Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Loud clicking noise
I can't access my lacie hard drive... When I turn the power on it just runs and makes a clicking noise. I can't access any of the files. What can I do?
  • Anonymous Mar 14, 2014
    CANNOT ACCESS FILES
  • 3,940 Answers
You are experiencing the infamous "Click of Death" indication of a failed hard drive.
Most likely, since you cannot access any data on the drive and it has the loud click, the most likely way to recover data from the drive is a data recovery service. www.ontrack.com, www.Drivesavers.com etc.
The bad news it that data recovery is extremely expensive. So, unless this is data you cannot live without, it may not be worth the expense to recover the data. You can contact the data recovery specialists and get an estimate. Last drive quote I saw was a 120 GB drive cost $1200 for recovery.
Posted on Jun 04, 2008
My Lacie 500GB External Hardrive has just started making loud clicking noises. What should I do? I'm feeling quite worried as this is my only backup system. 3011 10KU SN...
It's not a good sign if a hard disk is making loud clicking noise. It means that the hard drive is about to give up. The clicking sound you can hear is caused by the arm of the hard disk knocking against other components in the hard drive. I recommend to back up your data as soon as possible.
Good luck,
Ryan
May 24, 2011 | LaCie Computers & Internet
I have a Lacie 1TB Big Disk Extreme. It has recently developed a loud regular whirring noise, that goes on and off every few seconds. What should I do? Thanks! Adrian
The irregular clicking or chunking sound usually indicates that your hard drive is suffering from physical damage. immediately backup your data, your hard disk will die soon.
This problem can be caused by the following:
  • Head Crash
  • Bad Sectors
  • Mechanical Faults
If your hard disk is under warranty then you contact your manufacturer.
Hard disk drive occasionally produces a whirring sound when it searches for a file which is heavily fragmented. This is caused by the spinning platters as the read-write heads zoom back and forth to access the sectors where the data is stored. It is important to distinguish the whirling sound from the clicking sound. This whirring sound can be reduced by periodically defragmenting your hard drive. Defragmenting reorganizes the scattered data on the hard drive to make files and programs run faster. It relocates the commonly accessed files to the beginning of the hard disk where data can load at a faster rate.
Apr 08, 2011 | LaCie Big Disk External USB 2.0 1TB Hard...
It is making a loud clicking and beeping noise and it won't mount to my macbook.
Loud clicking usually means that the device has failed mechanically. You could try connecting it to another computer, but it's most likely a dead drive. Sorry for the bad news. Steve.
Jan 12, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
I have this Lacie 1TB hard drive and i recently uploaded about 150 GB of video on it at once. I did it over night and the next morning the drive was making some noise like its working on something. Now it...
Drive noises are typically a common and needed noise. Most run via magnetic (voice coil) technology and that is noisy. Slow play back may be related to connection, usually you need stuff on your harddrive (C:\) to avoid access delays.
Oct 03, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My drive turns on fine, but when i connect it to my computer, it starts to make a clicking noise. It's not very loud, but noticeable. I was wondering if it might be a problem with the transformer, the...
Nope, that would be okay, the heads are MAGNETICALLY located across the disk.
The F drive thing is assigned by the OS on boot up, you cannot really alter that without retarding things.
So, this is not a primary drive? if not other stuff gets loaded ahead, a ton for camera card ports, for example.
Sep 20, 2010 | LaCie F.A. Porsche (301177) Hard Drive
Lacie Hard Drive won't turn on properly
A clicking noise is a sign of hard drive failure.
If its a metal clicking noise, could be a physical damage.......hard to get data back from it.......and very very expensive.......sorry
Don't forget to rate this answer if it helps
Dec 24, 2009 | LaCie (301074) 80 GB Hard Drive
My external hd makes a constant, loud noise
Back up your files and buy a replacement drive the grinding noise is the hard drive experiencing mechanical failure and may stop working soon.
Oct 08, 2009 | LaCie Computers & Internet
Lacie HArd drive not accessible
Start > Control Panel > Administrative Tools > Computer Management > Disk Management
Find the drive on the bottom section, right-click it and assign an unused drive letter of your choice. It should then appear in windows explorer.
Jun 30, 2009 | LaCie (300770) 250 GB Hard Drive
My lacie is making clicking noise like clock
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Dec 31, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Hard drive making strange alarm/chiming noise and won't load onto desktop
Listen to your power supply and see if it is making a faint buzzing noise. Try your device with a new power supply. With a new power supply my drive now runs fine, and was not corrupted.
Jan 13, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
397 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
