Question about Casio FX-260 Calculator
PROBLEM W/ CASIO fx-260 SOLAR
HELP!
I cannot get out of the DEG or RAD or GRA modes. I am trying to get back to COMP mode which should be indicated by an absence of display in the mode indicator. MODE 9 does nothing
  • 2 more comments
  • afunfrnd Oct 24, 2008
    I have the same problem. The can only get deg, rad, and gra. I cannot get norm, sci, fix, or comp. How can this problem be solved?
  • Anonymous Nov 13, 2008
    How do you put this calculator into SCI mode?
  • Anonymous Dec 03, 2008
    me too...
  • Anonymous Feb 14, 2009
    I have the same problem??
  • Casio Master
  • 7,993 Answers
Sorry, but I think you misunderstood what the manual says. See the not on the screen capture.
True the sentence is not very clear, but what it means is the following:
All modes (except COMP) will have an indicator (with the appropriate labeling) displayed. When in COMP mode the COMP indicator is not displayed.
The truth of the matter is that computation- wise you have two MODES only : the general COMPutational mode and the Standard Deviation (SD Statistics) MODE. These two are incompatible because the key layout is different.
But to compute trig functions
  1. calculator must not be in SD mode, hence it is in COMP mode
  2. An angle unit must be shown on display.
Read the screen capture about the MODES of this calculators. DEG,RAD, and GRAD remind the user that the angle units in trigonometric function calculations and coordinate conversions are in degrees, radians or grads. They have nothing to do with the other calculations you are doing.
PROBLEM W/ CASIO fx-260 SOLAR - 874c328.jpg
You can only remove DEG by changing the angle unit to RADians or GRADs. In so doing, the new unit indicator (RAD, GRAD) will be displayed instead. There is no point worrying about the angle unit indicator unless you are performing coordinate conversions or calculating trigonometric functions or the inverse trigonometric functions.
MODE 9 cancels the FIX display format: decimal are displayed with a fixed number of decimal places (set by the user). After this key sequence the decimal display format reverts to NORM(al).
Posted on Jun 22, 2010
How do I clear "DEG" from display?
You can switch between Rads/Deg/Grads. Deg is the one you want to use. So, to answer your question, the "DEG" is suppose to be there so that you know what mode you are using. If you don't have the manual, here it is:
http://support.casio.com/pdf/004/fx82SOLAR_E.pdf
Nov 11, 2014 | Casio FX-260 Solar Scientific Calculator,...
HOW TO SET FX-82ms TO RADIANS
Press the MODE key until you get the "Deg Rad Gra" screen. Press 2 to select radians.
May 19, 2012 | Casio FX-82MS Scientific Calculator
How to set casio fx-82ms scientific calculator to radians
I want to remove rad and sci symbol from casio fx-901 calculator display
For removing SCI symbol press following keys Shift-->Mode-->8-->1.
You can't remove RAD symbol, you can only replace it by DEG or GRA.
Aug 22, 2011 | Casio FX-115ES Scientific Calculator
I want to know how i can change the mode of casio fx-350 into "DEG" to solve the problems cncerning tan cos and sin
Press the MODE key a certain number of times until you reach the screen that says DEG RAD, GRA. Press the number that corresponds to DEG.
May 22, 2011 | Casio FX350MS Scientific Calculator
When you are in "comp"
The "Deg" indicates degrees are the unit used for trigonometric calculations. You can use [MODE] [5] to switch to radians or [MODE] [6] for grade. [MODE] [4] switches back to degrees. This is independent of "Comp" mode.
Jan 16, 2011 | Casio FX-260 Calculator
DEG mode
The DEG indicator has absolutely nothing to do with division, fraction or other operations. It is relevant only when you are calculating trigonometric functions (Sine, Cosine Tangent and their inverse functions.)
When you are calculating trigonometric functions the results depend on the angle unit the calculator is configured for
DEG >> angle values are in degrees.
RAD>> angle value are in radians
From the equivalence 180 deg =Pi radians you get
1 rad= 180deg/Pi=180 deg/3.14..=57.29577951 degrees.
The DEG indicator merely reminds you that angles are in DEG. If you change the unit to RADians the RAD indicator will be displayed instread.
Apr 15, 2010 | Casio FX-260 Calculator
Problem with Casio FX 260 Calculator
Dec 03, 2008 | Casio FX-260 Calculator
Casio FX-260 Calculator Logo
1,774 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
