Question about Canon PIXMA MP160 All-In-One InkJet Printer
Fax troubleshooting Hi , my canon mx300 on fax setting is saying " waiting for report" & the in use / memory light is on , i have my fax/phone set to net switch as usual & Im not expecting a fax & have gone into memory & there is nothing there ??? please help
  • Anonymous Jan 22, 2009
    I have the same problem, What should I do?
  • plebc Jan 28, 2009
    same problem, pixma mx700, low on ink message as well (have replaced tanks with non-canon ones)
Hi my canon pm160 when i plag my printer its always on the alarm can you help my to solve it thanks.
im printing documents then the doc. half print and then when i unplag it the alarm is on
Posted on Jun 09, 2008
  • 34 Answers
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
270
Posted on Mar 16, 2009
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
My fax (pixma mx330)says memory in use and shows
Hi, you must reset the machine in the factory setting mode.
Oct 09, 2009 | Canon Office Equipment & Supplies
We are getting a message "waiting on report" when trying to fax
I experienced this problem when "Fax Setting -> TX Setting -> Print Report" is configured before you send out the fax.
After your Fax was sent, and the message "Waiting for report" appear forever and does not leave.
It is because your INK Level is Low and your have set "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report will not be printed out due to ink level is low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed out immediately, the message disappear.
May 29, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon mx700 fax report problems
after emailing canon support, the answer is this: 1) the fax paper size must be "letter" - 8.5-11". 2) reset all settings through settings menu. the fax will then print reports (and also every report that was not printed before).
Mar 05, 2009 | Canon MX700 Office All-In-One InkJet...
Canon MX 300
I cant send Fax. I also receive a message ''waiting for report''and"memory receive mode". Please Help
Sep 17, 2008 | Canon MX300 Office All-In-One Printer
Fax Troubleshooting
I changed the toner and it started working fine.
Jun 15, 2008 | Canon MX300 Office All-In-One Printer
My canon mx310 wont allow me to send a fax, it says 'waiting for report' when i press send.
I have the solution for this problem. You need to go into your fax settings, and adjust the RX Settings. There is an option there to "print if no ink" and you set that to YES, and it will spit out the pending report that is preventing you from sending faxes.
May 25, 2008 | Office Equipment & Supplies
Fax memory
This thread might be dead but I found that you CAN turn off report printing, which also frees up the memory, in the Fax->Menu->Maintenance/settings->Device Settings->Fax Settings->TX Settings->TX Report. Turn reporting off and it clears memory also. Hard to find but its there.
Jun 25, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
173 people viewed this question
old marine
old marine
