Question about True 52 cu. ft. / 1472 liter Commercial Freezer TM-52F
True Commercial freezer not cutting out
My true 2 door commercial freezer is not cutting out when it reached the apropriate temp. It only works again after I unplug it for a few hours and leave the doors open. Could it be the defrost cycle is to short?
Please help!
Tech. can not find freeon leak in line but endicator is regestering freeon leak in side of back panel.
Posted on Aug 27, 2008
Freezer door is very hot to the touch on the outside
Hello, their are heat coils in the doors, their maybe a issue with the door heat circuit controls.
Mar 18, 2014 | True 72 cu. ft. / 2039 liter Commercial...
Our old Imperial heavy duty commercial model uf20x needs seal. Where to find it?
Commercial refrigerator parts supplier can make it same day. Check google for your nearest supplier.
Feb 01, 2014 | True 72 cu. ft. / 2039 liter Commercial...
Fan does not come on nor does door light. Also will run to cold temp when it cycles off cabinet warms up very quickly
have you checked the door switch for each door? the lights should still work in defrost mode but not fans or compressor.
Jan 08, 2014 | True T23F Commercial Freezer
Regarding replacing the temperature control on the True t-23f freezer, I can't find it.
As soon as you open the freezer door the temp control is at the upper right of the freezer.
Mar 20, 2011 | True 23 cu. ft. / 651 liter Commercial...
We have a True TS-49F freezer that the interior fan have stopped working. Holding the door switch does not activate them. Unit is out of warranty.
Most all commercial freezers like yours have, what is called, a fan delay. It is located in the evaporator case and is usually attached on or very close to the actual cooling coil. It may also be a combination switch known as a defrost terminator/ fan delay. It's purpose is to keep from circulating warm air. If the cooling coil does not reach a preset temp, the fans do not come one. Another thing is that the fan motor may just be bad. If you have more than one fan, then chances are that it's going to be the fan delay. I would start there to see that either the fan delay switch is bad or there is a reason that the coil is not getting cold enough to activate the switch.
Nov 09, 2010 | True 49 cu. ft. / 1388 liter Commercial...
What could cause an evaporator coil to freeze up on a true t-19f. Also what is the suction pressure on this model.
Hello
Could be low on freon,i belive this model uses 134A.
So the suction pressure should be 31 to 35 psig,for a temp of 36 to 40.f
Also check the defrost timer and the door seal. The eveap should have a drain line on it, make sure this is working and not plugged.
Apr 07, 2010 | True 19 cu. ft. / 538 liter Commercial...
New Commercial True Freezer suddenly quit freezing
Check for freon leak>> is compressor running?
or Iced over?
Jan 29, 2009 | True 72 cu. ft. / 2039 liter Commercial...
True commercial freezer
The ice could be preventing the freezer from freezing properly, try defrosting the unit. if this does not help then this could indicate a more serious problem like a bad temp sensor or refrigerant leak.
Apr 27, 2007 | True 52 cu. ft. / 1472 liter Commercial...
True 52 cu. ft. / 1472 liter Commercial Freezer TM-52F Logo
188 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
