Question about Insignia IS-LCDTV32 32 in. Television
Sound but no picture... help please
I got this tv about 6 months ago everithing was good but a few days agoi ran into this problem.When i power on the tv i get sound but no picture.i tried the trick with the hair dryer but that didnt work... someone else suggested to change some caps or even the powersupply but if it was the powersupply than i woudnt get any kind of sound right.. some one else said something about changing the lamp... but i dont know where the lamp is located inside the tv.... what can i do????
  • Charpa Jun 09, 2008
    I have same issue, green color background, sound and no picture. This is second time this has happened. The first time it suddenly returned to normal. When I cut the TV on yesterday, it showed up green. TV was working fine prior to this.
  • 2,326 Answers
If no audio, the assembly where the tuner is mounted needs to be replace.
I have repair a few LCDs with similar failures.
In many cases the audio amplifier became defective as well.
If you need more info, my email is
Posted on Jun 12, 2008
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
sounds like the vertical output is causing the CRTs to shutdown for protection. Try resoldering the vertical output IC that will often correct the problem. If not the vertical output IC may be defective.
May 17, 2008 | Samsung HCN4226W 42" Rear Projection...
36" Sony Trinitron blinking red 4 times-PLEASE HELP QUICK!
Sounds like a typical high-voltage failure. Could easily cost another $300 to have it fixed. If it is less than about 6 years old I'd say it was worth fixing. If you want to DIY, then pull all the electronics out (label all the connections) and send it all to either Module Exchange at 972-298-1212 or PTS Electronics 800-844-7871
Feb 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV Won't Stay On...
I had a service some out and they replaced the amps and the TV has worked fine since then....
Nov 15, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Blinking green light, no picture or sound
Hi, bought television only 2 months ago now blinking opc light and power lights with no picture or sound. Whats up with that?
Sep 13, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Hello, You have a high voltage section problem I would not suggest fixing this set on your own. You will need to take this set to the shop. Because there are no user repairable parts inside of the set.
Sep 10, 2007 | Sony KV-36XBR400 36" TV
Insignia IS-LCDTV32 32 in. Television Logo
50 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
