Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer FH code "sometimes"
This washer is nuts. ALL THE CHECKS ON THE LIST HAVE BEEN PREFORMED SO DON'T POST THE LIST AS A SOLUTION BECAUSE IT'S NOT!!! Washer may do 20 or 30 loads with no problem then BOOM here comes the "fh" again. Reset, and then fine for several loads or many loads . All components, connections, hoses and tubes on the list have been checked, cleaned, dianostics have been run and everything passes. Please give me a solution that is helpfull. Whirlpool duet washer started with a "suds" code, reset washer then "fh" code showed. ran diagnostic stopped at "c01" then showed "hf" code. Drain pump was not coming on but I was able to make it come on by pushing on the switch on the side of the pump. Could my problem be the pump or a switch or sensor somewhere?
    Genius:
  • 3,587 Answers
Well..based on what you're stating here..sounds more like a sensor, based on the duty cycle.
Posted on Jun 04, 2008
  • Patrick Michaels
    Patrick Michaels Jun 04, 2008
    ok..with the extended operational mode, it's clear you have a thermal issue with the pump..the sensor MAY only be sending a correct signal to the board, and making it stop, until the pump has cooled down.
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
My Whirlpool Duet washer is making a loud squealing noise when filling with cold water, or it reduces the cold water to a trickle, which sometimes causes the washer to throw an FH code. It does not h
Hi. Got some info about the FH error from Whirlool service manual.
F/H
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
In my experience the CCU is the problem (control board).
IF the machine has water! If not, check water valve, hose, water tap.
Do it overfill? If thats the case, the pressure switch is gone, its hose has a leak.
Hope this helps you
Sep 27, 2014 | Whirlpool GHW9400 Duet Washer
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
http://www1.fixya.com/support/r10423905-fh_code_means_duet_epic_front_load
GENE
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
FH Error code Whirlpool Front load washer. I
the only thing you can do is to go to the manufactures website and download the user manual and check the trouble shooting guide for a possible cause for this problem eric
Jan 17, 2018 | Whirlpool Duet GHW9150P Front Load Washer
Light is blinking FH
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FH?
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
have you cleaned out the small screens in the water solenoids in the back of the unit where the fill hoses connect?? Also this can happen in certian times when water pressure is low going into the unit or home
May 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
352 people viewed this question
Dan Webster
Dan Webster
Sal De
