FixYa.com
Tags:
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Hampton bay fans
posted by Skyhawk1 on Jun 04, 2008
I have three new hampton bay fans with light kits. They all have remotes. Sensors sit ontop of each fan. The light switch for each fan have the duplex switches. With each fan/light set to separate duplex settings only the fan/light set to the original duplex can be controlled either by the light switch or the remote. With all three on the same duplex setting they can each be controlled by the light switch and the remote. Problem is When you turn the fan/light on in one room all three turn on. How can I get these fan/lights to be independent operations from the remotes and the light switch????
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 12, 2008
Not Rated (0)
jb78
Rank:Apprentice Apprentice
Rating: 66%, 4 votes
inside the remote, and inside the transmitter above the fan there are 4 tiny keys that set the frequency. set each frequency different then the remotes will only operate that fan. However if two lights r on and one off, when u turn the switch off they all go off, and when u turn it back on the same ones should come on. Then label the remotes!!!
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Electric Fans problems?
Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
hampton bay ceiling fan
i lost the instruction to my... Answer This...
hampton bay antique ceiling fan
i need the instructions for my... Answer This...
how to program my remote
I want to know how to program... Answer This...
Remote doesn't work?
My hard wired in wall remote... Answer This...
Redington III 52" remote...
Everything works fine except I... Answer This...
Repair Service
Find Electric Fan Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
