Question about AT&T Blackberry Curve 8300 Smartphone
Blackberry Curve & Outlook 2007
I'm having trouble with a brand new Blackberry Curve & Outlook 2007 in that no all of the calendar items in Outlook are syncronising with the Blackberry. No problem with contacts, tasks or memos. I've tried 4.3 & 4.2 SP2 of the Blackberry Desktop Manager. I have also tried to export to .csv then import to the handheld - no go. I have a blackberry 8310 and outlook 2007. I was finally able to sync for the first after a week of frustration. Now when I go back to update, itwill not sync and gives me an "unknown error" message.
  • ravi_michal Jan 28, 2009
    I have the same problem. I have DM 4.7 because the lower ones weren't working and Outlook 2007, I have tried to uninstall and reinstall to no avail. Please help. It won't sync my calendar or contacts.
  • Anonymous Mar 03, 2009
    When trying to sync my bb curve to outlook 2007 for the 1st time I get "unknown error" per prior post I tried to uninstall dm 4.3 to reinstall it and get: error 1316.a network error occured while attempting to read from the file c:windowsinstallerlackberry desktop software.msi. Any suggestions?
To get rid of the unknown error, you will need to uninstall the Blackberry Desktop software. When you do this, make sure that you have the uninstaller delete the user settings, too. Then reinstall Desktop Manager 4.3. See if that helps with the syncing, too. This solution solved the error problem for me, so I hope it will work for you.
If this does not solve the syncing problem, then post back here again and we'll look for another solution. Sometimes a .pst file repair will help.
Posted on Jun 15, 2008
How do I load and coordinate my MS Outlook address book and calendar with my Blackberry Curve 8330?
Here is how you do it:
1Install Blackberry Desktop Manager Softwarewhich included in your Blackberry Installation CD. If you don’t haveone, you may download software from Here
2Make sure you set an Outlook profile that the Desktop Manager can use.3Start the BlackBerry Desktop Manager.4Connect your Blackberry with your computer via USB cable and allow Blackberry device driver install.5Click on Synchronize in BlackBerry Desktop Manager.6Activate the Synchronize organizer data checkbox: BlackBerry Synchronize.7Click on the Configuration tab. Then, click on the Configure synch: BlackBerry Synchronize Configuration.8Check the data you want your BlackBerry being synchronized to. Choose CONTACTS, TASKS, CALENDAR, and NOTES databases.9Afteryou check each item, the software will ask which application you wouldlike to sync it with, you will choose OUTLOOK for all.10Nowgo back to the Desktop Manager. Make sure that the SYCHRONIZE ORGANIZERDATA check box is checked. And select the Synchronize now button at thesynchronize dialog to begin synchronization.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Dec 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry curve
outlook can not load on your blackberry
Oct 13, 2009 | AT&T Blackberry Curve 8300 Smartphone
How to set up sync between blackberry 8310 with outlook 2007 contacts
you have to open your blackberry desktop manager software. goto synchronize, and then configure synchronize and then tell the desktop manager to sync with outlook for you contacts calendar and so forth. so from then on when you plug your bb into your pc and strat up desktop manager, when you choose to sync it will sync your bb with outlook.
Oct 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
Verizon Blackberry Curve 8330 Calendar
you can transfer your information from your palm to your blackberry with a connection cable and your pc or laptop
May 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Caalendar on my desk top for my blackberry curve 8300
the blackberry will be using the Outlook calendar to update its information. its quite easy to use. What's happening is that the items calendared on the BB are syncing with the "private" calendar under the username (Outlook Today - Username - Calendar), and not the "public" calendar (All Public Folders - John Doe). No items are marked as "private" on the BB.
Install the Blackberry Desktop manager software and after its done go to the Syncronize Button. Once inside look to the left for configuration synchronization click this button it need you to be online to do this as well. inside it will list the many programs that can be used to sync your blackberry make sure you have already setup your outlook so that it can pick up the new settings your creating. once your all done look for the top upermost button on left of BDM ( blackberry desktop manager) and click syncronize to sync your blackberry. now once it is done your BB only needs to be plugged in and it will autosync itself. look in your outlook for new entrys and popup
Apr 14, 2009 | AT&T Blackberry Curve 8300 Smartphone
My phone will not sync with my Outlook calendar.
As a past Blackberry user i simply gave up on this. I would suggest using an outlook email account as Microsoft unlike gmail provides Active Sync for all free accounts these days. Give it a try and see if you can get the calendar to to sync. Also, if you are using outlook desktop software 2013 then you get a full feature active sync exchange style email.
Oct 23, 2017 | RIM BlackBerry Curve 8310 Smartphone
How to manage BlackBerry Curve 8330 calendar from home PC desktop
The blackberrys link to outlook and not their own calendar/contact manager. If you have outlook at home, you should be able to use the desktop manager software to sync with that.
Feb 13, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
I've had a few clients with this issue. I have used these steps from RIM. Try it and see if it helps.
Here’s what you need to do:
1. Uninstall Desktop Manager
2. Remove any references on your registry and on your C drive program files and users to:
a. Blackberry
b. Pumatech
c. Research in Motion
d. RIM
e. Desktop Manager
3. Disable the UAC (User Accounts) on Control Panel-Users
4. Get a command prompt and type regsvr32 atl.dll (enter)
5. Reboot
6. Make sure that when you re-install you have absolutely no SpyBot, Virus, Spam guard or the like running.
7. Reinstall Desktop Manager (version 4.2 SP2)
8. If you get an “Error 1904….Lotus Notes…” Ignore it
9. After you do all this, it should work
Jan 10, 2009 | AT&T Blackberry Curve 8300 Smartphone
AT&T Blackberry Curve 8300 Smartphone Logo
1,619 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
