Question about Tilia FoodSaver V2240
Foodsaver pro locked up. 3 green lites blink off and on. is the problem fixable?
  • eskelin Oct 24, 2010
    Please explain to me where the reset button or hole is found on our Foodsaver professional II vaccum sealer.
    It also has a nick or blank spot in the center of the sealer heat strip. Can that be repaired or replaced?
The reset button is the small black rubber covered hole on the left side of the vacuum channel. If you press down on that with something like a knitting needle with the unit on, it should reset
Posted on Dec 08, 2010
    New Friend:
Mine did it too...got fluid in vacuum pump take top left plate off four screws on bottom.... Take circuit board off.. Three screws and four plug connections. Remove clear hose from bottom of round white cylinder. Flip board over. Remove torx style plug from bottom of round white cylinder(might have to remove glue on wire posts). GENTLY PRY WHITE F shaped tube off cylinder. Suction all water out of cylinder and cleAr vacuum linesand f shaped piece. Actuate pump by spinning black wheel to help clear lines. Let dry several days (I put mine in dehydrator ) reassemble. Good luck.
Posted on Oct 08, 2013
    New Friend:
  • 3 Answers
Replace the sealing wire and Teflon tape, easy thing to do.
Posted on Feb 05, 2013
    Genius:
  • 1,478 Answers
The problem is fixable, have you try to reset it it? if no, try to reset the unit, that should help.
Posted on Oct 17, 2010
  • 1 more comment
  • bgbradley Nov 06, 2012
    This did not fix the problem!!! Any more suggestions?
  • Anonymous Feb 18, 2019
    If the sealer happens to be closed, then it isn't possible to access the left side of the vacuum channel. Because the machine is closed! Three blinking lights means there has been some kind of internal error (not water in the pump). Is there no way to access the reset button from outside the device? From its extermal housing? If the lid was locked shut?
  • Kirby Feb 18, 2019
    (Because I can't believe there ain't no way to do it this way.)
SOURCE:
Foodsaver Professional II locked up. 3 green lights blink on and off. Is the problem fixable?
I completely diassembeled my unit and could find nothing wrong. I reassembled it and had the same problem.
In my opnion the controlled board has failed; time to guy a new Foodsaver.
The small black rubber covered hole on the left side of the vacuum channel is not the reset button, it is the "lid closed" button.
The seal is not the issue as the lights start blinking right after you turn the unit on.
Jun 23, 2012 | Kitchen Appliances - Others
Out of the box green light comes on and blinks for 10 to 15 seconds, blue screen on television appears for a few seconds then goes black and red light blinks and nothing happens
Only get Welcome screen and green blinking lite. Then shuts off. Buttons locked out also. Need to get software update V41C-11.3 Mitsubishi-tv.com. Go to support then software update. It will ask for model, ser. First and Last name and E-mail. download. http://www.avsforum.com/avs-vb/showthread.php?p=19844230
Has a link about 1/3 way down that will go right to the download. Very helpful.
May 28, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
The button on wall which has a little green lite in the center, keeps blinking, but the garage door does open
Press and hold the lock button for 3 seconds to stop the light from blinking. That blinking is the indication that the lock function is on and your remotes will not work.
May 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can't open my foodsaver for cleaning
I had the same problem and got this information from Foodsaver:
Turn Foodsaver unbit on and press the cabncel button. That should release the unit for cleaning.
It worked for me!
Feb 02, 2010 | Tilia Foodsaver V835 Vacuum Sealer
My sons nintendo ds wont turn on, when we charge it, turn power on , the green light comes on and bottom screen blinks for a split second then goes dead.. Is this fixable , if so what do i try??? thanks
yes it is fixable sounds like your fault is with the top screen are the hinges ok has it been dropped.
most green light and screen flashes point to a defective screen or connection on the mother board or sometimes fuses. id start with checking the motherboard connection if its ok check the fuses if all is ok buy a new top screen and replace it.
Jun 30, 2009 | Nintendo DS Lite Console
My nintendo lite wont turn on-the green lite is on but thats all-
Which LCD is blinking?
If your top screen is blinking before cutting off, your DS lite has a problem with the bottom screen.
If the bottom screen blinks before cutting off, your DS lite has a problem with the top screen.
Can you confirm?
May 30, 2009 | Nintendo DS Lite Console
Sear garage door wall mount contol light keeps blinking
One of the buttons has a lock icon. Hold that button in for 3 seconds.
May 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sony LCD projection TV - bulb problem
Hi! sweet123,
Please answer this question. Were the 4 bulbs visabley bad; say broken or did they have a milkey look, or broken wire inside? In other words did the bulbs you replaced look as good as a new unused bulb? Please reply.
toprol
Nov 15, 2007 | Televison & Video
Tilia FoodSaver V2240 Logo
3,867 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
elementsandt
Level 1 Expert
Sheldon Dedek
Vitally Alcher
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
