Question about LG Washing Machines
Lg wm1814cw model front load, will not drain, hose is not clogged, filter is not clogged. Still will not drain, automatically.
  • Anonymous Mar 21, 2014
    won't drain completely if I have a heavy load
    drain motor does not operate. filter was not clogged. any other ideas.
    Champion:
  • 210 Answers
What you can do is go into the test mode, and see if the drain pump is operating, if not you will need a need drain pump. Do not put it into spin in test mode if you have clothes in there
Sgt 48
Posted on Jun 04, 2008
  • 110 Answers
You need to check the pump, if something is not clogged up in pump, please check the propellers, the propeller may have chipped and it will not pump out all the water if so...
Also use MelaPower He detergents.
contact me at marcwhite33@comcast.net
How do I put hose back in behind lower cover cap? pulled completely out when attempting to drain hose & clean the pump filter.
Go to www.youtube.com and enter
LG WM1814CW
Into search bar on youtube.
You will see various videos on How To Fix your exact model washing machine. :) x
Nov 17, 2014 | LG WM1814CW Front Load Washer
Where is the drain filter located
Hi.
If the model is WM1814CW, then the drain filter is located behind the small door located at the left hand corner at the bottom of the appliance's front side.
Regards.
Ginko
Aug 08, 2011 | LG WM1814CW Front Load Washer
Our LG Tromm WM1814CW frontload washer is not draining in the spin cycle, but its only sometimes. We have tried cleaning the Filter and its clear, we looked in where the filter is to see if its clogged,...
hi Shellinator7.
check the small drain hose on the side of the pump that is clogged, then that is not a failure that will significantly affect the normal operation of the washer. If your washer is not draining okay and you don't mind catching some water that spills out of that pump filter area when you open it up, then you don't necessarily need to remove that front panel and bother with unclogging that small drain hose. If the large hose between the tub and the pump or the discharge hose between the pump and the house drain behind the washer is clogged, then you may need to open up that cabinet.
you could also check out this link and read up some more on this.
LG Tromm front load washer not draining in the spin cycle Google Search
Dec 14, 2017 | LG WM1814CW Front Load Washer
My LG Tromm WM1814CW is not draining. I cleaned out the drain filter and checked to make sure the drain hose is not kinked and still - there is no water draining from the machine except when I pull out the...
Check inside the filter housing with a flashlite for debris that got around the filter. If it is clean, you have a bad pump and it needs to be replaced.
Jan 26, 2010 | LG WM1814CW Front Load Washer
Lg front load washer WM2301 will not drain
drain hose may be bent or clogged, or the drain filter itself may be clogged
Sep 11, 2009 | LG WM1814CW Front Load Washer
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
Where is the drain filter and the spin rinse sensor located on
Have not heard of a part called a "spin rinse sensor". Drain filter is located behind the small access door at the bottom left on front of the machine. Use small hose there to drain remaining water out of pump and hoses, then unscrew the big thing on the right side (end of the filter).
Mar 14, 2009 | LG WM1814CW Front Load Washer
Washer won't drain
You either have a foreign debris trapped inside the drain pump or the drain pump is broken.  You will need a qualified LG technician to repair this problem.
Jul 01, 2008 | LG WM1814CW Front Load Washer
LG front washer WM1814CW error OE
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 16, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
314 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
