Question about Pioneer DEH-P2000 CD Player
PIONEER DEH-P2000 DO YOU HAVE A GOOD COLOR PICTURE OF THE PLUG....I NEED TO KNOW WHAT COLOR GOES WHERE SO I CAN MAKE MY OWN PLUG OR AT LEAST RUN A TEST TO SEE IF THIS UNIT IS GOOD
    Problem Solver:
  • 20 Answers
Goto www.installdr.com. They have all wire diagrams.
Posted on Aug 07, 2008
I dont know wich wire to put where on my ignition of my hyundai elantra 1996 car
If you purchased a wiring harness adapter for the vehicle, which you should have, you simply connect all the same colors from it to your Pioneer and insulate any wires with no match, then plug in the connectors.
Dec 14, 2013 | Pioneer DEH-P2000 CD Player
I am trying to find a Pioneer DEH-P2000 Schematic diagrams.
schematic for what.....All name brand radios have a standardized color codes coming off the harness.
Yellow- Constant
Black- Ground
Red- Switch power
Blue- Antenna
Blue/white- Amp turn on
White- Left front +
White/black- Left front -
Gray- Right front +
Gray/white- Right front-
Green- Left rear side
Purple- Right rear side.......the black stripes are your negative speaker outputs.
Feb 24, 2010 | Pioneer DEH-P2000 CD Player
I need wiring color coding 4 pioneer deh 2050mpg? i know red is constant power.
Not to question you about the red being constant power but I have a pioneer deh-1600 car stereo and red is hooked to electric terminal controlled by ignition switch (on/off) and if your unit has a yellow wire that goes to constant power. The only problem with hooking up the red wire to constant would be if you happened to accidentally leave your player on it could drain the battery. Hope this helped a little. Good luck.
Oct 10, 2009 | Pioneer DEH-P2000 CD Player
Wiring my pioneer deh -p2000 to my speekers
Check the back of your receiver, to see the plug with a set of 8 wires that should have the following color standard:
Left front: White
Right Front: Grey
Left Rear: Green
Right Rear: Purple
Note: 1) Colored wires with a line/stripe on it is NEGATIVE, thus connect to negative on speaker. When connected, speaker cone should vibrate OUT, not inwards, otherwise reverse speaker connection;
2) You can check to see if speakers are in the right order by 'panning' balance and fader controls (from left front only to right front only, to right rear only, to left rear only in succession)
3)If there is an amplifier in your setup, the RCA plugs (like home audio plugs, should be connected instead, NEVER both!)
Hope this helps
Mark
Sep 25, 2009 | Pioneer DEH-P2000 CD Player
Can not find a wireing diagram for a pioneer DEh-p2600
Pioneer follows the universal after-market color code, so if your CD player was made in the last ten years or so, the wires should go like this:
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
May 30, 2009 | Pioneer DEH-P2000 CD Player
Pioneer DEH-P2000
It sounds like you have a positive and negitive touching each other or one wire is exposed and is touching metal. Pull it out of the dash and check you splice/connections.
Aug 07, 2008 | Pioneer DEH-P2000 CD Player
Pioneer DEH-P2000
Most of the car stereos are 40 to 50 watts output.so they need a stronger fuse than 3A.This kind of radios use 10A fuse.
Jan 12, 2008 | Pioneer DEH-P2000 CD Player
Pioneer DEH-P2000 CD Player Logo
201 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
