Question about Whirlpool LEB6200 Electric Dryer
Dryer won't dry
The dryer tumbles and heats up, but the clothes don't dry - - sometimes it takes 3 to 4 cycles of 60-minutes each
  • 172 Answers
Hi BethandRoss,
You have a loss of airflow from the dryer. Two things can casue this.
1. You vent going outside is blocked off with lint, bird nest or something.
2. your blower wheel is broken.
for problem 1. pull the dryer out and take the vent off. Start the dryer and feel the amount of airflow coming out. If you have none then go to problem 2. If airflow is good take a look in your vent going outside. Somewhere between that vent and outside you have a blockage. Clear it out or replace it if needed.
for problem 2. I would need your model number to give the exact direction to replace it. Since all dryer come apart abit different, and all dryers have different blowers, I would have to know the brand or model to help you further.
I really hope this will FixYa.
Have a nice night Mike Anderson
Posted on Jun 04, 2008
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
Ge adora dhdvh66ghobb stops heating after 8 minutes
bad thermostat possibly, which will do that
May 05, 2014 | GE DHDVH52GFWW Gas Dryer
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
I have a fridgedaire front load dryer (Model AEQ6700FS0) and it will start up, run for about 30 seconds and then it stops tumbling and the 3 lights on the far right (drying, cooldown, extended tumble)...
This is just a guess in a way, as I don't have specific knowledge about your particular model, but could it be a wrinkle prevention feature? I know some dryers have a feature which will cycle the dryer on for an occasional short tumble if the regular cycle ends and the clothes have not been removed. Opening the door might be all it takes to cancel the function.
Jun 30, 2011 | Dryers
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
Dryer flame on magtag wont stay lit. Pilot flares up but no flame
Thermocouple is probably bad. The pilot burns and heats a sensor which tells the CPU that the Flame can start, and the thermocouple heating up changes voltage with increase temperature and tells the CPU that the Flame is burning OK. If it is defective, there is no voltage change and the CPU assumes that the Flame didn't start for some reason, (Gas only!) and turns if off for safety. Over and over xx times.
My .02
Good Luck!
Mar 26, 2009 | Dryers
Whirlpool LEB6200 Electric Dryer Logo
155 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
