Question about Durabrand DB1200 CD Player
Durabrand DB1215 car radio
Sound cuts off from time to time just for a second or two, and when I turn up volume above volume # 30 , volume cut out completely and with no sound.
Usually when it cuts off that means its pushing too much power, might be that you have too many speakers in the car hooked up too it or that they have a very rare ohm rating which can sometimes effect how the stereo works. It also could be that one of the speakers wiring is hooked up wrong which you can usually tell by switching your balance back and forth between speakers, if it sound like more bass is coming out of one speakers then both usually means that one of them are hooked up wrong, not exactly shorting out but just switching the wires around will fix it
Posted on Aug 21, 2010
I have a db 1210 and i need the wireing plug for the speakers can you help
Posted on Oct 04, 2008
RADIO CUTS OFF WHEN VOLUME IS TURNED UP
It could be your wiring as well. Sometimes, when speaker wire gets cut and grounded, like your factory wiring to your door speakers or you tap into facrotry speaker wires to add more, the load on your deck increases. When the volume gets to a certain level, it will cut off because of the heat produced to maintain the load.
Feb 23, 2010 | Pioneer DEH-P4000UB CD Player
Instructions on installing durabrand DB1215
Why did my db 1215 not come with wires so I could install it in my car?
Oct 17, 2009 | Durabrand Car CD Player and AM/FM...
Power cuts out for approx. 3 seconds when volume is turned up above 20, the must be turned down or will cut out again.
it looks like you have a speaker going bad disconect all four speakers and conect one by one
Sep 30, 2009 | Kenwood KDC-MP232 CD Player
Radio cuts off and back on seems to be vol related
This is cause by many things one of which is a faulty speaker that is going short when operated at high volume. Another is the wiring supply the power to the radio is not "thick" enough hence not able to supply the demand for extra current. Had this same problem with Golf II which I replaced the main supply wire and after that it went to full volume with no cutting off.
May 12, 2009 | Sony Car Audio & Video
Shuts of when radio volume is above 24
check to make sure the ohms rating on the speakers is correct. should be equal to or higher on speakers compared to receiver.
Mar 11, 2009 | Kenwood KDC-MP235 CD Player
Durabrand DB1215
the db1215 that i have does have a clock....
press disp to display the clock,then release.
press and hold disp for 2 seconds, the clock will begin to flash.
press tune<< to adjust the hours and tune>> to adjust the minutes.
clock settings will be saved after 5 seconds
Jul 07, 2008 | Car Audio & Video
Error Code E-2
theres 2 screws on top of the unit called teansit screws. remove them, if that isnt the problem then return the pos.
Jun 14, 2008 | Durabrand WD268 Cassette Player
Sound
By no means is this a solution, only a comment - Internal Amplifier is bad. Check your wiring before installing another unit.
Jan 12, 2008 | Jensen CD4610 CD Player
Sirius radio connection
Yes, just plug it into the AUX port and keep pressing the mode button until it says "AUX" on the display!
Dec 27, 2007 | Car Audio & Video
Replacing car radio
you need to get a wiring conecter kit. the directions will be in the box. i just got mine today and had to get one of those kits... walmart has them =P
Dec 24, 2007 | Car Audio & Video
Durabrand DB1200 CD Player Logo
453 people viewed this question
Top Durabrand Car Audio & Video Experts
matt martin
matt martin
Are you a Durabrand Car Audio and Video Expert? Answer questions, earn points and help others
