Question about Vacuums
Vacuum was used to clean up after plaster sanding.
Could the debris from plaster sanding cause my rainbow series D4c vacuum not to work? If so how is the best way to clean it?
    Problem Solver:
  • 9 Answers
You should never vacuum up drywall dust, sheetrock dust, talcum powder, or fireplace ash with your Rainbow. These are "non-wettables". Some of it can stick inside the motor parts, and some might blow out through the exhaust, back into the air you breathe (cough-cough).
Posted on Aug 19, 2010
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=645474
Generic problem for all Vacuums
Posted by veronica1113 on Jun 04, 2008
Could the debris from plaster sanding cause my rainbow series D4C vacuum not to work? If so how is the best way to clean it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Rainbow D4C will still work but not @ the highest efficiency rating – the suction will be reduced because the sheetrock dust gets into the motor and the fan blade(s) Quan 3 and would need a professional cleaning 1st or 2nd. Replacement of the motor; if it is too serious and or too expensive. It’s a good vacuum back it is suggested that people use a good Shop Vac for the sheetrock dust removal. Feel free to contact your local vacuum cleaner dealer in your area or you can try to repair and change out the fans, clean out the carbon brush area and cleanup the armature. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 10, 2008
Rainbow vauccum D4C model
I think you made mistake of connections when reassembling the unit or place motor in wrong direction. Please open it again, if you opened it before, and check above said hints.
Sep 18, 2008 | Rainbow Vacuums
Will D4c se plug into D4c
The Rainbow D4, D4C and SE all are the same vacuum base, only changes were made to the nozzle. As long as the nozzle cord on your D4 has 2 prongs, not 3 prongs you can use the D4 nozzle that looks like This or the SE PE (SE Performance) Nozzle that looks This
Sep 01, 2014 | Rainbow Vacuums
I smelled something burning one day , but i kept using my d4c, now the motor part does not run but the top plug in will run
I work on Rainbows. D4C-E2 etc. Not sure what you mean by the top plug in. There are two motors in the rainbow, one in the main unit, one in the power head. Where was the odor coming from? email me back with more info, I can help you with this. Jerry
Nov 06, 2010 | Rainbow E series Canister Wet/Dry Vacuum
What's the best way, if any, to clean the carbon deposit on the E Series armature?
Use a scouring pad, or emory cloth. Do not use sand paper, or a wire brush. That will cause too deep of scratches, plus you may get sand in the motor components, or damage sealed coil wires, and ruin your motor.
Let me know if you have any more questions,
Ralph
Aug 03, 2010 | Rainbow 75th Anniversary Canister Vacuum
I want to take apart and clean my D4C Rainbow and my E series 1 speed, I bought both of them on Ebay, and both have odors,( They are suppose to be the vacuum that cleans and purifies the air) that leaves...
Sorry, but a Rainbow D4 has no filtration at all. The E series has a HEPA filter that needs replacing. You can put liquid Lysol in the water on the D4 and that will help
Apr 30, 2010 | Rainbow E series Canister Wet/Dry Vacuum
What's the difference between the rainbow D4C SE and the D4C?
the se has a newer updated version of the power nozzle. the power nozzle is smaller.the d4c is older
than the se. the attachments are pretty much the same and the se is a darker color than the
d4c
Jul 01, 2009 | Rainbow 75th Anniversary Canister Vacuum
Can not get the housing off
Remove the 4 screws on the bottom of the canister, and also carefully remove the water basin gasket. You will reattach the gasket with rubber contact cement when you're finished with your repair/cleaning.
May 05, 2009 | Rainbow Technologies D4 Bagless Vacuum
Rainbow vacuum model D4C leaks water,
you can buy them on line, there sticky on 1 side, you need too clean the area after removing the seal.be sure the areas clean so the seal will stick
Jan 18, 2009 | Rainbow Technologies D4 Bagless Vacuum
Rainbow d4c
If it just quit running, it could be the cord. If you have a meter, you can check it to make sure it isn't broke. Take out the 4 I think, screw from the bottom, the top half should come off, then you get to the switch and the end of the cord. Check the motor brushes also, if they are worn down, they may not be conducting and the motor won't run. It gets involved, so don't know if you want to do this at home.
Feb 24, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
521 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
