About linux hai can you help me how to configure network in linux
  • npc89 Nov 04, 2008
    I am using Ubuntu, the best I can seem to get is access to the DWL-810 from Linux, but the computer cannot seem to access the network beyond that (cannot access my home router, or the Internet).
  • 70 Answers
if you are using ubuntu, you can open a teminal and try system-config-network
or vi /etc/sysconfig/network-scripts/ifcg-eth0
then insert the ip and the gateway.
Posted on Mar 18, 2009
  • 39 Answers
Might be that you have have to set up WEP or WPA encryption
on your machine to match that on your router and/or network.
If so, I can't give a short answer on how to do this, but you can google ...
Posted on Mar 04, 2009
  • 329 Answers
What type of linux are you using? is it kubuntu, edubuntu, or ubuntu?
Posted on Jun 04, 2008
Lost internet connection linux mint 14
Installing your wireless driver on a Linux distribution is only half the battle.
Once it's installed, you have to configure it.
This means adding the network name, or SSID (service set identifier), and the passkey for your wireless network.
In older versions of Linux, this had to be done with the "iwconfig" command line tools.
Luckily, Linux Mint has incorporated a graphical utility for configuring your Ethernet and wireless adapters.
Open the "Control Center," which will be found under the main program menu on the bottom right of your computer screen.
Click the "Network Connections" icon under the "Internet and Network" section.
Click the "Wireless" tab in the "Network Connections" window.
Click the "Add" button.
Type the name for your wireless network in the "SSID" text box.
Choose one of the options under the "Mode" drop-down list. Most users will choose the "Infrastructure" option.
Click the "Security" tab.
Choose your network's security protocol from the "Security" drop-down list.
Type the key for your wireless network in the "Key" text box.
Click "Apply" to save the changes.
Click the network connection icon in the task bar. It will look like two computers and can be found next to the clock.
Click on the name of your wireless connection to connect to the network. - The_network_manager.
Activate a Wi-Fi Card for Linux Mint
Log into Mint as user root. Launch a command shell, either by logging in in text mode or by launching a Terminal window from the graphical desktop.
Type the following command into the shell:
Press "Enter." Make a note of the name chosen by Linux Mint for your Wi-Fi card it will be the only word displayed flush with the left edge of the screen.
iwlist wlan0 scan
Replace "wlan0" with the name of the Wi-Fi card you noted earlier.
Press "Enter."
Mint will display a list of the wireless networks in range that you can potentially join.
iwconfig wlan0 essid library-wireless
Replace "library-wireless" with the name of the network you want to join, from the list generated by the "iwlist" command. Linux Mint will join the network.
At this point you can browse the Web and access the Internet in other ways via the Wi-Fi card on your computer.
Getting Started with Linux Mint
Aug 07, 2013 | Computers & Internet
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System:
VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
on Jan 12, 2011 | Network Computing Devices (NSH800S/A)...
Linux ubuntu9.10 network confiuration
The main network configuration file is /etc/network/interfaces
afeter you edit the network configuration file you should write
sudo /etc/init.d/networking restart
Wait some minutes to the network service to restart and it should be working as per your configuration.
Jul 10, 2010 | ValuSoft Ubuntu Linux for PC, Mac, Linux
Looking for linux driver
Nothing on the market for Linux at the moment.
You have to configure it yourself if it is configurable at all
Feb 09, 2010 | EnGenius 300MBPS WIRELESS N USB ADAPTER....
Network card not detecting in RHEL4 & 5
The solution proposed by user 'Solutions58' seems to be about windows box since he is talking about 'Device Manager'
RHEL4 or 5 detect compatible NIC cards during boot up process automatically. Sometimes NIC may be detected but may not work properly due to lack of proper driver (a.k.a Module - in Linux culture).
Do this -
1. First find out from HP's web site if NIC for your model has Linux support. You can also use Google to find appropriate driver for your NIC. If yes then you need to follow instructions that are provided in the INSATLL file that comes bundled with the driver.
2. Otherwise buy a $10 NIC card which has Linux support. Disable your onboard NIC through your computer's BIOS and boot it. Linux should detect your NIC right away.
3. Following command can help you in your quest
As root
# dmesg | grep eth (Will show your detected NIC)
# service network status (Will also show configured & active devices)
# ifconfig -a (Will also show your network devices and related info)
# system-config-network (will let you configure your NIC via GUI)
(This would be your best choice)
# system-config-newtowk-tui (Will give you a text base interface to configure your NIC)
Aug 05, 2009 | HP Computers & Internet
Driver for d-link dwl 520 wireless PCI card for LINUX OS
please go to the following web site and download the Driver and Instructions--
Nov 14, 2008 | D-Link Air DWL 520 802.11b (DWL-520)...
Hai sir
Try this: may help you
Note: Note: Red Hat versions 5.1 and earlier used the BIND 4.x package, which used a slightly different format for its configuration file. BIND 8.x offers more functionality over that offered by BIND 4.x, and as 4.x is no longer being developed, you should probably consider upgrading your BIND package to the latest version. Simply install the BIND RPM package (see Section 10.1 for details on using the RPM utility), then convert your configuration file to the new format.
Jan 28, 2008 | Computers & Internet
Linux cannot detect my dfe-690txd
please reinstall your card
on the web of linux
Jan 10, 2008 | D-Link DFE-690TXD Network Adapter
Can't connect to internet by using LINKSYS Wireless-G card
I am assuming you have a dual boot machine meaning it runs either linux or windows and not both at the same time. Linux on the other hand may not configure the card automatically and as you should consider changes to the laptop in terms of configuration and devices are actually changes to two computers the windows computer and the linux computer. You probably did some configuration for windows to enable the wireless card (if there was no encryption windows may have done it for you). Linux on the other hand may not recognose and configure the card automatically and as you should consider changes to the laptop in terms of configuration and devices are actually changes to two computers the windows computer and the linux computer. The many flavors of linux also have almost as many means to configure devices. In order to assist you I will need to know which distribution and version of linux you are using. I will also need to know the manufacturer and model (possibly number and not description) of the wireless adapter to be configured. Warning this may be easy and in other cases it may not be and I have access to few linux distributions to experiment with.
Dec 09, 2007 | Linksys WPC54G Wireless-G Notebook Adapter...
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
