Question about Zebra Bar-One Platinum 6.0 for PC
Cross application and automatic print job with bar-one platinum
Dear expert, I need detailed steps as to how to pass data into the fields prompted for while printing a label. The Bar-one software prompts for selecting a model no. from a list connected to an ODBC server and the quantity of labels to be printed. The rest of the fields are filled in by the software by using the model no. selected.I am taking the user's input(model no. and quantity) and I need to make an automatic print job out of it. Please kindly help as the instructions provided in the help documents are not detailed enough. Regards, Riddhi Mazumdar Pentair Water Pvt Ltd.
Errror message JVM error 102 appears on screen
Problem
The BlackBerry smartphone stops responding and displays the following error message:
JVM Error 102
Cause
A problem exists with one or more of the .cod files on the BlackBerry smartphone.
Resolution
Before completing this resolution, download and install the latest version of BlackBerry® Device Software from your service provider's web site.
Re-install the BlackBerry Device Software and applications to your BlackBerry smartphone by completing the following steps:
Warning: The following procedures will delete either all data or all data and applications from your BlackBerry smartphone. Back up your data before performing the procedure. For instructions, see KB12487.
Connect your BlackBerry smartphone to your computer.
Open BlackBerry® Desktop Manager. Note: BlackBerry Desktop Manager may display "Disconnected." If this is the case, proceed to the next step to correct the problem with Application Loader.
Click Application Loader. The Application Loader Wizard appears.
Click Next.
Choose the port that the BlackBerry smartphone is connected to and click Next.
If prompted, type your BlackBerry smartphone password and click Next. The Device Application Selection screen appears.
Select the applications that you want to install on your BlackBerry smartphone.
If the Device Backup screen appears, choose whether or not to automatically back up the data on your BlackBerry smartphone. Click Next.
Click Next.
The Completing the Application Wizard screen appears, displaying all the software that will be installed on your BlackBerry smartphone. Click Advanced and make sure that Erase all application data and Erase all currently installed applications are both selected.
Note: If the application loader tool was not able to access all of the data on your BlackBerry smartphone, then the following two fields are grayed out: Erase all application data and Erase all currently installed applications.
Click Next.
Select Do not automatically create a backup and click Next.
Click Finish. The BlackBerry Device Software will be installed on your BlackBerry smartphone. Do not disconnect your BlackBerry smartphone until the process has completed.
Axl
May 04, 2010 | RIM BlackBerry Bold 9700 Smartphone
My phone says error 513
Hi, After typing the incorrect password ten times and restarting the BlackBerry smartphone, the error JVM 513 appears: This error occurs because all of the data and applications on the BlackBerry smartphone have been deleted. The BlackBerry Device Software must be reloaded on to the BlackBerry smartphone. To reload the BlackBerry Device Software you need the complete the following steps: Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps: To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications to be loaded, and then click Next. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Clear the check box next to Backup up device data automatically during the installation process. Click Ok > Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following: Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. Hope I helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 27, 2009 | AT&T Blackberry Curve 8300 Smartphone
Deleted/missing client details
Sheldon, The data might really be gone. There are several reasons you might lose data with Filemaker 7 including the file being closed unexpectedly due to power failure, so the application doesn't close the file properly, or the Filemaker application unexpectedly quitting. However, the data might still be recoverable in this scenario. Under the File menu there is a recover command you can try that will create a new "Recovered" file from the current one. Additionally, I strongly recommend you start a daily incremental back up for your FileMaker database files. While corruption issue are rare, accidentally deleting a record, or information in a field, or purposeful sabotage by an unhappy employee is permanent without a backup. Additionally, a back up would provide a solution for recovering the data in the event client data disappears in the future.
I hope I've done a good job answering your question. I am a FileMaker 7 expert (and 8, 9, and 10 as well); if you have any additional questions I will do my best to answer them. If my answer was helpful for you I'd appreciate a 5 thumbs up rating, or a click on the yes this was helpful button. Thank you!
Nov 25, 2009 | FileMaker Pro 7 for Mac, PC
I have reload sofware 513 on my bb 8900 screen and I have tried to plug it to my computter and my computter doesnt recognise it.
Hi, After typing the incorrect password ten times and restarting the BlackBerry smartphone, the error JVM 513 appears: This error occurs because all of the data and applications on the BlackBerry smartphone have been deleted. The BlackBerry Device Software must be reloaded on to the BlackBerry smartphone. To reload the BlackBerry Device Software you need the complete the following steps: Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps: To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications to be loaded, and then click Next. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Clear the check box next to Backup up device data automatically during the installation process. Click Ok > Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following: Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. Hope I helped you. Thank you for using ' Fixya ' and have a nice day!! .
Nov 17, 2009 | RIM BlackBerry Storm 9530 Smartphone
What i need to do when black berry has error jum 102
You need to run application loader...
  1. Open BlackBerry Desktop Manager.
  2. Click Help.
  3. Select About Desktop Manager.
  4. Click the Device Software tab.
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click Application Loader.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Clear the check box next to Backup up device data automatically during the installation process.
  8. Click Ok > Next > Finish.
  9. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
  1. Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
  2. Click Next.
  3. Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
  4. Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
  5. Click Next > Finish.
Oct 31, 2009 | RIM BlackBerry Curve 8310 Smartphone
So i messed up on my password threee times and now it says error 513 how do i fix it
Oct 11, 2009 | RIM BlackBerry Pearl 8100
Printer Won't Print
Step one: Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu. Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: Check the product cable, Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds. Reconnect the USB cable to the product and computer.
(NOTE: The product must be connected directly to the computer using a USB cable or a powered USB hub. If the product is connected to the computer through a non-powered USB hub, or if the type of hub is unknown, connect the product directly to the computer) after the product is connected to the computer, the product should start printing the jobs in the print queue. If the issue continues, proceed to the next step.
Step three: Determine whether the product is paused or offline, Click Start and click Printers and Faxes. The Printers and Faxes window appears. In the Printers and Faxes window, right-click the product icon and click Open. The Printers folder opens. On the menu bar, click Printer. Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it. If the menu includes Use Printer Online, click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: Stop the print queue, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder; Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs. (NOTE: If the queue was accidentally stopped, the print job will resume automatically. If the issue continues, proceed to the next step)
Step five: Delete the print jobs, Double-click Macintosh HD, Double-click the Application/Utilities folder.
Open the Print Setup Utility folder, Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue, Click Start Jobs, Double-click the appropriate product in the product list to open the print queue.
When the print queue is empty, click Start Jobs. Try the print job again. If the issue continues, proceed to the next step.
Step six: Remove and re-add the product to the printer list, Double-click Macintosh HD, Double-click the Application/Utilities folder, Open the Print Setup Utility folder, Select the appropriate product.
Click the red X to delete the product from the computer, Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer, after the computer is restarted, double-click Macintosh HD.
Double-click the Application/Utilities folder, Open the Print Setup Utility folder, and Reconnect the USB or Ethernet cable to the product. If the product is not automatically added, click Add. Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 18, 2008 | HP DeskJet 5150 InkJet Printer
HP Deskjet F380 All-in-one Won't print
Solution:-
Step one: - Restart the computer
Click OK.
Step two: - Check the product cable
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
If the menu includes Use Printer Online , click that option.
Step four: - Stop the print queue
Double-click Macintosh HD.
Open the Print Setup Utility folder.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
Step six: - Remove and re-add the product to the printer list
Click the red X to delete the product from the computer.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
HP Deskjet F380
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 12, 2008 | HP DeskJet F380 All-In-One Printer
I cannot print but i can scan
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 09, 2008 | HP DeskJet F380 All-In-One Printer
Zebra Bar-One Platinum 6.0 for PC Logo
62 people viewed this question
Top Zebra Computers & Internet Experts
pkwc
Mike
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
