Question about Dictaphone 3750 Desktop Cassette Transcriber / Recorder
VOX I have a Dictaphone 3750 at work that I have never used before. It worked fine at one meeting, but later kept showing VOX pause when I was using conference record. How do I change this setting and just straight record? I have no owners manual available.
On the right-hand side of the unit, there are two buttons with on/off positions. Both the Speaker and VOX options should be in the off position. When VOX is turned on, it only records when it monitors a level of noise. I do not have it turned on ever.
Posted on Jun 18, 2008
Vox mini led projector light blinking problem
I dont think it as solution. when power on, it has to show the VOX logo initially. Later we can set the i/p mode...
I had the problem with my new led vox projector. Larer I replaced it. now I got the same issue with the replaced product. Each time I used only 2 to 3 hrs the device. Waste of buying such brands.
Jul 28, 2013 | JAKKS Pacific Eyeclops Bionic Eye Tv...
I need a handsfree headset recording device for the dictaphone 3750
Hello this is a great solution
http://www.tvps.com/Products/Nuance-Dictaphone-0421-C-Phone-Hands-Free-Overhead-Headset-with-Boom-Microphone---New__ECS-CMH.aspx if your unit is already modified for hands free with the 3.5 extenal jack mic input if not you also can send your unit to modified Send an email to service@tvps.com or call (805) 644-9525
Jun 08, 2011 | Dictaphone 3750 Desktop Cassette...
Dictaphone transcriber 3750 won't play, reverse, or go forward. What can I do?
Does anything show up on the display? Like 'No Cassette' or 'End Tape'?
Are you using a foot control? Does the tape move when pressing the buttons on the machine itself? Is the foot control plugged into the side of the machine (and NOT the back)?
Feb 18, 2010 | Dictaphone 3750 Desktop Cassette...
Tape stops
There is a switch on the right-hand side of the machine labelled 'VOX'. Set this switch to the 'OFF' position and you should be good to go.
'VOX' is voice-activated recording. It's designed to record only when someone is talking, and to pause when nothing is being said. In theory it's a great feature, but it never really works as good as you'd like. It'll usually miss the first few words you say, or it'll cut in & out while you're talking.
You can also set the 'VOX' sensitivity by adjusting the 'Tone/VOX' slider on the front of the machine.
Hope this helps...
Aug 13, 2009 | Dictaphone Audio Players & Recorders
I need to record something with Dictaphone 3750 - I have no manual and there is just a Tel. Rec button. Help
If you press and hold the 'Conf' button, the machine will record using it's built-in mic (located on the right-hand side of the machine, closer to the front). It is probably recommended to get a microphone that plugs into the machine for better recording quality. Depending on what you're recording, you could get a handheld microphone or a telephone record adapter that plugs into your phone and the back of the 3750 (press and hold 'Tel Rec' to use that).
Aug 08, 2009 | Dictaphone 3740 Desktop Cassette...
Foot pedal won't work with hands free microphone
The 3750 won't let you control the telephone record jack. The only way you can get a mic to work using the Tel Rec jack is by pressing and holding the 'Tel Rec' button for about 1 second. But this isn't compatible with the hands-free operation.
If you're looking to do hands-free recording, it uses the built-in conference mic. Press and hold the 'Conf Rec' button for about a second and it should start recording. This built-in mic is located on the right-hand side of the machine near the front by the headset jack.
If you want to control the machine via a foot control while in Conference Record mode, you'll have to change the 'Foot Control Dictate' setting in the menu. Here's how:
1) Press and hold the 'Erase' & 'Search' buttons for about 5 seconds until the menu appears.
2) Scroll through the options until you get to 'Foot Control Dictate' and set this to 'Yes'.
3) Press 'Stop' to exit the menu.
4) Press the 'Conf Rec' button to enter record mode.
Now you should be able to control the start/stop of the record function via the foot control.
Hope this helps...
Apr 13, 2009 | Dictaphone 3750 Desktop Cassette...
Telephone recording won't work
You need to have a telephone record adapter plugged into the back of the 3750. Then you press and hold the Tel Rec button until it begins recording.
Also check to see if the 'Vox' or 'VA' switch is on (voice activation). This will cause the machine to pause if the volume is too low.
Jan 15, 2009 | Dictaphone 3750 Desktop Cassette...
Dictaphone 3750 transcriber
If it does this with all tapes, there is a small "no-cassette" switch at the back of the cassette compartment. The switch may be broken, dirty or out of adjustment. When you open the cassette door you should be able to see the switch tab. Push it in just a bit to see if the No Tape indicator goes out.
Sep 09, 2008 | Dictaphone 3750 Desktop Cassette...
Dictaphone 3750 Desktop Cassette Transcriber / Recorder Logo
344 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
Alan W Kelly
Alan W Kelly
NOEL
NOEL
Pennywhistler
Pennywhistler
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
