Question about Panasonic SC-AK24 CD Shelf System
How to program out of sleep mode
How to take out of sleep mode
No trabaja la bandeja de cd un diagrama de SA-AK22 nececito
Posted on Jun 05, 2008
Why does my pedometer goes into sleep mode ewhen I stop and wont go back on when I start walking again. What do I havwe to do to get it started again?
This pedometer is programmed to go to sleep for a couple of reasons.
  1. To save battery life.
  2. To not inadvertently add steps to jostles or shakes. This pedometer has been programmed to only start counting steps at your 10th step from the sleep mode. This is to help with the accracy of the device.
May 08, 2014 | Ozeri 4x3motion Digital Pocket 3D...
Unable to turn off music in sleep mode
Hi, There are different levels of sleep a computer goes through as time passes and it can take a while for your computer to fully awaken. What happens is the computer closes programs not necessary in sleep mode. Some of the small programs used to carry instructions called batch files are in hibernation and especially in older computers with slower processors and very little ram can be a problem. You can set your computer to never sleep by going to the control panel and opening Power Settings. Good Luck
Feb 05, 2014 | Acer Computers & Internet
Cant get power saving mode off
Step 1:
Sleep Mode b> Sleep mode is primarily used with home computers (desktop computers). Sleep mode is designed to save the current work, programs, and settings of your computer using your computers memory, while using very little power. b> Hibernate Mode b> Hibernate mode is primarily used with laptop's. Hibernate mode is designed to save your computers current state on to the hard disk, then turn off your computer to stop using power completely. This mode is usually used when you do not plan on using your laptop for an extended amount of time. Benefits b> Using Hibernate mode is more power-efficient, but files may become fragmented over time by using this mode frequently. Sleep mode does consume more power, but the advantage that Sleep mode has over Hibernate is that it does not take as long to resume your computers former state when you are ready to continue using it.
Feb 23, 2013 | Lenovo 3000 Computers & Internet
Windows sleep mode problems
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Dec 21, 2012 | Computers & Internet
Kenmore 70121 air conditioner
There should be a sleep mode button on the remote. Press this then pres ok/enter.
Note: In this "MODE" the selected temperature will increase by 2 degrees F 30 minutes after the mode is selected. The temperature will then increase by another 2 degrees F after an additional 30 minutes. This new temperature will be maintained for 7 hours before it returns to the originally selected temperature. This ends the "Sleep" MODE and the unit will continue to operate as originally programmed. The "Sleep" MODE program can be canceled at any time during operation by pressing; Sleep MODE, "On/Off", "Fan Only" or the "V//X" buttons, on either the Control or the Remote. "Time Delay Stop" limit reached will also end "sleep" MODE.
Jun 01, 2012 | Kenmore Heating & Cooling
My icq is in standby mode and not connecting to the internet even when there is net in my laptop. what might be the problem?
when you are going to use icq make sure you get laptop out of going to sleep mode, i have found that desktops do same thign when going to sleep not only does desktop sleep monitor also, it puts programs that you left open to sleep.
May 11, 2012 | ICQ Instant Messenger
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
Dec 20, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
Turn off sleep mode, It causes prob. turning on programs to use computer
I have a hp desktop, each time I push the sleep button, the computer goes to sleep, however about 10 seconds ofter entering sleep mode it starts up again.How can I make the computer stay in sleep mode. thanks
Oct 13, 2008 | E-Machines eMachines Desktop PC
Panasonic SC-AK24 CD Shelf System Logo
170 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
