Question about Cell Phones
Please Solve My Problem
When I Connect My Headset on my mobile it didn't detect that headset, what to do?
  • withpari Jun 04, 2008
    I have done that, but still not detecting my headset...
  • withpari Jun 05, 2008
    Hello, is there somebody who can fix my problem?????
Try to check the connection of your headset terminal if there was any dirt or curution that causes a loss connection on your headset
Posted on Jun 04, 2008
Could not connect my Nokia Bh 503 Headset to my windows 8 laptop?
It shows Nokia BH-503 Headset installed in View devices in win8 But it doesn't connect. I tried manually connecting in phones it works by pairing. But doesn't get connected in win8. Can anyone help me solve this?
Dec 17, 2012 | Nokia BH-503 Bluetooth Headset
It cannot connect with mobile phone, I tried to use HTC and IPHONE to connect, all of these cannot search the signal from bluetooth? why? I also tried to turn on and off mobile phone and bluetooth for many...
Here is something to try on your iPhone. Hopefully it should fix your problem.
On the iphone, delete all the headsets you may have used from the UI of the iphone.
Turn off the headset.
Warm reset the iphone, press and hold the home and power keys on the iphone for 10s, the screen will go blank and the phone will reset.
While the iphone is rebooting, turn on the headset again and put it into pairing mode with the LED flashing red/white, red/white ...
Now when the iphone is ready, make it search for the headset.
When you see the "9xxPlantronics - Not Paired" entry on the iphone UI, then tap the screen where this message is displayed and the iphone will pair to the headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 22, 2011 | Plantronics Discovery 975 (8164001 P)...
This device Hiadesatoepe 00 does not recognize any phone device .. what is the solution
Hi ahgay1974,
Try 0000 / 1234 / 4321, this works normally the 00 is incomplete the code should be 4 digits,
also make sure that the mobile device you are trying to connect your headset is set to discoverable for the headset to detect the mobile device for proper connection.
This also applies to any other device such as Laptops, Computer so on.....
I hope this helps.
mvincentc
Jul 04, 2011 | Samsung WEP200 Headset
I cant use my jabra BT2070 what is the password for pairing update????
Hi leovy_naguit,
I see that you need information regarding your Jabra Bluetooth Headset.
*Once the Light on the Headset is constantly lit it means that it is ready for pairing.
*On you Mobile phone go to Bluetooth it should be detected as soon as you set your mobile phone's BT to be discoverable.
*Select Connect/Accept/OK or which ever options you Mobile Phone will provide when pairing with your headset.
*The pairing code will be " 0000 "
This should help you pair up your headset with any Mobile phone or device that uses Bluetooth.
I hope that this will be of help.
Have a nice day,
mvincentc
Apr 30, 2011 | Jabra Bluetooth Headset - BT2070
Trying to connect Plantronic 220 headset to Pantech phone. Can't find the right option on the phone to engage the bluetooth device. I think the headset needs to be flashing red/blue to pick up device and...
1.First switch on the bluetooth in mobile phone.Keep the headset switched off.
2.Now press the call button for 2 seconds if you are paring this headset for first time,If this head set is aired already with another mobile press for 8 seconds until the headset status indicator begins to flash blue then red
3.Now search the bluetooth by your mobile device.It detects and you can pair it
Thank You
Nov 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
BH105 is switched on, green light is blinking, but Nokia 5310 phone is not able to detected it.
U must RESET the Headset.
Switch OFF the Headset.
HOLD the answer/end key + power key (for about 5 second).
Red + Green indicators lights start to alternate.
Then Ur Headset is RESET.
Connect / Pair it with your Mobile as normal.
Nov 02, 2010 | Nokia Bluetooth Headset BH105
How to use bluetooth headset in samsung corby???? plz plz help me
1. Just activate the bluetooth in your mobile.
2. Put your bluetooth headset in discovery mode (for this you may need to press the ON button in your headset for more no. of secs around 15 secs) . Please read the user manual of your bluetooth headset to know about how to put it in discovery mode.
3. After that, search for bluetooth devices in your samsung mobile.
4. your headset should be detected in your mobile. If not, still your bluetooth headset is not in discoverable mode. you have to turn it on and try again.
5. If listed in your mobile, select it and it may ask for Passcoe. Provide 0000 as passcode. Thats all now the bluetooth headset is connected to your mobile. If passcode is not accepted, then please do refer the device manual to know about that.
I hope this is useful to you.
Thanks
May 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
The headset icon always appear in my nokia n70 and cannot remove and when i connect my headset ... it doesn't work . with or without headset the headset icon always appear in my screen . During incoming...
Feb 25, 2009 | Nokia N70 Cellular Phone
Cant connect my bluetooth headset to my phone
First switch on ur mobile bluetooth and search for device...And if it detect the headset then try to connect..
Nov 29, 2008 | Cell Phones
Unable to Detect the Jabra BT125 headset from any Bluetooth Device
If you hold down the button, it will turn the light blue, keep holding it till you can connect it. It will come up as Jabra BT125, hit connect. Then it will ask for a password. The password is 0000. Then it will connect :)
Feb 21, 2008 | Jabra BT125 Headset
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
