Back to:
Tags:
Telescopes
Generic problem for all Telescopes
Focus knob screw (by 2 users)
posted by Coach22 on Jun 04, 2008
Where can I get the screw part that the focus knob attaches to. It came out of my telescope and disengaged from the knob. I cannot find it.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by spacebeast, posted on Aug 07, 2008
My scope was dropped and the shaft the the focus knob is attached to pushed through the base of the telscope. It is still functional, however when I turn the knob to extend the scope I have to pull the dust cover section of the scope to get it to extend, otherwise the adjustment rod just pushes out from the scope through the back. Can I just rplace the little plastic sleeve or is this a repair that will require replacing the plastic scope case? Any information would be greatly appreciated.
Solution #1
posted on Jun 24, 2008
Not Rated (0)
wycowboy911
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I've had the same problem. Unfortunately, these are knock-off scopes. If the shaft that the focusing knobs attach to is still there, you can replace the knobs themselves by ordering THIS part. If the shaft AND the knobs are both missing, you'll have to replace the entire focusing mechanism (sorry, but I don't know where to order the housing from). Hope it's more helpful than the prior answer.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Focus knob screw:
I don't want to Accept this solution
Solution #2
posted on Jun 06, 2008
Not Rated (0)
PaulMo
Rank:Wiz Wiz
Rating: 79%, 150 votes
Not enough information to answer question.
Thank You!
Can you Help with these Telescopes problems?
Telescopes
I was given a BSA Optics telescope with no manual and I...
Meade 114EQDH4 (36 x 114mm) Telescope
i have the 497 controller and want to know what i need to...
Meade 8" LX90 LNT Schmidt Cassegrain...
I took my old motor drive apart to tighten some screws an...
Bausch and Lomb Professional 200 (200 x...
I have this telescope...With no idea howto use the lenses?...
Telescopes
Home accident: My Konus MotorMax-90 Telescope tipped over...
Loading problems.
Repair Service
Find Telescope Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
