Question about Car Audio & Video
Sony car amp
The overcurrent light has come on no sound is it an internal short? what is overcurrent
Trash it
Posted on Jul 13, 2008
  • 1,550 Answers
Everytime the overcurrent light is on,the audio amplifiers IC's are in bad conditions
Posted on Jun 05, 2008
My phoenix gold x200.4 amp turns on but the protect light keep on flashing
  • What does it mean when the LEDs flash on my amplifier?
    With most recently produced Phoenix Gold amplifiers, a flashing/blinking LED is an indication that the unit is in protect mode, usually due to an overcurrent condition caused by an internal short, external short (speakers), or low impedance. Overheating will also cause the amplifier to shut down temporarily.
    If amplifier remains in protect mode, power down the amplifier, disconnect the speakers, and power up again. If LEDs continue to flash, there is probably an internal problem with the amplifier that will require service attention to fix.
  • Sep 23, 2010 | Phoenix Gold ZX600ti Car Audio Amplifier
    Overcurrent lights comes on whenever my amp is on
    this can only mean 2 things, either your over working the amp, which means your amp is trying to push power that it don't have, and it's getting hot which is known as thermal mode. and the other reason can be that make sure amp rms. matches the rms. of your subs.
    Mar 13, 2010 | Sony XM-2150GSX Car Audio Amplifier
    Its on over current
    when the overcurrent light lights up, this means the amp is being run too hard or too loud. try cutting the gain back a little. i always hated putting in the sony amps that had those lights on it. it seems that when you turn it up and get it sounding good the light comes on.... if the overcurrent light is on all the time and it doesnt make sund....the amp could be bad. good luck.
    Dec 17, 2009 | Sony XM-754SX Car Audio Amplifier
    Amplifier keeps running overcurrent
    sounds to me like you are overheating the amp, try down tuning the peak level of the amp, and also if there is anything around the amp clear it away, check if the fan is turning on, you may need to replace it,
    May 20, 2009 | Sony XM-2150GSX Car Audio Amplifier
    Sony Xplod Amp
    well you might want to try using 30 amp atc fuses instead of 10 amp fuses on your amp, because you are getting an overcurrent from your alternator then from your battery. I have the same amp and you will find that your subbs will hit better too. also check on your ground wire from your amp as this also will cause the RED light to come on. :)
    Mar 24, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
    Overcurrent protector
    The woofer or the wiring may be shorted. Remove the speaker wires from the terminals of the amp and power up the amp. If it powers up, check the wiring and the speaker. If it still goes into protect, the amp may be defective. A short in the wiring or speaker can damage a brand new amp.
    Dec 17, 2007 | Sony XM-1600GSD Car Audio Amplifier
    My amp
    It sounds like the amplifier has shorted output transistors. The clip indicator may be on because the output is equal to the rail voltage. The amp is probably going into overcurrent protection when the drive circuit engages. The amp will have to be repaired. If I'm not mistaken, this amp uses the dlogixs modules. Since the modules are not readily available, you may have to send it to an authorized service center or back to LA sound.
    Nov 15, 2007 | L.A. Sound T475 Car Audio Amplifier
    Amp overcurrent problem
    Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (overcurrent), the amp likely has blown output transistors.
    Sep 20, 2006 | Sony XM-2150GSX Car Audio Amplifier
    Car Audio & Video Logo
    419 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
