Question about Vizio L32 32 in. LCD HDTV
My Vizio LCD HDTV 32in. doesn't seem to "center" the picture on sports programs so when they have a score box in the upper left corner most of it is cut off and can't be seen. Doesn't matter how I adjust the screen, bigger or smaller, the picture doesn't seem to be centered to allow viewing of the whole thing. Is this the TV or the channel? Always happens on sport games (baseball, football, basketball).
  • Anonymous Mar 23, 2014
    can't see the scores on the top left corner on fox channel
  • Vizio Master
  • 777 Answers
This is a common complaint. To be frank I don't have the exact term for your Vizio, but most recent LCD and plasma TVs have the ability to "zoom" or adjust "picture format" (those are two commonly used terms) depending on the signal source and format.
it has to do with the fact that currently there are both classic style format 4:3 signal sources as well as new HD 16:9 signal sources and on top of that it may happen that a 4:3 signal source is distributing adjusted image from a 16:9 or other signal source. Think cinema adjusted to run on classic TV - remember the vertical strip of image with two huge black areas below and above it?
Well the ZOOM or PICTURE FORMAT allows to adjust such an image so that you cut the "void" are by scalling (enlarging) the visible area to fit the whole screen.
A problem then appears when the signal source is normal and showing full screen. Then, because of the enlargement, you start missing some of the picture. Before there was nothing there because it was showing adjusted wide (cinema) format to the TV box format, but when the new TV box format gets enlarged it sure starts missing around the edges.
That's what you're seeing.
More and more TVs do not have the ability to adjust that through the TV itself. Don't ask me why, but they can only do it through the remote.
So if you have an original remote there MUST be a button there that's called ZOOM or FORMAT.
It does the trick.
Hope this helps. If it does do not forget to rate it.
Cheers,
www.coppelltvrepair.com
Posted on Oct 18, 2010
SOURCE:
Why can't I get football scores in upper left corner?
The score might be hit away by the rising football.
Jan 04, 2016 | Televison & Video
Small black box in upper left corner of Sony TV - need to remove
I had a similar problem on my Toshiba Regza but trying my fix couldn't hurt. I use a satellite dish for TV (if you do the same this might work)... I turned off my receiver, took the programming card out, cleaned it with my shirt (especially the part that looks like a computer chip), put it back in the receiver, turned it back on and when everything reinitialized the black rectangle was gone.
Hope this helps.
Apr 11, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
TELEVISION HAS NO PICTURE.SOUND ONLY.2yr OLD 32in VIZIO
Ur controller board it dead,the board with wire cables,that connected to LCD screen.
Nov 11, 2009 | Vizio L32 32 in. LCD HDTV
Picture went out
I also have the same problem on my 42" Vizio.
Sep 15, 2009 | Vizio L32 32 in. LCD HDTV
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
Cannot optimize picture width on new flat screen HD
On your cable box remote press the hd zoom button. I have comcast cable box and it worked for me.
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Discolored lines within picture 32 inch LCD TV
I have the same tv, if you turn up the brightness and turn down the contrast that should help a little bit.... Hope this helps
Aug 15, 2008 | Vizio L32 32 in. LCD HDTV
Cant see full picture w/ Vizio 32in HDTV
You would look for a format button on your remote.
Dish Network: bottom left the asterisk "*" button
DirecTV: top left, second from the top labelled "format"
Cable remote: look for format, zoom, or aspect ratio
Pressing this button should scroll you through the options.
Apr 16, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
851 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
