Question about Canon imageRUNNER C3220 Color Copier
When printing to IP address a pop up asks for user id and pass
If I set the printer up to print to the IP address, I get a pop up asking for user id and password. When I share the printer it doesn't ask. How do I turn off asking for user id?
I am having some problems sharing since I upgraded to Vista Home Premium 64-bit. I can't get the x86 drivers in the "additional drivers." and I can't install the driver manually because "the architecture isn't supported."
This is related but it is also a separate question, how can i get this to work? Possibly upgrading Vista Home Premium to Business to use "You can use Print Management to manage printers on computers that are running Microsoft® Windows® 2000, Windows XP, Windows Server® 2003, Windows Vista®, or Windows Server 2008."
The part about eliminating the code is right on, thanks.
When a PC shares a printer you can add additional drivers so the drivers are available to various clients that connect to the printer share. There was something I read about a Microsoft Printer Manager that is included with Vista business that may help me. BUT, I prefer to print to the printer directly so if your suggestions work, I'll be fine.
Posted on Jun 09, 2008
  • 38 Answers
I can definately help with your ID code problem, and maybe with your vista problem.
The ID problem is very simple. Normally when this happens, the copier is set up to use ID codes for copying. When you install the driver, it connects to the machine and collects these type of settings, and configures the driver to the same state as the copier. You have two options to solve this problem. you can either turn off the ID codes in the driver completely, but then your copier must be set to allow print jobs without ID codes, or you can configure the driver with your code, and set it so that it does not ask you again.
both of the options are done by going to the printer driver properties. Click on the "device setting" tab at the top.
If you want to disable the ID codes completely, simply untick the "job accounting" box. click on "Apply" and then on "OK"
If you know your code and you want to configure the driver with your ID code and set it to never ask you for the code again do the following:
Make sure that the "Job accounting" box is ticked. Click on the "settings" button to the right of "job accounting". In the window that appears tick "Allow password setting". Enter your ID code and password (If you have a password), and untick "Confirm ID/password when printing". If you like you can click on the "verify" button. This will check that the ID and password that you've entered is valid or not. This is very handy feature if you are unsure if you've entered the correct info. When you're done with the afore mentioned settings, click on "ok", "Apply" (If active), and then on "OK"
Now for your vista problem. I'm not too sure of the exact problem that you're experiencing, but from what I can make out from your description it sounds like its a driver issue. I would say go to the canon software site and download the x64 driver for your product. The URL for the site is : http://software.canon-europe.com. once you are on the site all you need to do is specify your model, the operating system (In your case Windows Vista) and the language that you want the software to be in. The site will supply you with a list of different software that you can download, make sure that you download the Vista x64 driver. The site will clearly state that the driver is compatible with x64.
Hope all this info is helpful. Have fun, and don't forget to rate me.
Posted on Jun 08, 2008
Where can I see client ip address for printing in the logs.
The log will show the user id but does not show the ip or hostname of the workstation from which the print originated
Mar 19, 2013 | Kyocera FS-C8020MFP Colour Multifunction...
Network can't ping jetdirect 615n card
why not ask at HP and not here, why ask on non HP forum.?
the HP enterpise forum covers this.
ask here first., they will direct you to OLD hardware help.
https://h30434.www3.hp.com/
here im searching there, see all those posts there.
https://h30434.www3.hp.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&q=JetDirect+615N
Jun 08, 2017 | HP JetDirect 615N J6057A Print Server (In...
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
We have a Panasonic PD-3520 setup with a static IP Address and attached to our companies print server. I can ping the IP address of the device, but when I try to print it has a rather long delay and then...
check the subnet mask address and also if it is going through a router this will have to be entered as server id..or gateway address..hope this helps..A
Aug 12, 2010 | Panasonic Workio DP-3520 Copier
I have a Windows printer set up for the Ricoh 12332C. Jobs are sent and clear the queue, but do not print. They appear to be accepted by the Ricoh - they show in the job history log, but they do not print...
Usually the setting of yout network with your copier/printer setting is mismatched so your printer.copier did not understand. What you can do you should check the system setting of your copier/printer and print it out then you should find the driver of your printer/copier in the add printer hardware secrtion in control panel of your computer network . Before you reinstall it , you should uninstall the previous driver so there is no conflict when you reinstall new driver . Try it
Apr 17, 2010 | Ricoh Aficio 1232C Color Copier
Our HL-5250DN won't show up on the network as a printer anymore, but I can reach it's admin page? It's driving me crazy to try to figure this one out. Nothing about the status given on the admin page seems...
Just reinstall the Printer on the Main PC install/Setup all software again, set for shared, Then, go to the clients PC's & set up that printer for NETWORKED Printer, Browse for it... should get you back. Installing a network printer allows multiple users and computer to share a single printer, rather than having numerous personal printers throughout the home or office. When installing a network printer, make sure it is located in a centralized place so that all users can access it conveniently, then install the software on each machine. You may find that newer versions of Windows may already have the necessary drivers installed. Finding the Printer on the NetworkTo install the printer using an IP address, go to Start>Control Panel>Printers and Faxes and then click the Add Printer icon. Next, clickCreate a new port, then select Standard TCP/IP Port from the drop-down menu. You will then be asked to enter an IP address. Enter the IP address of the print server and click Next. You will be asked to select the printer manufacturer and the model from the list. If you do not see your printer listed, insert the disk that came with the printer and click Have Disk.
If you do not know the IP address of the printer, you can sometime select Browse for printer in the beginning of the process. If the networked printer is attached to another computer is being shared, you will need to enter the name of the computer followed by the share name of the printer. For example: \\computername\printername.
Spending extra on a network printer can save you money in the long run. Network printers can be higher grade and print cartridges can last longer than personal ink jet printers.
Feb 16, 2010 | Brother HL 5250DN Laser Printer
How can I connect wireless G print server to a 65bits windows vista without a problem, it just works for WIN XP
Hi, it appears that many are having problems with the WPS54G Print Server. I too have always found it hard to get pc to connect to it. My latest problem was with a Win 7, 64bit pc.
Setting up a printer with a print server is a two part configuration. First you need to configure the print server and then add a printer in your OS.
The following instructions are for a linksys wireless router and the linksys wirless print server model # WPS54G.
To set up the print server correctly go to this link.....http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4142&donelr=1
Following is the instructions from the above link:
Title: Connecting the PrintServer Wirelessly to a Wireless Router Article ID: 4142 Before configuring the wireless settings of the PrintServer, make sure to know the following settings on your linksys router: SSID, and wireless security. To check the wireless settings on the linksys router, click here.
Configuring the Wireless Settings on the PrintServer
The wireless settings of the PrintServer can be configured using its web-based utility. Make sure the PrintServer is set to a static IP on the network.
Record the Print Servers IP address you will need it later.
NOTE: Make sure the PrintServer is already working when hardwired to the linksys router before attempting to use it wirelessly on your network.
Step 1:
Access the PrintServer’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the PrintServer's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the PrintServer setup page appears, click Wireless.
Step 4:
Enter the same SSID you have on the linksys router. Make sure the Network Type is set to Infrastructure then click Save to apply your changes.
Step 5:
Click Security and look under the Security Mode field. Select the type of wireless security your router is currently using then enter the corresponding security keys.
Step 6:
Click Save to apply the settings then close the PrintServer setup page.
Step 7:
Unplug the Ethernet cable connecting the PrintServer to the linksys router. Power it off for 30 seconds then power it on.
Step 8:
Make sure the Wireless LED on the PrintServer is lit and the Ethernet LED is off to indicate that the PrintServer is in wireless mode then try to print wirelessly.
Stop if you can print at this point. If not continue. The following instructions are for Windows 7, 64 bit OS.
Once the above steps are completed open windows file explore. Click Network and you should see a "print server" listed. Click on PRINT SERVER and you will see a network icon labeled p1.
You should now be able to add a printer.
In win 7 open the add printer and click "Add a network, wireless or Bluetooth printer", and click next. A searching for printer window pops up. It will list any network printers or print servers it see's on your network. You should see a listing titled "p1 on Print Server".
At this point you need to click "The printer that I want isn't listed. This is just below the "Select a printer" box.
Next a "Find a printer by nane or TCP/IP address" window opens. Select "Add a printer using a TCP/IP address or hostname. Click next.
Another window pops up which ask for a printer host name or IP address. Enter the IP address of your print server (the one you recorded when setting up your print server), and click next.
The next windows states the device is of unknown type. Under Device Type, make sure Standard is checked. Out to the right is a down arrow, click it and you should see many different devices displayed. Scroll until you find "Hewlet Packard Jet Direct", click on it to select it and click next.
Finally a "Install the printer Driver" window should open. Select your printer and follwing the instructions. If your printer is not listed you can click "Window Update" which will look for new printer divers. Once the printer driver is installed you should be able to print.
As you can see this in not a simple printer install. Good luck!
Nov 23, 2009 | Linksys Wireless-G WPS54G Print Server
Scanning
Follow the instructions below if you run into any configuration problems report back to this site and I will be notified by email.
Scan to E-mail allows a scanned document to be distributed to one or more e-mail addresses. This feature allows e-mails to be sent from the printer directly to an SMTP mail server.
NOTE: This solution assumes Microsoft Internet Explorer is being used as the web browser. Other web browsers may vary. You may need to contact your System Administrator to perform this solution, as it requires knowledge of the network’s email system.
The printer will have to be configured for TCP/IP (IP Address, Subnet Mask, Broadcast Address, Gateway Address). Before you begin, print a System Settings List and make sure the printer has an IP Address and that Internet Services is enabled. See the Related Items below for additional information.
NOTE: An e-mail server must be configured properly and running on the network to perform this solution. The IP Address of the e-mail server is required.
  1. Open an Internet browser window on the workstation.
  2. Enter the IP Address of the printer in the Address field, and then press [Enter] on the keyboard. The Internet Services window will be displayed.
  3. Click on [Properties]. The Properties window will be displayed.
  4. Click on [Machine Details] from the list on the left side of the window.
  5. Enter a valid SMTP Compliant e-mail address in the Administrator E-mail Address field.
    NOTE: When entering the address the SMTP-compliant format must be used, for example, person@company.com. Any replies to e-mail sent from the printer will go to the address specified in the field.
  6. Enter a valid SMTP Compliant e-mail address in the Machine E-mail Address field.
  7. Click on [Apply New Settings].
  8. If prompted for a user ID and password, enter the administrator user ID and password in the fields provided, and then click [OK].
    NOTE: The default user ID and password is admin and are case sensitive.
  9. Click on the [+] next to the Protocol Settings folder. A list of items will be displayed.
  10. Click on the [E-mail] link. A list of settings will be displayed on the right side of the window.
  11. Select the receiving protocol to be used from the Receiving Protocol pull-down menu.
    NOTE: Contact your System Administrator for more information regarding the receiving protocol of your e-mail server.
  12. Enter the IP Address of the POP3 Server in the POP3 Server Address field.
    NOTE: There is no option to set a DNS Host Name for the POP3 Server. Contact your System Administrator if you require additional information.
  13. Enter the username for the POP3 account in the POP User Name field.
  14. Enter the password for the POP3 user name in the POP User Password field.
  15. Enter the password again for the POP3 user name in the Confirm Password field.
  16. Enter the IP Address of the SMTP Server in the SMTP Server Address field.
    NOTE: There is no option to set a DNS Host Name for the SMTP Server. Contact your System Administrator if you require additional information.
  17. Click on [Apply New Settings]. A page will be displayed asking for the printer to be rebooted for the new settings to take effect.
  18. Click on [Reboot]. A 'Do you want to Reboot?' message will be displayed.
  19. Click [OK] to continue with the reboot.
  20. Click on the [X] in the upper, right corner to close the window.
Jun 20, 2008 | Xerox WorkCentre M-24 Color Copier
To set scan
On most printer/scanner equipment there is an user tools or options icon or button. Look in there for system settings,sub-section interface settings.That is where you will find your devices IP address. Be very careful not to change these settings, just look don't touch.
Mar 01, 2008 | Canon imageRUNNER 400S Copier
Printer will not print
1. Printing from one computer directly to the printer requires a crossover cable. The reason they are telling you to use a router is so you can use a standard wired cable. You can print direct to the printer from the ethernet port via a crossover cable.
2. On the settings. First, go into the nework settings and turn OFF the auto dhcp. What it is most likely doing it switching the IP address on you. Set that to manual or static, then enter the appropriate IP address.
Set that IP address in the driver under the port configuration.
So in order, can the router unless you are going to run your network through it also. And use a crossover cable to run directly from the conputer to the printer. Then turn off the AUTO on the IP address settings and make the IP address static.
Then print out a configuration page to confirm the IP settings then set the printer up from there.
The crossover cable for direct computer to printer is te key.
Any other questions ask away.
Feb 20, 2008 | Xerox Phaser 8560DN Laser Printer
Canon imageRUNNER C3220 Color Copier Logo
833 people viewed this question
old marine
old marine
