Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Blank pages WHEN I PRESS PRINT A BLANK PAGE COME OUT FIRST AND IT PRINT THE PAGE AND THEN ANOTHER BLANK PAGE COME OUT.IT DOES THIS EVERY I PRINT.
  • 2 more comments
  • IzzieBell Jun 13, 2008
    I have exactly the same problem. Whether I print from the computer or copy from the flatbed it makes not difference. I get a blank, a copy, a blank. FRUSTRATING to say the least. I have tried removing all ink cartridges and replacing them; unplugging copier and plugging it back in; wiggling just about everything LOL. Hopefully someone has the solution. Thanks for being here.
  • M99MCD11 Jul 16, 2008
    JUST STARTED HAVING THE SAME PROBLEM, WAS HOPING IT WAS JUST A MATTER OF RECALIBRATING SOMETHING ON THE MACHINE. I DIDN'T HAVE ANY LUCK THE CANON KNOWLEDGE BASE.
  • Anonymous Aug 01, 2008
    I have the same problem. I get a blank page, sometimes more than one, then the printer finally prints my document, and ends with another blank page. This just started last week. This occurs also when I'm copying a document. I've taken out the cartridges and unplugged the unit, but the problem still exists.
  • alexo316 Oct 29, 2008
    I hope the only solution isnt buying a new one!!! anyone know of any better solutions???? it would be quite lovely if they could share them with us.
By a different printer, it is the paper sensor and too expensive to fix
Posted on Jul 08, 2008
Prints blank page
Have you checked the print que
Printer problems can be a real hassle.
From time to time, due to document layout or settings on your computer, in your software of choice, or even on your printer, a blank page may get "printed" with the rest of your document.
Fortunately, this issue is a simple one to troubleshoot.
Click "Print Preview" when you are finished with your document and ready to print.
Observe your document.
If you see an extra, blank page, you have created a second page.
To delete the second page, close Print Preview, go back into the document and eliminate any blank lines in your documents that you may not need.
You may also find an inadvertent page break at the end of your document.
Place your cursor on its symbol and delete it.
Locate the symbol by clicking on the Show Formatting paragraph icon in the toolbar.
Circumvent this "ghost page" if you do not see a second (or additional) blank page in Print Preview.
Specify the number of pages you wish to print, within the Print dialogue box.
This is typically done by selecting the "Print From" option, then entering the page numbers desired.
If your document happens to be ten pages (without, of course, that final blank page), then enter in the "Print From" field the numbers "1-10".
This will print only pages 1 through 10, without an eleventh (blank) page.
Jul 11, 2013 | HP Deskjet 5940 Photo InkJet Printer
Printer working but page is blank after printing
try this select all in the page that you want to print then press ctrl +p it will show you a window in the bottom of that window press print selection it most work
Jun 22, 2012 | Kodak ESP Office 2150 All-in-one Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Canon iR C6800 prints leading and trailing blank pages
There is an option in the print driver to print a separation page (typically just a blank page unless you specify otherwise) so that each person's print jobs can be differentiated easily.
This option probably got enabled somehow on her PC. Have her go into the print driver's properties (right click on the Canon in the list of printers and select Properties) and look for the option that says separation page or separator page and deselect it. Then click Apply or OK, and it should be good.
Jul 06, 2010 | Canon imageRUNNER C6800 Copier
I have an HP C7280 AIO printer. Everytime I print, it always form feeds a blank page bewteen each printed page (print page 1, form feed a blank page, print page 2, form feed a blank page, and so on).
Generally, there are printer set up programs that will let you chose to put a blank sheet or to not do that. If you have a disk or manual, look for the set up utility and go thru the tabs to find paper handling or something similar to that. There should be a check box you can clear to stop the blank page.
I hope that this information was helpful. Have a great day.
Brian
Jan 24, 2010 | HP Photosmart C7280 Printer
Extra blank sheet of paper between printed pages
Check your print settings, it is possible that you enable page seporator in the settings.
Apr 30, 2009 | HP Photosmart D7160 InkJet Printer
How to print a blank page HP 2550 Laserjet
Open notepad, select Page Setup under the file menu and delete the entries in the Header and Footer fields and click OK. Also press enter or space a couple times so that there is something to be sent to the printer - then print!
Dec 30, 2008 | HP Office Equipment & Supplies
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Hp Photosmart 3310
wow..try a test page to see if the printer is happy on it's own.
Aug 19, 2008 | HP Photosmart 3310 Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
236 people viewed this question
old marine
old marine
