Answers
SOURCE: car cassette player
yes the rubber rollers inside your unit have become hard,,and they are slipping, and the unit detects this,, u can purchase a product called re-grip [ for rubber products and it treats the rubber in such a way to make it soft and pliable again ] the product is sold by mcm electronics and can be found online,,, treat the surfaces of the rubber rollers in your unit and it should preform to original specs....any further help please email me at troublerst@hotmail.com...i hope this helps you
Posted on Jul 12, 2007
  • 298 Answers
SOURCE: Panasonic SA-HE100 Remote
The correct replacement remote from Panasonic can be found in the link below.
Panasonic SA-HE100 Replacement Remote
Posted on Jun 25, 2008
chiquititas
  • 1010 Answers
SOURCE: CD stuck in CD player. Cassette and radio works good. But CD stuck.
This symptom is often a sign the player is nearing its end of useful life. But, sometimes it is merely due to a collection of dust, dirt or a foreign object lodged in the mechanism. Sometimes it is a logic error inside the electronic memories.
So, there are a number of possibilities.
Here is what I would do:
ONE: Do NOT force it or use tools to pull the disc out.
TWO: If you can find the wires that supply the 12 volts to the unit, pull that wire so there is no power to the unit whatsoever for at least 30 seconds. That will reset the electronics inside the player.
THREE: IF you cannot find the wires, or if they are too hard to get to, you can pull the plus cable off the battery; raise the hood and with a wrench loosen the bolt holding the plus cable onto the battery terminal. Pull it off for at least 30 seconds or longer, then put it back on. This will perform a hard reset as in TWO.
FOUR: If still no removal try this technique:
http://www.wikihow.com/Remove-a-Stuck-CD-from-a-Car-CD-Player
If it is not an expensive unit you may find it a superior investment to purchase a new player rather than pay a tech to repair it. (In the worst case the unit must be pulled, cover removed and disc manually removed; then you may find out there are damages or defective circuits awaiting further repairs; probably looking at a charge of $75 or more if you go to a service shop).
Let's hope the ideas above kick it out and it returns to normal useage.
Posted on Jun 26, 2008
SOURCE: jbl radio in toyota sequoia
If I unplug all the wires from the CD player won't the security system lock up my stereo system? Which means that I have to go to a dealer to get the code from them.
Posted on Nov 01, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
Will it record on most cassette types
The difference between cassette types is the length of the tape and the quality of the tape. Your recorder will work on all types of cassettes.
Dec 17, 2015 | Panasonic RX-D55GC-K Boombox - High Power...
I have a eur7711150 remote for a panasonic radio that was my dads.. i cant figure out how to change channels on the radio.. hate to sound so stupid but there doesnt seem to be a tuner or a seek button
The EUR7711150 remote works for several different Panasonic CD stereo systems. To switch between AM and FM, press the Tuner/Band button. (If you were in another mode, you'll need to press the Tuner/Band button once to get to the Tuner mode and then toggle if needed.) Then if you press Play Mode (above Repeat to the left of the number keys), you can toggle between Preset and Manual. In Preset, the rewind and fast forward buttons select between your preset stations. Alternatively, you can set the presets to numerical values and touch the appropriate number button. (Touch the >=10 button first to access Memories 10-15.) If you are on Manual, the rewind and fast forward buttons will let you move up and down between the frequencies. Pressing and holding Rewind or Fast Forward for a moment will let the radio scan to the next frequency in that direction with a signal.
The CD button enables the CD or MP3 disc player mode. AUX and Tape are for external audio devices and cassette tape mode, respectively.
These comments are based on using the remote with the Panasonic SA-PM19. Please add a comment with the specific model of your Panasonic radio if you need additional assistance.
I hope this helps.
May 05, 2013 | Televison & Video
Malfunctioning CD, Cassette, Radio stereo
With all due respect, it is not the sort of fault a novice can fix with any competence. It has power supply and system issues.
Jul 12, 2017 | Panasonic Sa-pm27 Shelf System 5 Cd...
I have a SL-HM42, it has a small flat white plug on it and I'm not sure how to hook it up. Am I missing something?
I'm trying to work out the same thing too. The stereo unit that came with the sl-hm42 stopped working recently and I'm trying to work out a way get the record player going again. By the looks of things I'm going to have to invest in a pre-amp to boost the output of the record player but that will be no good unless I can work out what each of the wires do....
Let me know if you work it out yeah?
Also, just to check, does your flat white plug have 6 wires?
Jan 02, 2011 | Panasonic Technics SL-DZ1200 Turntable
Can i dub from a cassette to a cd on my panasonic sxbs?
No you can not go from the cassette to cd on the unit. You can go from cd to cassette though. The unit is not a cd recorder.
Apr 20, 2010 | Panasonic RXD27 Radio/Cassette/CD Boombox
Record from radio to cd
i don't think this stereo has a cd burner your best bet would be to use online radio (most stations do this now) record straight to your computer and burn cd from there
Jun 12, 2009 | Panasonic RX-ES25 Cassette/CD Boombox
Stereo cassette receiver--hums
There could be an open filter capacitor in the power supply.
Jul 13, 2017 | Kenwood Audio Players & Recorders
AKAI CD-M600 CD PLAYER not working.
Akai CD player playing very S L O W L Y and the CD door won't open and if it does, it goes into ewject mode. Help!!! Has an internal motor died??? Can i be repaired???
Mar 29, 2009 | Audio Players & Recorders
Durabrand 3-Piece CD Boom Box w/ Radio Cassette Recorder,
Does it happen when playing cassette or radio? might have a problem with the speaker wires.
Oct 23, 2007 | Durabrand CD Player with Cassette...
284 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
