When i load the washer and ture it on, sometimes the washer will not hold the water inside. it will drain the water as it is trying to fill. what do you think i need to do? model# WDSR2080DAWW serial# LL106689G
  • Anonymous Sep 11, 2008
    My washer starts filling up and dosen't sense when its full and just keeps filling up and over flows and flow. What might it be? Thank you and God Bless
  • 240 Answers
Drain hose is not high enough. ge's will gravity drain if drain hose height outside washer is below water level. just get some part above tub level before going down into drain.
Posted on Jun 04, 2008
After working well for six months, my washer now expels water at random points during the wash and rinse cycles.
Check inside the fill hose for debris. There is a screen designed to block debris from getting inside the machine valve. If the screen builds up with debris the water slows down. Sounds like the water is filling too slow. Also the unit and/or the load may not be balanced causing it to stop and drain out. If it's okay then see what lights are blinking when these events occur and post here.
Jun 06, 2013 | Haier HLP21E Top Load Washer
It won't hold water just keeps draining even while its filling. I bought a frigidaire stacked washer dryer and i just hooked it up today everything works great except when i turn it on it will work normal...
help is on it's way ... the drain hose needs to be 36 in high. . if it's too low it will drain and fill all day . you can use a drain ext. or longer hose if needed. if this does not correct problem / were still here . mm
Nov 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
417.43142300 Kenmore drains while trying to fill with water
try this the drain hose from the washer is stuck to far down the drain .allow only 8 to 10 inches down drain if the house drain is lower than top of tub it will do the same thing. raise the drain haundi24
Oct 27, 2009 | Kenmore 43142 Front Load Washer
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
My GE Profile top load washer won't hold water
Your drain line is too low or has a blocked air gap. Take the drain line out of the drain. Hold it up high and turn the washer on to fill. If it fills and begins agitation,repair the drain line problem.
Sep 08, 2009 | GE Washing Machines
When tub filling, it drains out at the same time.
The outlet of the drain hose must be higher than the water level inside the tub--normally the pump inside removes the water when needed. Get a plumber to install a proper height drain pipe for you.
Jul 16, 2009 | Haier XQBM22-C Top Load Washer
My washer won't stop filling with water i changed out the water valve and still have the same problem. even when the washer goes in to a drain cycle it still fills with water.... thanks for your help
have you tried looking at the pressure switch? sometimes you can blow through the house that's attached to it and it will clearn things up. give it a try. good luck :)
Jul 15, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Will not fill with water goes right down the drain,works sometimes
Your drain line is too low or there is a air gap blockage.
Remove the drain line from the drain and hold it up high while filling with water and see if it fills and stops.
If so, correct the drain line problem.The drain hose should be 36 inches from the floor.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Maytag legacy series washer not holding water
Same problem here. But according to Maytag Service, the draining pipe may be too deep inside the draining tube on the wall, thus creating a siphon effect and not allowing the tub to fill.
Their suggestion is to ckeck the pipe and make sure no more than 6-8 inches are inside the draining pipe. This should take care of the suction. We'll see, Imma do that when I get home.
Jan 06, 2009 | Maytag Legacy Series Top Load Washer
Can't hold water
There is no drain valve.
Pull the drain hose up out of the drain pipe until there is only about 6" inside the pipe. Make sure there is a gap around the hose where it goes into the pipe so air can get in.
Make sure the drain pipe is higher than the water level in the tub.
Nov 17, 2007 | GE WJSR2070B Top Load Washer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
