Question about RIM BlackBerry 7280 Handheld
WHY WONT MY 7280 CHARGE OR TURN ON
When i plug my blackberry into the charger the red light on the top flashes for on and off about 3 times for 4 seconds and then goes off. When the light stops a little picture in the top right of the screen goes on with a battery and a lightning bolt. Does this mean its charging? If it does why cant i turn it on?
I've tried charging it through a home and car charger and also through the computer
  • Anonymous Jun 17, 2008
    I plug the phone into the charger, and there is a red light on top that stays red, but the phone won't turn on.
  • 26 Answers
The red light indicates its charging.  My guess is that the battery is dead and will nto hold a charge.  This is an older model phone and the lives on the batteries is 1-3 years at most.
Posted on Mar 26, 2009
I took this blackberry bold out of a recycle bin at my school and when i plug it into my dads bb charger the red light comes on but after 10 minutes of charging it still wont turn on.I think its a corrupt...
try this:
JUMP STARTING A BLACKBERRY
1. Plug wall charger into wall and then plug into blackberry
2. Take off back cover and pull the battery out (while it is plugged in still)
3. Wait 30 seconds. The red LED may remain on (tech said it didn't matter).
4. Put the battery back in and wait about 5-10 seconds and it'll begin to boot up (white screen with clock icon).
Jan 28, 2011 | Computers & Internet
My bold wont turn on. when charging, red light goes on and off
did you try the car charger,wall charger might be faulty,if that does'nt pan out,might need new battery
Oct 20, 2009 | RIM BlackBerry Bold Smartphone
BLACKBERRY BOLD HAS NO POWER,WILL NOT TURN ON. THE ONLY SIGN OF POWER IS THE RED INDICATOR LIGHT TOP RIGHT....ON SOLID. CARRRIED OUT REBOOT TAKING OUT SIM AND BATTERY. ANY ADVICE WOULD BE APRECIATED.
I have the same problem with my Blackberry 8120, died this morning, will not switch on, no red light, no charging light, completely dead... my computer does not recognise the blackberry at all so cant install any new software.. plus I need to recover all the information that is on the handheld... please help if you can....
Oct 15, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blabkberry wont charge or turn on.
That usually means dirty power. Make sure you are using a good cable to charge the phone, not all micro-usb chargers work...for example some of the motorola chargers. Make sure there isn't a short in the charger cable. See if the same problem occurs when you attach to the computer USB.
Oct 09, 2009 | RIM BlackBerry 7290
My Casio Exilim EX-S880 wont turn on. Battery is dead but the camera wont charge on the charger. The red charger light is flashing when then camera is placed on it. This red light used to stay on...
I found this while trying to solve my exact same problem.. It worked for me after about 7 times. Some other people on the site said it worked for them after 20 times. Good luck!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Aug 05, 2009 | Casio Exilim EX-S880 Digital Camera
Upon power up, 3 red LEDs flashing rapidly continously, no power.
The control systems on power mobility equipment have a "prevent" circuit that immobilizes the equipment while it is plugged into a charger, so folks won't take off with it plugged into the wall outlet. When you turn it on when plugged into a charger, the display will flash constantly, or sweep constantly, depending on the manufacturer. This is normal. Your off-board charger should have a red light to indicate power to the charger, and another light for the charge status. Yellowish means it is charging, when it turns green, you are fully charged. If the status light is green all the time, that is an indication that the charger is not functioning properly, or that the batteries are below a chargeable state. Check charger output, which should be 26-28 volts dc, and each battery should show at least a 12 volt reading, but around 13.5 volts with a full charge. If one or both of the batteries drops below 12 volts after a short period of time, it's time for a fresh pair. Fully charge new ones before using the chair.
May 31, 2009 | Pride New Jazzy 600 Power Wheelchair by...
Blackberry 8900 wont turn on
the problem could be in charger or battery,
if the problem is in charger,try to charge it wit your laptop
or else try to charge your iphone battery with a battery charger,
if it doest work try a different battery
Apr 16, 2009 | RIM BlackBerry Bold 9000 Smartphone
Hi there, i have a blackberry rim and cant turn it on, when i plug the cord in to charge it up the red light at the top flashes on for a second then the whole thing goes dead again....help plz and thanks...
It sounds like an issue with the battery. Check the battery is not warped and is genuine. Easiest option is replace the battery.
To make sure it is battery related, Try to charge via USB or another AV charger.
Jan 09, 2009 | RIM BlackBerry Pearl 8100
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Nov 22, 2008 | Vivitar DVR 7300x Digital-8 Camcorder
My blackberry pearl 8100 wont turn on
I have an answer for the 3-2 red light blink w/black screen. Remove the battery, hold the end call button and put the battery back in. The red light should stay on for a while now. Push and hold the call button and alternate with the end call button untill the hourglass shows. Allow some time to boot up. I stumbled upon this, so if this doesnt work, try simmilar procedrues. I did get mine to work. Good Luck, dont give up, it flashes that 3-2 code for a reason.
Mar 09, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry 7280 Handheld Logo
237 people viewed this question
Top RIM Computers & Internet Experts
Andrew Wright
Trisha
Trisha
Nataly Roberts
Nataly Roberts
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
