Question about Onkyo HT-SR800 System
Need help understanding microphone
I am just about to finally plug in my onkyo subwoofer I bought the seven speaker surrond sound hdmi entertainment system with this microphone and I don't quite understand how to use it can you in simple terms explain to me how the easiest way to use it so the reciever can set the right settings for all seven speakers instead of manually? Please help lost and fustrated
As described in the owners manual, set the microphone at the primary listening position at ear level, prop it up somehow, a camera tripod works well, plug the mic into the receiver front port, near and under volume dial, and follow instruction on the receivers screen.
Posted on Nov 02, 2008
I recently connected my satellite reciever to my
Iassume you mean you hear the buzz independently of the audio program - simply connecting the cable causes the buzz?
If tanything in the mix is powered from different AC sources you may have a different ground potential. Sometimes manipulating the orientation of one or more ac plugs will solve hum problems.
Apr 02, 2010 | M&K Sound Mp Series MX-350 MK II THX...
I have a Dell 5.1 surround system that I bought for my computer. It has three cables, yellow, black, green, that connect to make it a single jack for the computer. I would like to hook up this system to...
well you can connect white and red to green connector(Front Speakers) the yellow connector is subwoofer speaker and the Black connector is for Rear Speakers) is not connected. The Tv dont have any Surrond decoder so to have full surrond needs surrond decoder
Jan 08, 2010 | Audio Players & Recorders
Cant wire theatre system right,only get surr. on dvd
Do you have a High Def cable box and Tv? if so you would use and HDMI cable from your cable box to your tv, then run an optical audio or coax audio from your cable box to your surrond system. Depends on which plug you have on both for the audio portion.If you dont have HD tv than you would run cable wire from cable box to tv then run red and white audio from cable box to surround system, to listen to it you would select aux channel.
Hope this Helps.
May 01, 2009 | Audio Players & Recorders
7.1 channel onkyo home theater -- no sound out of subwoofer
You might try different listening modes; Some modes (Direct, DTS, Dolby - though I'm not sure which, offhand) require a seperate LFE track for sound to be output by the subwoofer.
Nov 25, 2008 | Onkyo 630-Watt 7.1 Channel Home Theater...
Cant get sound out of the receiver on the sat input
Have you selected the appropriate input type? (e.g. Optical, HDMI?)
Some receivers (like my Onkyo 606) support HDMI passthrough, but will not decode audio signals from HDMI. Making it a pretty useless port!
Do you get sound when you select FM Tuner on the Pioneer?
Nov 22, 2008 | Velodyne CT-80 Subwoofer
Onkyo 875 suboofer problem
decided to get a technician over.
Apr 22, 2008 | Televison & Video
Is the subwoofer got a power? If not then troubleshoot the input power maybe fuse damage.
if there is power, EXamine the connection from the woofer to the output of the source. check the jacket of the of termination.
Apr 22, 2008 | Onkyo TX-SR605 Receiver
Onkyo 605 HDMI Sound
Change the setup in the Hardware control/HDMI/ HDMI Audio...
Jan 17, 2008 | Onkyo TX-SR605 Receiver
No sound through the speakers...
It may be the PS3
you have to select Optical Out 5.1 etc first.
That PS3 is not user friendly at all.
Colin Graham.
Oct 22, 2007 | Audio Players & Recorders
Onkyo HT-SR800 System Logo
109 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
