Question about HP Photosmart M407 Digital Camera
Unsupported card I am getting the error message of unsupported card when this is the same card I have been using since I got the camera 2 years ago..why is it starting that now??
  • Anonymous Nov 04, 2008
    I also have the M407 and it recently started displaying "Unsupported Card" on the LCD using the same caed that I bought with the camera.
    I have tried the following:
    • Several different SD cards.
    • Upgrading the Firmware.
    • Formatting internal Camera memory.
    • Formatting the SD Card.
    • Leaving the camera without power for days.
    I'll check back again for answers.
    Thanks!
    Chris
  • 3 Answers
Yep, i have the same problem. info in manual says that m407 support up to 8gb, but only sd, non sdhc
Posted on Aug 07, 2010
    Scholar:
  • 54 Answers
The first thing you will have to check the card. There is slot on the card that contains a switch. This will lock the card so that it is write-protected. This will cause the unsupported card error.
If the card looks fine, try a card reader just to confirm that the card has not been corrupted.
If the card is functional and you can read its contents from the PC or another SD-slot device, then the issue is your camera. The slot contains thin copper prongs that comes in contact the copper surface on the back of the SD card. If the prongs are bent or damage, then the camera cannot read your card.
I have fixed this before. So if you details instructions, contact me.
Posted on Dec 10, 2008
4 Suggested Answers
Bogdan
  • 198 Answers
SOURCE: unsupported card error
Hello, This may be related with the sd card reader in the camera. It's pins doesn't make a perfect contact with the ones on the sd card. In order for your camera to recognise the card only 4 pins can be connected. However in this case the camera will give you this error because it can't acces the card (send information to it or receive) because of the missing pins. It will only recognise it as a card. The camera must be dissasembled and the card slot needs to be checked out for 2 things. One is that it makes perfect contact when a card is inserted, the other is that it gives you the right voltage to the card in order to power up correctly. When it will be checked with a voltmeter it will need to show up some 3.8 - 5.8 volts on some pins (i guess pin 3 and pin 7). These check need to be done in a service center, because dissasembling the camera yourself can result in other problems most often damaging the lens unit wich is a very delicate mechanism. Good luck and please reply if you need more info.
Posted on Apr 25, 2007
  • 3 Answers
SOURCE: Memory Card
Try taking the SD card out then plug the camera into the p.c then format the internal memory.
Posted on Apr 08, 2008
informatica
  • 1114 Answers
Hi - You can download the manual by clicking the link underlined in blue below:
Photosmart M415
See page 166:
Also try formatting the card in the camera as cards that have been used in other cameras or formatted on a PC may not work correctly until formatted in the camera.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Sep 06, 2008
Put memort card in camera,,didn't realize I had to format disc.followed instructions in book to format but does not tell me it is formatting,,, still get unsupported card message
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Please note that your particular model camera can only use up to 2GB standard SD cards. These are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Sep 27, 2011 | HP Photosmart M417 Digital Camera
Error 9
Is there a camera or smart card connected to the printer? This error usually has to do with an unsupport camera or card being connected.
Feb 28, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I have 2 Hewitt Packard 433 photosmart Digital camera's. The built in memories work but when I put in card's message come's up *unsupported card* Can this be fixed?
Having gone over a month without a response to my query, I assume the problem was caused by trying to use an SDHC card in an SD device.
Aug 19, 2010 | HP Cameras
SD Card Not Working
Well here's a probem indeed. If you did infact buy an SD Card i believe it should work. But if you bought an SDHC, your camera might not support it. I know my camera i bought a couple years ago can not support SDHC cards. They look the same, but they transfer data much faster. Let me know if that is not the case. chris173@gmail.com
Apr 19, 2009 | HP Photosmart M407 Digital Camera
UNSUPPORTED FORMAT
Since this camera is fifteen years old, and is long discontinued, it is unlikely that spares will be available for it. The camera shop gave you the most cost effective advice.
Apr 08, 2017 | Kyocera Finecam S3L Digital Camera
Roland SPD-S Flash card error
The card I have always been using is now also suddenly giving this message. I found an old SanDisk 16MB and a 1GB SanDisk that works perfectly in my Boss 864 and they also give the same message. Trying to go into formatting brings the message "no card!"
May 13, 2008 | Roland Spd-S Sampling Percussion Pad...
Digital camera error
1. What's the make and model of the camera?
2. What's the make, model and capacity of the memory card?
3. How old is the camera?
Dec 19, 2007 | Cameras
Memory Card
Nov 13, 2007 | HP Photosmart M415 Digital Camera
Card Error?
i think you have broken or bended any of the pin inside the card slot, and that is creating problem. Try looking in the card slot you may find any of the connector pin broken or bended. Try straighten the pin cautiously and may your machine start working .
Aug 16, 2006 | Fuji FinePix S7000 Digital Camera
HP Photosmart M407 Digital Camera Logo
419 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
