Question about Janome Memory Craft 9000 Computerized Sewing Machine
Janome issues Did you ever resolve the issue below? I am having the same problem. How did you fix it? Email me @ BrandyShirley@hotmail.com Hi my Janome machine brand new has just started looping the top thread in the machine. Called shop they say must bring it in but not happy as it was working fine just the other day.
  • Janome Master
  • 1,388 Answers
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
janome issues - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Jun 08, 2008
My Janome hd1000 is not picking up the bobbin thread. Can you help
Be sure to use a brand new needle. If that does not resolve the issue, your machine probably has a needle/hook timing issue. There are many web sites & videos on sewing machine timing. Or take it for service.
sewing machine timing Google Search
Jul 27, 2016 | Janome Hd1000 Sewing Machine
When I turn my Janome mc 9000 the screen says raise presser foot and needle bar and switch it off and back on. I did this several times and it still says same thing.
Almost defiantly a sensor issue. These are not easy machines to work on due to their hi-tech design. Clean and inspect as much of the mechanism as you can as some cotton or fluff may be obstructing a sensor or switch. This may stop the machine from calibrating.
Below is a link to a PDF of janome error diagnosis. It is a bit complicated but one of these steps may solve your issue or offer a solution.
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwj1mtPo-fLNAhXqDMAKHfgCBYAQFgglMAA&url=http%3A%2F%2Fwww.janomeservicevideos.com%2Fwordpress%2Fwp-content%2Fuploads%2F2015%2F02%2FError-Codes.pdf&usg=AFQjCNHyJmEhmZ9Avh-lSL4Y0vVHEYM1yg&cad=rja
Jul 14, 2016 | Janome Memory Craft 9000 Computerized...
Can I fix a broken bobbin winder on my Janome sewing machine by myself?
If your bobbin winder is malfunctioning and you are unable to resolve the issue, for ~$25 you can purchase a stand-alone bobbin winder at the local fabric store (JoAnns or Hancocks) or even online (Amazon).
Oct 30, 2015 | Janome Sewing Machines
My memorycraft 9000 computerscreen went blank..it's a bluish colour..the machine still embroiders and sews..but i can not remember all the positions...is it a new screen i need..a phone quote was $400 -...
It sounds like the screen is still getting power there are a few things that might cause display problems. Referencing the troubleshooting section from the manual the only display issue listed is "Visual touchscreen is not clear" The fix is to adjust the display by turning the Visual Touchscreen Sharpness Adjustment Knob. You can find the location on page 2 of the manual, located online at:
http://janome.com/documents/File/ManualFile/inst%20book%20MC9000.pdf
If this does not resolve or help the issue there could be a lose connection inside the machine or the screen may have failed. If you do not feel comfortable tinkering inside your machine you may want to take it somewhere to have them work on it.
Apr 12, 2010 | Janome Memory Craft 9000 Computerized...
Janome 8000 LCD question
Hi Lezlie,
I shall send you the installation instruction to gain access and replace the screen via email.
Cheers
Martyn
Dec 22, 2009 | Janome Memory Craft 9000 Computerized...
Manual needed for a Janome FW 131 Foreign Winfield.
Hi, Could you email me the 20x14 guide too for the janome fw131 pretty please? I would really appreciate it! My email is acchanim@gmail.com. Ta.
Jun 24, 2009 | Janome 6019QC Mechanical Sewing Machine
JANOME MEMORY CRAFT 5700 INSTRUCTION BOOK
Hi, I downloaded (for free) a copy of the Envision 8006 (and 8007 supplement) manual from the Elna website 2 1/2 years ago. The Envision 8007 is the same as the Janome Memory Craft 5700. I can email you a copy of the manual.
Mar 13, 2009 | Janome Memory Craft 5700
Clunking noise only in embroidery mode 11000
Unfortunately this isnt a solution just a suggestion, write a clear list of problems experienced, Also list all the attempts at repairs, embed scanned copies of reciepts for the repairs, give the name and location of the dealer/s used, Scan examples of work showing stitching problems and include them, don't use inflammatory language as that will weaken your case, just state matter of factly all the problems encountered, all the steps taken to try and resolve the issues.Write clearly what you would like done to resolve your machine problem, i,e, a proper diagnostic report and repairs or replacement of the machine.Save a copy to your computer, Print 4 hard copies, send one to the dealer explaining the steps you are taking to resolve your issue with the machine. Send one to the Janome headquarters in your country, addresses can be found on the web or at Janome Global, Send one to Janome Japan customer services, put the fourth on file. Give them 10 days to acknowledge reciept, then start making polite enquiries regarding your mail of , and insert the date sent.
If you are in America investigate if your state has the Lemon Laws, also investigate consumer protection rules. If you are in England use the consumer protection rules and advisory body. If you are in the EU there is legislation that covers goods that fail to meet the advertised perormance levels of the item.
I know this isnt a solution, but as long as you show you have taken steps to remedy the issue, you have case for obtaining a replacement that works.
Jan 03, 2009 | Janome Memory Craft 10000
Janome Memory Craft 9000 Computerized Sewing Machine Logo
128 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
