Question about Brother MFC-5440CN All-In-One InkJet Printer
Star up The PC fax receive won't start at startup. The error message shows that USB port is at use PR002. When I close error message and start the fax receive manually it works.
SOURCE: brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Posted on Apr 28, 2010
What the solution of laptop hp compaq nc6000 when turn on won't start up
Hit escape as you turn on the pc. Continue hitting the button until the startup screen shows. Also Try Hitting Contol alt delete all at once and hold down until startup screen shows. Be sure you have absolutley no usb ports being used during startup
Nov 13, 2012 | HP Compaq nc6000 Notebook
Error message 0xc18a0206
Hello and Welcome!
The error
Oxc18a0206 is mostly occurred in HP printers
To solve the error code
Oxc18a0206,Follow the given steps
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove.
Sir, If you find my solution helpful for you the your Rating as FIVE STARS will be esteemed.
For further help, you can take my valuable,professional help by taking my Service
Thank you for using FixYa!
Dec 14, 2011 | HP Photosmart C7250 All-In-One Thermal...
Showing error 0xc19a0020 Ink systme has failed. Unable to copy, recieve faxes, or print
The product displays a '0x ... ' error message. The exact text of the error varies by product, but it is usually preceded by the word 'Error .
Solution one: Reset the product
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ).
    1. Remove the cartridges from the product.
    2. Wait for the 'Insert Cartridges ' message to display on the control panel.
    3. Disconnect the power cord from the back of the product.
    4. Wait 60 seconds.
    5. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
    6. Reinsert the cartridges, and then close any open doors on the product.
    7. If you receive a prompt to print a calibration page, do so.
    8. Reconnect the USB cable to the rear of the product, and then try printing again.
Mar 06, 2011 | HP Photosmart C6180 All-In-One InkJet...
EX100 WIRELESS NOT WORKING ,TRIED DIFFERENT USB PORTS ,RECEIVER WORKING,PC SAYS FOUND NEW HARDWARE AND FATAL ERROR HAS OCCURRED.TRIED RESETTING, ITS BRAND NEW IS THERE A CONFLICT BETWEEN THE EX110 I AM...
The problem might be with your new keyboard and mouse. Because you have tried with all the usb ports. So try your keyboard with some of ur friends PC and then you can decide on the prob whether its with ur PC or with ur newly purchased Product
Aug 01, 2010 | Logitech Wireless Access Duo Optical...
I can not get the printer to stop printing ...what do i do?
Hi please turn off the printer and restart it after five minutes if you still have the problem please uninstall and reinstall the drivers for your printer.
Jun 13, 2010 | HP Office Equipment & Supplies
Brother mfc- 665cw, receiving faxes
5. Press OK.
Jul 03, 2009 | Brother MFC-7820N Printer
I have an error code of 0x886a6916 and the copy, fax, scan, and photo lights are flashing.
This is info for the HP C6180, It may help
The product displays an ' 0x ... ' error message. The exact text of these error message varies by product, but it is usually preceded by the word ' Error '. Following are some examples of what the error message might look like on your product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 1: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the ' Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Apr 29, 2009 | HP Photosmart 2710 All-In-One InkJet...
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
Power Surge error message
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at thumuvikram@rediffmail.com for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
MY Epson Stylus C60 wont print
This means that your printer is trying to print from the wrong serial port connection, as your printer should be connected via a USB cable. Go to start>control panel>printers and faxes. Double click the printer and faxes icon and your Epson printer icon should be there and set as default with a tick next to it; right click on the icon>properties and then at the top of the next window, click on the tab that says ports and a list of ports will be there and the one that should be ticked should be USB001, and not LPT1 as it will be show, press ok and close windows and restart the pc.
Jun 29, 2007 | Epson Stylus C60 InkJet Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
414 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
