Question about Toshiba Computers & Internet
My pointing device soft keys are disabled, how do i enable it?
  • T&N Family Electronics Dean and Sherrie Terrell
    What are pointing device soft keys? I did a google search and this is what I came up with. I have no idea what you are talking about. Google came up with 1,400,000 possibilities for your question.
  • 85 Answers
Remove its software from computer . after restarting computer reinstall it again
Posted on Jun 04, 2008
I have a toshiba laptop. I accidentally disabled the synaptics pointer/cursor. Now it won't move.
Well, you have two options on this one. If it's just disabled and there's no keyboard shortcut to re-enable it, you can either:
1) Use the Windows key, the Tab key and the arrow keys to navigate through the menus to re-enable it. You would need to go to Control Panel -> System -> Device Manager and go through to find the right one to re-enable. This is possible, but would be pretty difficult and time consuming to do if you're not used to keyboard shortcuts.
2) Buy or borrow a wireless (or wired) USB mouse that you can plug in long enough to go into the Control Panel and re-enable the touchpad using the same steps as above.
In the Device Manager, look for anything with a yellow exclamation point or a red 'X'. Those will be either problem devices or disabled ones. It should be under 'Mice and other Pointing Devices' or something similar.
Hope this is helpful!
May 11, 2011 | Toshiba Satellite PC Notebook
I have a compaq 620 and would like to turn OFF the mouse / track pad under the keyboard... please help!
Try these solutions: > 1.. F10 to enter bios setup at boot time
> 2.. Advanced
> 3.. Device Options
> 4.. Dual Pointing Devices
> 5.. Use arrow keys to select the pointing devices you want enabled
> 6.. F10 to save settings
> 7.. File-Save changes and exit
> 8.. F10 to confirm
>If the Synaptic's Touchpad driver is installed
touchpad/point stick can be
>enabled/disabled via the mouse properties in the control
panel applet.
Or:
> 1.. Start
> 2.. Control Panel
> 3.. Mouse
> 4.. Device Settings Tab
> 5.. Select the device and click on the enable or
disable buttons. "
If this helps, please rate. Thank you.
Jan 18, 2011 | Compaq Evo N610C Notebook
Cs walked on my laptop. noow cursor pad not working. Help
have a look at the F keys - is possible one of those disables the touch pad
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to claasic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 20, 2010 | Compaq (153515-001) Touch Pad
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Problem with mouse in my new Dell laptop
Touchpads
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | Dell Inspiron 1420 Laptop
My touchpad has stopped working. Device Manager
Comment back with Make and EXACT model
Mar 24, 2010 | Computers & Internet
My my touchpad doesnt worrks
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, option here to Disable,
Feb 23, 2010 | Dell F3534 Touchpad
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
Touchpad not working
First check: Control Panel -> Mouse -> TouchPad On/Off
Second check for a button near the mouse pad, often there are buttons that will enable/disable the touchpad
Thrid use the shortcut key FN+F9(or what ever F key that is used by your laptop) to disable/enable the TouchPad.
Fourth try this software: http://www.kingzm.com/eng/files/download/MouseManager.zip
Fith
- Select Start, Settings, Control panel.
- Open System, click on Hardware, and Device Manager.
- Expand "Mice and other pointing devices", and double click on the entry below, that may be called "HID-Compliant mouse", or "Alps Pointing Device".
- Under "Device usage", choose "Do not use this device in the current hardware profile (disable)", and click OK.
Jan 20, 2009 | Toshiba Satellite A205-S4617 Notebook
How to disable touchpad
To enable/disable touch pad go to "Device Manager" (right click on My Computer icon on the Desktop). Pick "Mice and other pointing devices", right click on your touch pad, select instal/uninstal. May need to reboot the computer if requested.
However - if you do not have any other pointing device (USB mouse) you will only have keyboard for your disposal.
Oct 06, 2008 | Computers & Internet
Computers & Internet Logo
13 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
