Question about Gateway Computers & Internet
Power supply port don't work anymore, i tried with a fresh battery and work well,tried several power cords and nothing happen,so,i heard about gateway mt series have this factory defect,help...
    Sergeant:
  • 458 Answers
Power supply port? What is that? What battery are you talking about. What model and type of computer is this? If this is a laptop you will have to do the following. You have not really made your question clear. I will try to read your mind.
Sounds like your power plug has come desoldered. This is internal and will have to be taken apart to repair. If you are comfortable with taking it apart you can repair it yourself. If you have not ever soldered anything before or taken a laptop apart before you need to have someone else do it.
If you decide to do it yourself you will need the instruction manual to locate all of the screws. You will need a soldering iron and a camera along with a pencil and paper to draw a diagram and take notes. Laptops have a lot of fragile parts in them that will break. Do not do this if you do not know how. This is something that a qualified tech should do. You will see the plug and you will need to re-solder it back onto the board. One wrong move and you could damage the entire computer. If you try to do this yourself you are on your own and I am not responsible nor is anyone else.
Most of them have a break down on how to take it apart. The best thing that I can tell you is below. The only thing to do if you do not have the manual is to find a screw and take them out one by one. There should be a way to pop off the top part above the motherboard. You pry on both sides and it should pop up to get under it. The keyboard should pop up from the bottom. All laptops are not the same. Just be very careful, but if you are not sure that you can do it leave it alone. I could do it because I have done it before. Step by step directions without being there is very hard to do.
Posted on Jun 04, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Can you please let me know if this solved your problem?
    Rate this as a fixya if your problem is solved please.
    If you need more help let me know.
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
Dell Dimension 4400 NEVER froze (8-9 years old) until a week ago - kept freezing at start-up - - had to interrupt power SEVERAL times to restart - - tried to power up yesterday - - make a slight sound,...
You need a power supply! Go to Amazon and search for one that is the same specs as yours. Fairly easy to replace, don't use your old one anymore, it could be dangerous.
May 05, 2011 | Dell Dimension 4400 Power Supply ** FREE...
I have the protron 3750 the power light is red when i turned the power on the light turned green for a few second then turned red again and nothing happened. can you help?
Tries unplug,replug the tv like an hour later,the tv,now will reset itself back to the factory setting,tv should work now.Not,than the power supply board is having problems,not giving wright voltages to the tv anymore.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Protron PLTV-37 37 in. LCD Television
After start button is pushed several low buzzes is heard
Better check that power supply & where it plugs in at out. Also,make sure all the connections are plugged in tight inside. Never assume that a replaced part is good & if you went after-market for the power supply, don't go super cheap. Buy a good one with a good warranty & the same if not more juice than the original.
May 12, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
My compaq laptop will not turn on. With the power cord plugged in the power port light is on but nothing else happens. None of the display lights light up and nothing appears on the screen. Only the power...
if u know repairing laptop ,u just open the back case of that and remove full outlet & see where the screen display chip is attached to the motherboard,if u see that u just remove the screws and clean it, afterwords add some heat sink compound to that and attach with screws,this is the best best solution & do it carefully
Oct 21, 2009 | Computers & Internet
My nwz-e438f walkman wont charge anymore can anyone help me?
Hi hellohello21,
attach the supplied cable directly to the computer's USB port (don't use any other extension cord simultaneously). If that doesn't work, check if you've some problems with your USB driver.
Oct 15, 2009 | Sony NWZ-E438F Digital Media Player
My power cord not charging battery
you may have damaged the power input port.
broken solder joint. or your power supply took a dive. if you have a DMM 'meter' check the power supply to see if you are getting power from it.
if it is the power input port, you will have to either open up the laptop and see if it is a fixable soldering job or take it to a pro.
Happy Fixing =)
Jul 11, 2009 | Dell Inspiron 6000 Notebook
Batery problem?
The battery number is SNN5743A .
You can get it in various sites on the web.
Apr 09, 2007 | Motorola M500 MP3 Player
Computers & Internet Logo
52 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
