Question about Dell Dimension 4600 PC Desktop
How many hard frives can be installed
Just wondering how many hard drives i can install inside my Dell Dimension 4600 PC. There's currently 1 80 gig drive that was factory installed. Thanks for your help.
    Sergeant:
  • 458 Answers
You can put as many drives as you can fit as long as you have the cables and connection. Usually 4 is the max in a computer, but you can by a SCSI IDE card and add even more. The biggest problem is to make sure that the jumpers are set to slave on one and master on the other. The jumpers are found on the rear of the drives by the power port. The master should be on the end of the cable and the slave should be in the middle. The longest part of the cable will go to the board. Look on your motherboard and you will see an IDE connection and it should have a 1 or a 2 by it; or primary and secondary.
I researched your computer. Here is the list of your specs: I am going to add my notes where you can understand them. I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya. I did more than try; I told you exactly what had to be done.
Manufacturer:Dell, Inc.Part number: D46RL Processor -Type - Intel Pentium 4 2.80 GHz GOOD PROCESSOR FOR AN OLDER SYSTEM - SYSTEM IS OUT DATED BUT STILL OKAY FOR MOST THINGS. SOMETHING TO THINK ABOUT BEFORE PUTTING A LOT OF MONEY INTO IT.
Processor main featuresHyper-Threading Technology -GREAT
Cache Memory - THIS IS PROCESSOR MEMORY -This enables the processor to process things. A Dual or Quad processor is better.
Type-L2 cache-Installed Size-512 KB Mainboard Chipset type - OKAY BUT LIMITS YOU.
Intel 865G - ON MOTHERBOARD USUALLY WITH A HEAT SINK ON IT.
Data bus speed533 MHz - REMEMBER THIS SPEED LIMIT
RAM Installed Size -ONLY 512 MB
-2 GB (max) -NEEDED AND CHEAP RIGHT NOW - IMPROVES SYSTEM AND WILL HELP WHEN MORE DRIVES ARE INSTALLED.
TechnologyDDR SDRAMMemory speed -333 MHz - REMEMBER THIS
Memory specification compliancePC2700RAM form factorDIMM 184-pinRAM featuresTwo DDR channels - THIS MEANS THAT YOU WOULD HAVE TO BUY 2 ONE GIG STICKS TO UPGRADE. Memory prices for a new computer might be cheaper. Something else to think about.
Storage Controller Type1 x Serial ATA - IntegratedController interface typeSerial ATA-150 -Remember this speed when you buy a hard drive. It is also only an ATA. They now have SATA drives and they get a lot bigger and are faster.
Storage controller interface channel qty2nd belowI could be wrong. Without seeing this board it looks like it might have 4 IDE channels total. Their wording is strange. This is not common on Dell motherboards. Of course Dell did not make the motherboard. They used one from a motherboard company and had the company possibly put their name on it. Could be INTEL, ASUS, GIGABYTE or some other company. This is why it is better to build your own system. You get what you want.
Storage Controller (2nd) Type1 x IDE - Integrated(2nd) storage controller interface typeATA-100 - **Speed change.**
:Controller Interface Type:Channel Qty2 Storage Hard Drive 1 x 80 GB - Standard - DMA/ATA-100 (Ultra) - 7200 rpmHard Drive (2nd) -You could add one here.
Optical Storage - this is on an IDE and will limit you.
TypeDVD-ROM - IDECD / DVD read speed48x (CD) / 16x (DVD) Optical Storage (2nd) Type16x DVD-ROM Drive +2nd optical storage read speed- 48x Storage Removable - This could be an EXTERNAL DRIVE.
Graphics Controller Type- Integrated-Graphics Processor / Vendor This takes away from your installed memory.
Expansion / Connectivity Expansion Bays Total (Free)2 ( 0 ) x Front accessible - 5.25" x 1/2H, 1 ( 1 ) x Front accessible - 3.5" x 1/3H, 2 ( 1 ) x Internal - 3.5" x 1/3HExpansion Slots Total (Free) ( 2 ) x PCI Could add 2 IDE SCSI Cards here.
Interfaces8 x Hi-Speed USB - Could add up to 8 External drives. CD/RW or Hard drives.
Power provided -250 Watt - This could not handle a lot of hard drives. Not enough power. System will not have enough power to run properly. Honestly I would not put a lot of money into this. You will be better off going with an External hard drive. The External hard drive can have its own power source and it will not need the power supply in the computer. So my suggestion would be to upgrade the memory and get an External drive.
Posted on Jun 04, 2008
Moving HDD from Dell Dimension 4300 to 4600 but b4 loading WinXP keeps going back to WinXp choice screen
haveu formmated your disk & installed an operating system ie Win7/Xp it seems u have not got an operating system.
Apr 25, 2012 | Dell Dimension 4600 PC Desktop
I want to install a aSATA HARD DRIVE IN MY 4600, IT SHOWS IT HAS ATA CAPABILITY BUT WHERE DO i PLUG IN THE DRIVE
As I recall the 4600 uses EIDE hard drives so you won't have SATA plugs. You may be able to get an adapter but it would be easier to install another PATA drive that will fit natively.
Feb 08, 2010 | Dell Dimension 4600 PC Desktop
RAM for Dell Dimension 4600
Heres a link from DELL,it has all the correct parts and manuals for you,
This section is titled Removing and Installing Parts by DELL.
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/parts.htm
Your memory is DDR Ram.
Aug 16, 2009 | Dell 1.44 MB Internal Floppy Drive for...
Slave drive into Dell Dimension 5100
Yes it does. It may not have an IDE cable if using SATA hard drive, but it does have a port on the motherboard to plug in the cable you take from your 4600.
Don't forget to rate your answers please!
Jun 07, 2008 | Dell Dimension 4600 PC Desktop
4600 Dimension Dell currently have 512 ram want to upgrade 1 gig
That computer takes PC3200 RAM. it can be ordered here: http://www.cdw.com/shop/products/default.aspx?EDC=638463
PC3200 memory can also be found at amazon.com Be sure not to buy laptop memory.
May 15, 2008 | Dell Dimension 4600 PC Desktop
New Hard Drive over 128 GB on Dell 4600 - but only recognizes 128 GB!
Check that your motherboard supports the high capacity of HDD
Install the OS having the latest service pack combination.
Let me know if your problem is solved and rate me as FIXYA!
May 10, 2008 | Dell Dimension 4600 PC Desktop
Dell 4600 motherboard
That particular Dell uses a power supply with non-standard wiring. The plug is the same size as an ATX plug, but it's wired differently. If you were to replace motherboard & plug in the standard power supply, it would damage the supply, or the motherboard, or both. Also, the front panel plugs (for power & power LED & hard drive indicator) are proprietary as well. Ideally you should replace it with another Dell Dimension 4600 motherboard. I've found replacements for reasonable prices on some of the auction places on the web. I recently replaced a failed motherboard in my Dimension 8300 with one I got from a popular auction site, I think my cost was about $59 plus shipping.
The other option would be to remove the hard drive, video card (if any), and optical drives, and consider a 'barebones' package from various sites such as geeks or newegg.
Jan 05, 2008 | Dell Dimension 4600 PC Desktop
Internal hd ata
If I am right on this one the 4600 can only take a 250gig hd But I was wondering if you could partion the HD to 236.7 gigs twice so the computer only recognizes the 236.7 gig hd you will see two drives in my computer once you do just format both partitions unless you have another hd and then you will see three drives just do the ones you installed or you may loose your operating system, I don't even know if that will work, but I think it is worth a try seems you already have the 500gig drive, can't hurt to try, I sure hope this help some what.,
Dec 22, 2007 | Dell Dimension 4600 PC Desktop
Hard Drive
Put the CD in your CD Drive and shut off the pc. Then start it up again making sure the CD is still in the drive. You will then be asked if you want to boot from CD. Press any key to confirm this (it might skip asking you if it detects that your hard-drive is already blank) Then you want to let it run its install routine. Im not sure what options it will give you but the ones you are looking for is FULL install.
Aug 31, 2007 | Dell Dimension 4600 PC Desktop
Ethernet drive
Did you reinstall windows or was this a second hard drive that you installed?
Aug 19, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
258 people viewed this question
Alun Cox
