My washer leaks from the bottom during rinse cycle.
  • juliensales Jul 22, 2008
    I have the same problem but my leak is being caused by two holes in the bottom of the tub basin, has anyone ever heard of this before?
    Why would they use a plastic tub???
    bjulien.tubex@acmesaw.com
  • 240 Answers
Possibly from drain pump. or tub seal. you will need to look inside cabinet to tell where from. please post model for more info.
Posted on Jun 04, 2008
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Frigidarie Stackable Washer and Dryer leak
Check the Drain Tube, Check the Screen. When it gets to the FIRST Spin Cycle, Check the Water Level inside the Drum and see if it is Completely Draining... There is a Water Level Switch that should not be allowing it to Overflow so you may have an issue there... But first check for a Blockage
Aug 07, 2014 | Frigidaire FEX831CS Top Load Stacked...
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
Water leaking from bottom of machine - machine not washing well
It is important that you look underthe washer to confirm the point of leak so as to get a first hand information.If the leak is during the wash cycle it can be from fault of the celing gasket or a leak from the drum moving spindle.However if it is during the rinse cycle,the leak can be from the out let hose,drainvalve/drainpump.If so the hose can be tighten or the valve pump can be removed,repaired and reset.
Aug 31, 2010 | Samsung WF337AA Front Load Washer
Washer leaking from the bottom
make sure your drain pipe is not backing up when washer drains
Jan 10, 2010 | Washing Machines
Leaking from bottom of washer
Do you have the little door at the bottom to collect lint and stuff that goes through the washer? I had a leaking problem once when I simply didn't tighten it enough. Check that.
May 06, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Washer leaks from bottom during rinse cycle
Take the cover off the back, and look up, next to where you put the soap in, when it's filling/rinsing. There is (like) a (white) plastic valve body, and look to see if water is dripping out of it. I haven't figured out a solution to that yet, other than to replace it.
Also check the boot, coming off the pump. You could have a bad/dry boot, or a loose hose clamp.
Mar 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
