Question about Sony Cyber-Shot DSC-T3 Digital Camera
The image view is very light / bright
I can click a picture well but when I see the preview of the same the picture has a whitish background with almost no visibility of the image.
thanks
AK
    Problem Solver:
  • 7 Answers
Change the mode in which u shoot ur pics... u might hav had ur mode set wrong... n don shoot where there is direct light fallin on ur lens....
Posted on Jun 04, 2008
How do install a windows desktop background.
I assume you wish to set a picture as your Desktop Background, I hope you know it's called wallpaper. There are few options, but the simplest way is open the picture, right-click and select "Set as Desktop Background", the settings will be updated within few seconds. You'll be able to see the new desktop background. If you are using Windows xp, right click anywhere on the desktop (empty area), select "Properties", click "Desktop" tab, there you'll see the available options to select your picture. Click "Browse", locate your picture which you wish to set as background image and select it. Now, click "Open", and make sure "stretch" is selected in the "Position" box, and then click "Apply", then "Ok".. You can also do the same from the "Control Panel's" Display settings, double-click the "Display" icon to access the settings.
In the same way, in windows vista and windows 7, right-click (blank area) on the desktop, select "Properties" and make the changes from the "Desktop Background" options.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Apr 11, 2011 | ASUS Eee PC 2G Surf Notebook
Tip
How to change your computers background into something cooler
<li> <p>Click on the Start menu button. Then click on Settings and then on Control Panel.<br /></li> <li> 2 <p>Double-click on the Display icon or text link. This will open a window named Display Properties.<br /></li> <li> 3 <p>Click on Background if that tab is not selected. Click on one of the items that appear in the box labeled Wallpaper.<br /></li> <li> 4 <p>Inspect the preview that appears above the Wallpaper menubox. Use the Display menu to the right to experiment with tiling, stretching or centering the picture that you are previewing.<br /></li> <li> 5 <p>Click on Browse to use an image stored elsewhere on your <a href="http://www.ehow.com/how_5177_change-background-picture.html#">hard drive</a>. Locate the image and click Open.<br /></li> <li> 6 <p>Click OK to change your background, or wallpaper. Click Cancel if you decide to maintain your current settings.<br /></li><br /> <span>Tips & Warnings</span> <ul> <li> For background pictures, you can use scanned or digital photographs, an image downloaded from <a href="http://www.ehow.com/internet/">the Internet</a>, or perhaps some original artwork that you created in a graphics program. Graphics files suitable for use typically end with extensions of .bmp, .gif, .jpg, or .tif.</li> <li> Wallpaper consisting of large image files will consume memory and system resources. Consider using a small image and tiling it if resources are scarce.</li></ul><br />
on Jan 04, 2011 | Computers & Internet
Tip
How to change the desktop background image.
There are two ways in which to set your desired image to your desktop background.
Option 1
1) Fistly locate the picture you want as your desktop background.
2) Then double click the image to take you into Windows Picture and Fax Viewer as the default picture viewer. Once there right click anywhere on the picture and click Set as Desktop Background from the pop up menu.
And there you have it. The image is now your new desktop background.
Option 2
1) Fistly locate the picture you want as your desktop background.slasher_x.gif
Then right click on the image and select Set as Desktop Background
Option 2 is a slightly quicker way of doing it as you don't really need to view the entire image in Windows Picture and Fax Viewer as long as you can see the thumbnail of it or you are in Filmstrip view.
To enable the thumbnail or filmstrip file view
In the picture folder click on the menu view and then click on the option Thumbnails or Filmstrip from the drop down menu. Or you can find the view icon on your tab menu.
NOTE: Just remember that if your image is in a 4:3 aspect ratio, such as 800x600, 1024x768, 1280x1024, it will be distorted and stretched if you are using as a background on a widescreen monitor.
Older 4:3 monitors (square monitors) use sqarish image resolutions such as 800x600, 1024x768 and 1280x1024.
Newer widescreen monitors use widescreen image resolutions such as 1152x864, 1600x900, 1680x1050 and 1920x1080.
on Nov 10, 2010 | Computers & Internet
How do i set a photo as desktop background? cannot find desktop properties...
  1. You can right click on the picture itself and select "set as Desktop background"
  2. Or:
  3. Click on the Start menu button. Then click on Settings and then on Control Panel.
  4. Double-click on the Display icon or text link. This will open a window named Display Properties.
  5. Click on Background if that tab is not selected. Click on one of the items that appear in the box labeled Wallpaper.
  6. Inspect the preview that appears above the Wallpaper menubox. Use the Display menu to the right to experiment with tiling, stretching or centering the picture that you are previewing.
  7. Click on Browse to use an image stored elsewhere on your hard drive. Locate the image and click Open.
  8. Click OK to change your background, or wallpaper. Click Cancel if you decide to maintain your current settings.
Read more: How to Change the Background Picture on the Desktop ' eHow.com http://www.ehow.com/how_5177_change-background-picture.html#ixzz1CRtCnmqv
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 29, 2011 | Samsung N150 (36725723009) Netbook
I want to change my desktop background
5
6
Jan 27, 2011 | Computers & Internet
Tip
How to change background and apply video effect of your web cam and mp3 player
This is a new feature of AV Webcam Morpher 2.0 which can be used in the Pro version only. With this feature, users can 'move' from one place to another, or build the stage to suit any special occasions like Halloween, Christmas, Valentines, etc.
step_header.jpg bullet.gif Step 1 - Choose the new background image from the built-in list bullet.gif Step 2 - Load new background image bullet.gif Step 3 - Add effects to improve the webcam view STEP 1: Choose the new background image from the built-in list
- Open the AV Webcam Morpher and switch to Background Changer module (3).
- Drop down the Default nickfaces list (4) for more background images.
- Selected background can be previewed in the Preview pane (5).
Notes:
- Make sure that the Preview (1) mode is on and at least one nickface (2) is selected.
- The default nickface, "Helen", cannot be used with the Background Changer.
tut07-01.gif TOP STEP 2: Load new background image
- Click on the Load button (1) and the Open dialog box comes up.
- Browse and select your favorite background image (2).
- Then, click Open (3).
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
- Turn the Background Changer on by clicking on the ON/OFF button (1).
TOP
tut07-03-2.gif STEP 3: Add effects to improve the webcam view
- Switch to the Effects module and expand the Video Effects category.
- Expand the Color effects.
TOP
Adjust the contrast of nickface vs. background:
Double click on Contrast (1) in the Effects pane to apply this effect into the webcam video.
Double click on Contrast (2) in the Effects to apply pane to adjust the contrast.
This effect make the video look more real by hiding the rendering effect around the nickface.
TOP
Adjust the brightness of the whole scene of nickface and background:
Double click on Brightness (1) in Effects pane to apply this effect to the webcam video.
Double click on Brightness (2) in the Effects to apply pane to adjust the brightness.
This effect will make the video become darker; the darker it is, the warmer the webcam look.
TOP
tut07-07.gif Result:
TOP
on Sep 23, 2010 | Computers & Internet
How to Add a Background Picture to a Microsoft Word Document 2007
t is easy to add a background picture by using the Watermark feature. First, you will click on “Page Layout”. In that menu bar (or ribbon), click on “Watermark”. A window menu will open. At the bottom of that window menu, click on “Custom Watermark”.
In the new menu that opens, check “Picture Watermark”, then “Select Picture” to find an image file on your computer to use. You have the option to have the picture look faded, as a watermark, or displayed in its full color. Check “Washout” for the faded option, or uncheck, to view the background picture in its full glory.
You will then need to choose the size of your background picture, by selecting one of the options under “Scale”.
To remove the watermark, simply click “Watermark”, and choose the “Remove Watermark” option.
Even if you don’t choose the “Washout” option, the background image will appear faded while you are working on your page. But, if you view the page through “Page Preview”, you can see how the background will look when printed.
To get to the "Page Preview" command, click on the button.jpgOffice Button on the upper left hand corner of the Word 2007 screen. Move your cursor over the "Print" option, and another menu will open to its right. On that menu, click "Print Preview".
Jul 21, 2010 | Microsoft Windows XP Professional With...
I cannot change my wallpaper!!!
Instructions
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Tips & Warnings
For background pictures, you can use scanned or digital photographs, an image downloaded from the Internet, or perhaps some original artwork that you created in a graphics program. Graphics files suitable for use typically end with extensions of .bmp, .gif, .jpg, or .tif.
Please give the positive feedback. Thanks for using Fixya.
Anand Kumar
Apr 12, 2010 | Acer Aspire One PC Notebook
Pictures appear to be darker than original in print outs.
You can make several adjustments to improve your images such as lightening dark areas, changing the exposure, sharpening blurred edges, and changing the brightness and contrast.
  • Exposure adjusts the overall intensity of light in an image.
  • Adaptive Lighting improves only the dark areas in an image without affecting the bright areas.
  • Brightness adjusts the amount of light in colors ranging from light to dark.
  • Contrast adjusts the difference in brightness between light and dark areas of an image.
  • Sharpness helps define edges and the smoothness of texture in an image. Use this tool to make a blurred image appear more focused.
Adjusting the image Follow the steps below to make adjustments:
  1. Click the View tab and select the image you want to edit by either clicking the image, or by clicking the small box at the bottom left corner of the image. Figure 1: Select the image c00603524.gif
  2. Click the Edit tab and then click the Advanced tab.
  3. On the Advanced tools tab, click Adjust Image .
  4. Select an adjustment from the list on the left. Figure 2: Adjusting the brightness c00603525.gif
    • The Exposure adjustment is automatically applied when the Adjust Image tool opens. Eight variations of the image are displayed on the left. The current image is displayed in the center. Each image represents a different level of adjustment. When you move the pointer over any of the images on the left, a large version of the image is displayed. Use Preferences to turn this large image preview on or off and to set the timing for the display.
    • If you want to use a different adjustment tool, select Adaptive Lighting , Brightness , Contrast , or Sharpness from the list.
  5. Select one of the images on the left.
  6. Do one of the following:
    • Click Accept to accept all changes and exit from the Color Toolkit.
    • Click Cancel to discard all changes and exit from the Color Toolkit.
  7. If you have finished modifying the image, do one of the following to save your changes:
    • Click Save to overwrite the original image.
    • Click Save As to save the modified image with a different name.
Aug 25, 2008 | HP Photosmart D7160 InkJet Printer
Sony Cyber-Shot DSC-T3 Digital Camera Logo
43 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
