Question about Averatec 3200 Notebook
Wont start? it has been shutting down alot, and finally it just wont start at all?
  • 458 Answers
Could be alot of things... Need more info about the symptoms ya were getting before it stopped ..
It coul be that the CPU was getting overheated and causing it to shut down until finally it blew the chip
Or.. could be the Motherboard Blew....Or.... could be a Bad memory stick... try pulling one at a time and rebooting ..Or,...You could have a bad DC jack that at first was just "loose" and now has broke or disconnected from the +positive post connection /
Posted on Jun 04, 2008
2 Suggested Answers
  • 30 Answers
SOURCE: shut down with disk in tray.,now wont start
If u have such a problem like u have to cancel it then u have to follow this procedure:
open task manager
In Applications select ur process to cancel
Right click the process
select Go to process
Select end process
Press yes
u will find the cancellation of ur process
Posted on Aug 03, 2009
I restarted my new macbookpro. now it wont let me open Final Draft. When I try to open in, the Mac Automator comes up and seems to shut down Final Draft. Please advise.
Thanks for visiting FixYa!
First, uninstall Final Draft 7 from your Mac. Then re-start your notebook. After it boots up - run a registry cleaner if you have one to remove all bad registry values that may have been let behind by the program. If you don't have a registry cleaner, try to get one. After running the registry cleaner, re-boot your Mac. Then, re-install Final Draft 7.
Two things might have happened. (1) the program became unstable and shut down or (2) you have a problem with certain sectors in your hard drive and lost part of the program.
In either event, re-installing it may cure the problem.
Apr 21, 2011 | Final Draft 7
Computer wont start and when it does it shuts itself down
Sound like a power overload system is kicking in, which means either a bad power supply or shorted circuit else where. Disconnect the DVD, CD, and any other devices to narrow it down. Try another known good power supply. If all this fails, it's going to be a problem with the motherboard, by elimination. There can be an intermittent capacitor or electronic heat sensitive part that's shutting down the computer. There are diagrams and videos on the net that can guide you through possible problems, in case you want to fix it yourself. Google "Intermittent Computer Startup" and you will find some good suggestions. One site is this one:
http://www.ehow.com/how_5880187_troubleshoot-intermittent-shut-down-computer.html
Good luck.
Apr 15, 2010 | Computers & Internet
My santa fe has problems starting back up after
if you pumped more gas after the handle shut off then you caused an issue by over filling. this happens to alot of cars when you try to get every once in the tank.
Mar 24, 2010 | Hyundai Santa Fe Cars & Trucks
Shut down with disk in tray.,now wont start
open task manager
Select end process
Press yes
Aug 03, 2009 | Dell Inspiron 1525 Notebook
Installed the convext high def finally got shound but now the volumn wont mute or turn down
shut down the system and start it again
donot restart
shut down
then start got it if the problem persists then try reinstalling the device drivers
Jul 08, 2009 | Compaq Presario 700 470024-192 Notebook
Car wont start
alot of cars have a auto shut down when they loose oil pressure, if the oil level is good, check oil sending unit ,if it is bad replace it and should solve the problem,thnaks hope i helped,robert b.
Jun 26, 2009 | 1998 Chevrolet Malibu
Wont start
Take it to a shop for diagnostics. It could be alot of things, but is probably a faulty fuel pump.
Fuel pumps usually fail once the car gets to operating temperature and then they sieze up if they are faulty.
Although it could be alot of other things, faulty computer, to a clogged fuel filter.
Aug 09, 2008 | 1996 Oldsmobile Cutlass Ciera
Volvo 245 engine shuts down when warm.
done the same in my volvo it was disrubitor but make certain that replacement one the same part number.
Jun 26, 2008 | 1982 Volvo 240 Series
My tv stalls on turn on
So the set finally produces a picture? symptoms like you describe tend to point to a intermtant failure of a component or more like impending failure of a component. Does the set shut down when you finally get it to show a picture? This set has a processor that stores errors in it. The first option is to read those errors. This set will shut down for many safety reasons.
Jan 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Averatec 3200 Notebook Logo
32 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
