Question about Acer Aspire 5100 Notebook
Fios Wireless Drops
I have the same problem where my wireless drops every few seconds. I tried to uncheck the v.6 that you suggested, but it still does the same thing.
  • Anonymous Aug 15, 2008
    New to Verizon FiOS. XP laptops are screaming, but lone Acer 5220 Vista disconnecting and reconnecting every minute or so. I have turned off Acer Emanager, set rate to Auto and dropped v6 protocol. Still no fixie. I will say when it is connected it is hitting the upperspeed boundary. Will reloading the wireless driver get me anywhere?
There are certain routers that Verizon supplies that have a compatability issue with Acer computers running vista........The tech guy I talked to sat and used my pc as a guniea pig and figured out that if you drop the beacon rate from 100 to about 20 it will stay connected..........after I get more info on the numbers i will be sure to post them here.
Posted on Oct 03, 2008
    Genius:
  • 1,554 Answers
Internal wireless is a hassle and does that on many models.
get an external pc wireless card and the issue will disappear.
you can run with both at the same time.
it fixed my issue for same system.
Posted on Jun 10, 2008
My belkin N150 adapter keeps dropping connection on my pc
For the WIFI connection droping problem ,goto browser and in URL 192.168.2.1 and click on security and keep it disabled .this will solve the connection droping problem..if u r concern with the security add the required MAC address in the mac adress filtering ..
i tried this and its wrking great..
regards,
goutham
Jan 11, 2012 | Belkin Basic Wireless N150 USB Adapter
Internet connection frequently drops netgear wrn2000
Hi
If the Internet connection frequently drops, It could be wired or wireless.
If it is wired connection u can try the following troubleshooting steps
1) connect Modem-Router-Computer
2) Open router UI (www.routerlogin.net)
3) User name : admin , Password: password
4) on the left hand side in the blue panel select WAN setup & reduce the MTU to 1400 & click apply.
if the problem still continues upgrade the firmware of the router.
This should resolve the problem
NOW IF THE WIRELESS CONNECTION DROPS, try the following troubleshooting steps
4) on the left hand side in the blue panel select Wireless settings (under Setup)
5) SSID: (user defined)
Channnel : 11 or 6
mode : upto 54 mbps or 150 mbps
Security : WPA-PSK (TKIP)
PASSPHRASE : (user defined)
Click apply
This should resolve the problem.
Thanks
Vineet Bajaj
Sr. Tech support Engg.
NETGEAR
Jan 11, 2010 | NetGear WNR2000 Wireless Router
Internet connection frequently drops, don't know why. Still connected to router, though not getting internet. Unplugging wireless adapter and plugging it back in fixes the problem...temporarily.
Hi
Channnel : 11 or 6
Click apply
If the problem still persists u can try upgrading the drivers of the wireless USB adapter.
Thanks
Vineet Bajaj
NETGEAR
Oct 31, 2009 | NetGear WNR2000 Wireless Router
Drops out often and disconnects. Use repair
in the device manager, open the properties for the network adapter and on the power management tab, uncheck the box saying "allow windows to turn off this device"
Oct 05, 2009 | 2wire (1000-100016-002) Wireless Adapter
Drops connection after a few hours
ask your internet provider why your internet connection drop, your Router is working properly.
Jul 20, 2009 | D-Link 802.11g Wireless Router WBR-1310...
ACER 5720 WIRELESS CONNECTION PROBLEMS
Are you using security?
If you are try changing between wep, and wpa
If that still does not work use mac filtering
May 27, 2009 | Acer Aspire 5100 Notebook
2wire adapter plugged in pc running vista software, cuts off part
I would suggest increasing the wireless power on your router or change the wireless channel.
Feb 26, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
Sounds like a bad router or antenna. Try replacing the antenna or checking the connection of the antenna on the router. Have your ISP replace the router and the problem should go away.
Jul 30, 2008 | Acer Aspire 3050-1733 Notebook
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER stopped working
What are you trying to connect your USB wireless device to?
Is it to a wireless hot spot?
or to a Wireless Access Point/Router?
When you find a connection, what is the signal strength?
I assume you have configured your Access Point correctly as well as making it secure. You should connect a computer to the Access Point using a network 10BaseT cable to check the Access Point configuration, especially the wireless configuration.
If you are trying to connect to a wireless Access Point and you have a weak signal, move your computer closer to the Access Point or move the Access Point to a better and higher location to give you a better wireless coverage. Note, walls can affect the wireless signals between the Access Point and the wireless network card and wireless USB device, especially reinforced concrete walls.
Jun 01, 2008 | Computers & Internet
Acer Aspire 5100 Notebook Logo
123 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
