Question about Whirlpool Kitchen Ranges
We have whirlpool stove an electric one and there is a beeping sound coming from the control panel. The only way to get it to stop is to unplug the appliance.
  • 868 Answers
Model /serial number???
Posted on Jun 04, 2008
Electronic control panel went blank and oven is beeping
The first thing I would do, because it is an "electronic" control panel is to unplug your stove, wait about 30 seconds, then plug it back in. Your Control panel may just need a reset and reboot.
If it is difficult to get to your plug-in, then go to your household breaker-panel box, and flip the switch for your stove to the off position for at least 30 seconds, then switch back to on. ...That's the same as uplugging and plugging back in at the wall.
Hope this helped hun ;-)
Oct 03, 2015 | Ovens
Why does my Frigidaire (Gallery Series) stove always beep all by itself ? It starts whenever it feels like it and hardly stops !
Hi Roger Uson, thanks for the inquiry!
It sounds like it could be an issue within your control panel or sensor of your Frigidaire range and that is why it beeps. I would recommend having a professional come out to properly diagnose your appliance. I hope this is helpful. -Matt
Sep 23, 2014 | Kitchen Ranges
Admiral stove is electric oven came on byitself also start beeping i unplug the elements but still the peeping
You have a short in the wiring. I would not reccomend using the unit til it is sorted out.
Feb 27, 2014 | Kitchen Ranges
I have a whirlpool electric glass top stove (model # rf364pxpq ). our electricity went out for only a moment, and when it came back on, the control panel is blank and the oven doesnt turn on. the stove top...
I just encountered the same problem. Power surge during storm caused the control panel to go blank. I removed the panel to get the part number. Reinstalled control panel and it started working. Below are the steps 1) Turn off breaker 2) Unplug unit 3) Remove rear panel 4) Unplug all connections to control panel 5) Wait 5-minutes 6) Reconnect all wires in reverse order 7) Install rear panel 8) Plug in unit 9) Switch breaker to on position Control panel came on, set clock and all oven functions worked.
Jan 02, 2011 | Whirlpool Kitchen Ranges
KitchenAid KEDT105V Electric Stove - f-5 beep Started beeping out of the blue, pushed cancel and it stops for 20 seconds then continuous beeping. If the oven is on the beeping will stop. Hope you can help,...
Hi, F5 means your control board may have suffered a fatal error. Unplug the unit for 30 seconds, when the power is re-applied if the error comes back you will need to replace the control board (ERC). Mike
F5 Board failure Replace control board (also called ERC or clock).
Mar 25, 2010 | KitchenAid KESC307 Electric Kitchen Range
Beeping won't stop and the F7 error code appears on the monitor
You may have got water into the control panel or cooktop causing an electrical short. Hopefully if you give a few days to dry out and plug it back in the code will be gone.
Sep 10, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
May 11, 2009 | Whirlpool RF315 Dual Fuel (Electric and...
Whirlpool gold accubake system in loc mode cant get it off the ..
daddysgirl,  You do not indicate the model number or the age of the stove.  Early model self clean stoves used a 'oven lock door handle.'  Later model stoves do not use such a handle but is electronic. I believe this is the one that you own.  You also don't indicate it the door is indeed "LOCKED" or does the console just says that it is locked. If you press START... does the oven actually come on and heat to desired temperature?  If not... I believe that you have a touchpad control problem.  You can unplug your stove from the wall or turn off the stove's 220VAC 50 amp circuit breaker located in your main electrical panel. If possible leave off over nite and then reapply power the next morning.  If you still have the same oven contol problems, then you will have to replace your oven Electronic Control Module (ECM).  It sounds like the "touchpad" portion is defected but unfortunately it usually comes as a part of the ECM.  The oven ECM is very expensive ($150-275. retail) plus labor to install.  Hopes this helps you!  HandyHenry
Jan 31, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Error message FSEO appear on display of whirlpool stove
Door and switches
do not agree
1. Unplug range or disconnect power.
2. Check wires and connectors from control to door switch, then from door switch to control.
3. If no damage to wires or connectors, replace door switch.
4. Replace all parts and panels before operating.
5. Plug in range or reconnect power.
6. Press Cancel/OFF key. Program and start the CLEAN mode, and observe for 1 minute to ensure that
operation is normal.
7. Go to step 1 and complete checks.
Jan 11, 2009 | Whirlpool RF364 Electric Kitchen Range
F9 error message after power outage
The F9 is a door lock latch circuit problem, either the motor latch or the control/power supply board will need to be replaced.
Mar 22, 2008 | Jenn-Air JES8750 Electric Kitchen Range
Kitchen Ranges Logo
85 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
