Question about Philips 55P8341 55" Rear Projection Television
Philips 55P8341 red pic
I may have the same problem with mine, I can still see the picture, but it is all red. Could I just need to chage the CRT fluid in the blue and green? I change the fluid on a similar tv and doing so took care of the white halo's. When I go into the red convergance, I can see the cross, but when I go into the blue all I can see is a light blue blob..... Makes me thing the the fluid is contaminated. Also don't have any sound, but I don't think that those two problems are related.
  • Philips Master
  • 8,617 Answers
Yes change the coolant, if that doesnt correct the problem you will need a blue CRT
Posted on Jun 13, 2008
Need the default coloring for the Philips 55P8341 tv
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 16, 2010 | Philips 55P8341 55" Rear Projection...
I have a philips 55p8341 projection screen that is blurry and has to much blue in the picture
Replace the coolant in the CRts. You can get the Phillips CRT coolant kit at the following link it contains the coolant plus instructions on CD.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Aug 13, 2009 | Televison & Video
55P8341
sounds like the red CRT may be shorted.You can get a repalcement Red CRT at the following link for a very reasonable price. If your not sure which one your model uses. leave them a email with your model number of your set.
Aug 12, 2008 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50 in. Rear... Problem:
You CRT coolant needs to be replaced, its a very common problem with the phillips and magnavox projection TVs. If you need more info on the Coolant Change let me know.
Jul 14, 2008 | Philips 55P8341 55" Rear Projection...
Pillips projection tv
I HAVE A PHILIPS M#55P8341A THERE IS DOUBLE PICTURE ON THE SCREEN IF YOU HAVE ONE PERSON THERE YOU SEE TWO OF THEM ONE IS RED THE OTHER IS GREEN?
Jul 09, 2008 | Philips 55P8341 55" Rear Projection...
Phillips 52" big screen is looking blurry. Can I tune it myself?
my projection tv color is red I have tried ajusting the color but nothing the pic is still to red
Jul 07, 2008 | Philips 55P8341 55" Rear Projection...
Blinking lights on philips 55P8341
5 volt protection is causing the set to go into protective shutdown. Check for shorted diode 6306. Part#934038020127
or shorted capacitor 2318. or faulty voltage regulator
May 18, 2008 | Philips 55P8341 55" Rear Projection...
Cannot adjust colors
sounds like your red tube is getting a short I can post you a web sight and they have used red picture tubes
Apr 22, 2008 | Philips 55P8341 55" Rear Projection...
Poor color
You may need fluid change. CRT gets dirty fluid, must be changed after long time of use.
Nov 26, 2007 | Philips 55P8341 55" Rear Projection...
Philips 55P8341 55" Rear Projection Television Logo
132 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
