Question about Dishwashers
Dishwasher filling with water and flooding when not in use
My dishwasher washes ok, draining properly etc, but when I'm not using it the bottom of the dishwasher is filling with water to the stage it flows out the front- I think it is coming from my kitchen sinks because when I use them it seems to fill the dishwasher more. I have put caustic soda down the sinks and they seem to drain properly so I'm at a loss as to what to try next.
  • mingjauwgo Jul 31, 2008
    diswasher continously filling model am 14-c
    Habit-Forming:
  • 111 Answers
Check to see if your dishwasher is level. If it is unlevel the water could run to the front. Hope this helps.
Posted on Jun 04, 2008
Why doesn't my dishwasher spray?
Wash motor may be faulty or the wash arms are clogged.
But if it simply fills and drains continuously then the flood switch has triggered. There could be water leakage which floods the base. Turn the dishwasher off form mains power. Pull out and tilt to one side to get water out. Then after a wait of few hours to allow things to dry, reconnect and see.
Apr 23, 2014 | Maytag MDB6769AWS Stainless Steel Builtin...
Bosch shu8805 (2002 model)
HI,
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Aug 18, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Hoover D73 Dishwasher water comes comes and goes, no washing
this is a problem with the timer programme at the end this can be replaced but can be tricky to do your self the water should drain freely out of dishwasher if you feel confident enough taking the back off try finding the drain pipe because uselly these get blocked with either the food off the plates and it can get blocked with limescale if it hasnt been used for a while then the mess has buitl up and set hard if you can get the drain pipe off try running some bleach through it but make sure you clean all the bleach off before putting it back on otherwise everything will smell of bleach this is the only sollution it does sound like the drain p[ipe is blocked the dishwasher will cut off if the water raises in the bottom it does this as a safety feature to stop your kitchen from flooding it is more than likely a blocked pipe so check this properly and the drain in the bottom of the dishwasher as the water shouldnt just sit their it should be draining all the time but i would say clean all pipes properly before you do anything else hope this is some help......................
Nov 02, 2007 | Dishwashers
LG drains and fills at same time.
This is caused by the " the flood" circuit at the bottom of the dishwasher that detects some water leak. Once this circuit detects any water on the bottom of the washer, it immediately switches the pump out circuit on. It consists of a polystyrene float coupled to a micro switch. You need to dry the bottom and then check for leaks (hose or hose clamp).
Jul 03, 2013 | LG LDS4821ST Stainless Steel 24 in....
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Dishwasher is working fine however at the completion of the cycle and when it sits idle it seems to be flooding from under the filter area.Flooding is slow however but causes headaches when it breaches...
Your water fill valve is slowly leaking water into your dishwasher. Your need to turn off the house water valve, to your dishwasher, and see if the problem stops. If it does then replace the dishwasher water fill valve. If it doesn't stop, then you have water coming in through your drain lines, which is highly unlikely. You will have to check to make sure your drain line has a high loop in it, or install an air gap. Good luck, Appliance Specialists
Mar 13, 2011 | LG 24 in. LD-12BW5 Free-standing...
I am having issues with my dishwasher where it appears to be working but does not clean. Hot water does enter the unit and drains properly but is not cleaning. Muck is still on the door, the arms are wet....
No you need not wash the dishes but just cleaning of the debris and then putting it in the dishwasher for proper cleaning will help you to prevent the drain from getting blocked.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Mar 04, 2011 | Dishwashers
Dishwasher: BOSCH SHE43 - pump keeps draining
Your dishwasher is stuck in flood mode. Bosch dishwashers are built with flood switches located in the bottom base pan of the dishwasher. The flood switch is connected to a rod that activates a small interlock switch. When water enters the base pan on a Bosch dishwasher, a Styrofoam puck lifts the rod, activating the flood switch.
When the flood switch is activated, the dishwasher will go into a no-fill, only-drain mode. The drain motor may also run with the door open to the unit. This is definitely a sign there is water in the base pan. This can be caused by the drain being clogged. There are two ways to fix:
1. You can uninstall the dishwasher and tip it forward to about a 45 degree angle to drain the water out of the base pan. (This is probably why Ian Bint's solution fixed the problem.) Be sure to put a towel under the dishwasher first so that the water is soaked up in the towel instead of going all over the floor. Once you've drained all the water out of the base pan, reinstall the dishwasher and begin a cycle. If it fills and runs, you are good to go.
2. You can also unplug the unit, then remove the kick panel at the bottom in the front. (It's attached with two screws.) Then get some old washcloths or small towels and reach into the base pan below the dishwasher to soak up the water. The pan is directly behind the plastic base panel rim. Once the pan is empty and dry, your dishwasher will no longer be in "flood mode" and will run properly.
If the base pan keeps refilling with water and the no-fill problem returns, there is definitely another issue, such as a clogged drain. At this point, you need to decide whether to invest in an expert evaluation by a certified Bosch repairman and make the necessary repairs, or buy a new dishwasher.
Jun 28, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Water slowly filling cabinet when dishwasher is off.
either
leaking valve - to check, turn water off and see if it still happens
or
if appliance is plumbed in to a spigot on the sink trap, then when you empty sink, some of the water finds its way into the dishwasher via the drain hose. to cure, take the drain hose as high as possible under the sink in a swan neck
Oct 08, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
DIshwasher doesn't drain or fill
Hello annie8866,
First off.. unplug power and then reapply power to it for a little while to see if a power reset will put it back in the proper sequence.. next, check inside the base for a drain inlet and a filter/screen and clean anything you see out of it.. Then try cycling it without dishes to see if it will run thru a cycle and drain properly.. Its ok to add a cup or two of white vinegar during the wash process to remove byproducts of the wash from the inner components.. Make sure the drain hose is not clogged or kinked up.. Try these things and get back to me if it is still misbehaving..
Sep 29, 2008 | Magic Chef CDB6100 Built-in Dishwasher
Dishwashers Logo
205 people viewed this question
Top Dishwashers Experts
