Question about PSC Duet RS-232 Handheld Barcode Scanner
PSC Duet RS-232 Handheld - help needed :(
I've recently purchased a PSC Duet Scanner, and I'm wanting to run it from a desktop PC running Windows XP This is a brand new piece of equipment. I am needing some advice on how to set it up, It came complete with scanner, a DB-9P(Male) - RJ10 lead, stand and a PSC I.T.E. Power Supply (10V 800mA) I have Tried it via the serial port and via a DB9-USB Adapter(with software), No joy. The Power Supply is a little confusing as the scanner has nowhere for this to be connected. Any help and advice would be greatly appreciated, Regards, Paul Wake
  • gplotto Oct 10, 2008
    I have the same issue
    I suspect we need some software to make it enter scanned codes into the keyboard buffer. eg type th enumbers for us when a scan is performed.
    The hardware beeps like it is working ok.
    David
I had the cable plugged in all the time. It turns out you need a program like Bill Redirect Pro. That did the job.
Posted on Dec 18, 2008
    Problem Solver:
  • 13 Answers
Hello The cable has taken power?
it is important to the power adapter and cable PSC.
fai photos to the cable and sends me. Then explain how to connect to xp.
hello Roberto
Posted on Dec 17, 2008
Cab't get computer/application to recognize the scanner
This is an older model handheld that utilizes either and RS-232 cable or Symbol Synapse cable to link to a PC. If the model you are using is cordless, then there should be a dock that is used to connect to your PC.
Most computer peripherals using RS-232 connections require a driver install to the PC in order to recognize the input from the device. Upon successful connection of the handheld or dock to the PC with driver installed, the unit should work as long as there is no physical malfunction to the unit.
The driver utility support the p470 models can be found here:
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=11585&sliceId=&dialogID=227820981&stateId=1%200%20227814895
This unit is only supported by Windows 2000 or Windows XP environments.
Regards,
Dan
IT Professional
May 04, 2011 | Symbol P470-SR1211100FB Handheld
The duet bar code reader is not been recognized by the computer
reinstall the driver of that device and try to run it again. also check the device connections if it properly installed and the compatibility of your Operating System.
Jun 16, 2009 | PSC Duet RS-232 Handheld Barcode Scanner
Bar code reader cannot be recognized by the computer
i think it is a softwere problem .once a time you reinstal same bar code reader driver, thanks
Windows XP does not recognize the Handheld scanner.
My guess is that the USB hub needs to be plugged in ... if for some reason the usb hub doesn't allow you to plug it in then you need to get one that you can plug in... because I believe the scanner is using more power that the usb port can power. Scanner usually need to be plugged directly into the computer or they need to be plugged into a powered hub.
I hope this helps!!!
cdixon18
The Man Inside the Machine
May 11, 2009 | PSC QS6000 Plus Handheld
NCR 7875 Scanner/Scale Communication problem with PC
You need another cable (the metrologic cable doesnt work with the same configuration) and set the button in the interface card to rs-232 and program the scanner-scale with the programing tags.
Dec 04, 2008 | NCR 7875
Rs 232 connector wiring
the problem is the Rs 232 connector is not all same,.the wire in the cable like my machine is different from usually printer does.
Jul 10, 2008 | PSC Duet RS232 (4310001-1000001021)...
PSC QuickScan GP5385-104342 RS-232 / DOESN'T WORK!
I think the problem you all are having is that this model of scanner requires a "decoder" to work correctly. It is another box which goes in-line between the scanner and the RS-232 port or ps/2 port of the pc. I'm not 100% positive about this, but I am pretty sure this is the problem. You need to look on e-bay for a psc barcode decoder.
Dec 15, 2006 | PSC Quickscan GP5385 Handheld
PSC Duet RS-232 Handheld Barcode Scanner Logo
397 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Electric Dime
Electric Dime
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
