Question about SNK Skyworth SLC1963A 19 in. LCD TV/DVD Combo
My skyworth 15.6in flat screen has been saying no signal
  • 67 Answers
Check the input selection on menu of tv, it may be trying to read dvd player without dvd inserted or another device connected to tv. also check to make sure cables are secure,. Most likely it is on wrong input.
Posted on Oct 17, 2010
DVD says no disk
Posted on Mar 16, 2012
SOURCE:
How to rectify the no signal problem
PUT SIGNAL SOURCE IF PERSISTS CHANGE THE WHOLE INPUT PANEL OF THE TV ITS FAULTY
Oct 08, 2015 | Skyworth SLC-1971A 19-inch 720p LCD TV/...
Remote codes for skyworth flat screen tv using a one for all 3220 remote
The 3220 has been around for a while. Here is a link to a code book: http://www.revoxremotes.com/Remotes/URC3220_Codes.pdf
But I didn't see Skyworth...
You may have to resort to the code finder technique included in the manual.
http://www.revoxremotes.com/remotes/urc3220.pdf
Dec 28, 2014 | Televison & Video
Skyworth tv
Check all the signal cables connected with the TV. If all are found OK, check the TV by tuning to an on air channel. If it do not tunes, check and replace the tuner.For more information, check the link ttp://electronicshelponline.blogspot.com/
Nov 18, 2013 | Televison & Video
19" skyworth tv/dvd and it says no signal on DVD
Its main system control memory IC should be checked and replaced. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
Apr 25, 2013 | Televison & Video
My skyworth slc-1551 screen keeps going blank, then a pop up window comes up and says image is blocked enter password
When I called the customer service said to try 1979, or 0000 or, 1111, or 9999, the first one worked me.
Jun 17, 2012 | Starlite Skyworth SLC1551AW 15 in. HD LCD...
Can I watch tv in thailand on my Skyworth LCD
Yes,Thailand have PAL signal frequencies.Ur LCD tv work with PAL signal freguencies.
Nov 08, 2010 | Samsung LN32A330 32 in. LCD TV
I have a 15" skyworth tv my screen has been severely damaged can it be repaired?
Probably not economically worth fixing, you can buy a new one for less than $100.00?
Jun 01, 2010 | Starlite Skyworth SLC1551AW 15 in. HD LCD...
My computer screen has a big strip running down the middle, how can I fix?
looks like your screen has a bad lcd cable (internal), you should conatct Skyworth or take it into a local bestbuy or staples. Reply and Vote!
Mar 28, 2010 | Starlite Skyworth SLC1551AW 15 in. HD LCD...
I have a Skyworth 32" flat screen television I am having problems with the remote as all I can do is turn the television on, I can not adjust the volume, select channels and can not turn the television...
not sure , but it could be as simple as the batteries are down and the on button is the last thing that will work. Do the side buttons work? They might help you find a way out of the problem. Maybe parent control too.
Nov 12, 2009 | Toymax Skyworth SLTV-3263A 32 in. LCD TV
SNK Skyworth SLC1963A 19 in. LCD TV/DVD Combo Logo
221 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
