HP LaserJet 4250 Jet Direct Error
On the Printer Screen it appears- "49.4C18 ERROR"
This appears when I configure JetDirect Properties.
This is related to firmware.
If you connect a parallel cable direct to a PC, then send the firmware directly to the printer.
This typically fixes the issue.
go to DOS command and type:
copy /b *.rfu lpt1
You must be in the folder where the RFU file is located.
You must also have one RFU file in this folder.
Good luck
Posted on Aug 12, 2008
Have you updated the firmware to the latest version?
Posted on Jul 31, 2008
Hp laserjet 4250 error 49.4oc2 service
If the error won't go away, the printer could have a bad memory DIMM, a bad JetDirect card, a bad Firmware DIMM or a bad Formatter.
Pull out the JetDirect and power up. If the error is gone, try reseating the JD. If error reappears get the card replaced. If the error is still present after removing the JD call a tech to look at it.
Nov 05, 2011 | HP LaserJet 4250tn Printer
Who can configure IP in 4250 Printer
To configure the Jetdirect printer server on your printer as a network printer, please click on this link and follow my instructions.
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Jun 28, 2011 | HP LaserJet 4250n Printer
My HP 4100tn will not print and I am getting error message as follows: 82.0180 EIO 2 ERROR I printed a document and then when I tried to print another document I got the error message. How can I fix...
Thank you for contacting FixYa with your printer inquiry.
This is an error caused by the jet direct card in your printer, try one of two things.
  1. Move the Jet Direct card from port 1 to port 2 on the printer.
  2. Replace your jet direct card with one that you know is good.
Test to see if either of these resolves the issue.
The problem is usually a faulty card.
J7934-69011 JetDirect 620n internal print server - 10BaseT and 100BaseTX LAN interface board - Plugs into peripheral EIO slot - Has an RJ-45 connector
Vender
http://www.dectrader.com/J6057-61001-New-HP-JetDirect-615N-internal-print-server-10Base-T-and-100Base-TX-LAN-interface-board-Plugs-into-peripheral-EIO-slot-Has-one-RJ-45-connector.html?utm_source=googlebase&utm_medium=shopping&utm_campaign=parts
image.php?type=p&id=223008&t250=y
Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 22, 2011 | HP LaserJet 4100n Printer
We believe the problem with our LaserJet 5000 GN is the JetDirect 610N network connection on the back. It prints its own internal documents just fine, so we know it's not that. And the network itself seems...
New Part Number is J7934A it is newer version and costs about $75.00 . To test the jet direct, press menu and then information, print the configuration page, if more then 1 sheet comes out 1 will be for the jet direct if this prints there is nothing wrong with the Jet Direct. however if you are printing through the network and you are getting any type of special characters like $%^ it is most likely a driver issue, uninstall the printer and reinstall using PCL 6. You can go to HP's wesite for driver support. Hope this helps.
Jan 03, 2011 | HP JetDirect 610N Print Server
What are the options on HP laserjet 4250 menu, i want the one to enter IP configuration
Follow these steps
Menu
Configure Device
I/O
Jet Direct Menu
TCPIP
Configuration Method
Oct 25, 2010 | HP LaserJet 4250n Printer
I have both green light next to the rj45 on my jet direct 610n, but my jet direct doe not show when I print the configuration page, I tried cold reset didn't help. Any idea howni might be able to...
If your JetDirect Ethernet card does not show up on the configuration page then the JetDirest is bad. This is somewhat common with the 610N cards. You will need a new card. They are cheap to buy just about anywhere including Ebay. I have replaced dozens of them over the years.
Sep 12, 2010 | HP LaserJet 4100tn Printer
Need installation program
you can check how to setup, install and configure your HP laser jet 4250 printer from here
Click to see check the page
and here is the driver link for your HP laser jet 4250 select your operating system then download
Click here to Download the driver
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
Manish
Jan 12, 2010 | HP LaserJet 4250 Printer
I am on a network with a brand new HP 8500. I have searched for the printer and my laptop doesn't pick it up. What amI missing?
Have you checked that the IP range for the printer is on the same IP range for your network? you could always cold reset the printer which will reset the network card back to zero's. You attach it to the network and your server should issue an IP address via DHCP. You should be able to see it on the network then.If not, the jetdirect network card may be at fault.Has the printer got a Jetdirect network card installed?
Oct 15, 2009 | HP LaserJet 8500 Color Printer
Error during print 'Remove all paper from bin'
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Have a nice working day.
Jul 17, 2009 | HP 4250 Monochrome LaserJet Printer
Jet direct card setting
Use the HPJetDirect software to configure printer. I uploaded it here:
http://wikisend.com/download/458082/HPJetDirectDiscoveryTool inpw_enww.exe
Click the BIG GREEN DOWNLOAD button. If the software cannot find the printer, try connecting printer network cable directly to computer.
Jun 17, 2009 | HP LaserJet 2500N Printer
Computers & Internet Logo
356 people viewed this question
David Payne
David Payne
