Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Model # GSS201EPJWW
My almost 2 yr old side by side ice and water in door refrigerator is making an annoying humming sound- Any one else have this problem?
Thank you!
  • ksachrisf Jun 04, 2008
    GSS22JERFWW:
    MINE HAS A WHISTLING SOUND ALONG WITH ERRATIC FAN SPEED INCREASING AND DECREASING EVERY FEW SECONDS.
    COOLING SEEMS TO BE TOO COLD AS WELL.
  • charjun Jun 13, 2008
    Thank you !
    Scholar:
  • 110 Answers
Bad main processing board
Posted on Jun 13, 2008
I have a GE model GSS201EPJWW side by side fridge. The ice maker makes ice but we can not get the dispenser to operate. At times the water will work but not cubed or crushed ice. What can be done to get...
Dispenser works with a motor which might be jammed. When you see the ice storage bin, there is a steel coil which rotates with the motor and ice falls down from the dispenser. See if the coil rotates at all and if so then the motor must be defective.
May 15, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Home from vacation--no ice.
Check the fill area of the ice maker for an ice blockage.
- make sure the tube on the back of the Ref. is connected to the white rectangled block of the fill tube.
- check to make sure the water filter in the bottom of the unit was not kicked and has popped out or is not seated / locked in place.
- Check to see if water is actually getting to the unit.. from the 1/4 inch supply line.
If your icemaker is the common one there here is a way to test it:
(I noted GE Profile but not an exact model number)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Last question... does water in door work?
Thanks for using FixYa.
Kelly
Apr 03, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice and water is not coming out. ge side by side
Check the plug to the door first. Then turn the ice machine head off unplug the refrigerator for a few minutes. Plug it in and turn on icemaker. this part problably just lead back to squre one. have someone push the button for water while you are listening at back bottom for humming sound,if you dont hear it its probably a bad water valve.
Mar 21, 2009 | GE Refrigerators
GSS201EPJWW side by side refrigerator
I HAVE TRIED A BLOW DRYER ON THE INSIDE OF THE FREEZER DOOR WHERE THE ICE GOES INTO FOR 5 - 10 MIN.AND IT STARTED WORKING AGAIN  :-)
Aug 18, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Click in circuit board Light in Icemaker dim bright Warm both sides
I didnt understand what you meant by refer(refrigirator???) and IM..??
Jun 26, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
GE 23.5 CU FT side by side w/ice maker and water in the door.
replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Ge side by side - high low humming noise from freezer section
Sounds like its the evap fan motor to me. Not very easy to axcess. I have had one GE make the same noises you are describing to me. Let me know if you are going to attempt it and need more assistance
Nov 19, 2007 | Hotpoint HSS25GFP Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
422 people viewed this question
Top Refrigerators Experts
KJ4QOB
Alan Moore
Level 1 Expert
Gerardo Ahuactzin
Gerardo Ahuactzin
Level 1 Expert
