Question about Janome Memory Craft 5700
Janome personalizer 2000
Is there a patch to make personalizer run properly with windows xp? it will not save the bitmap when i use fill stitches, but does if i only digitise the outline. creates a bmp file but it is empty!!! on two tests it had only three pixels of the outline i had drawn!! please help!!! beth
3 Suggested Answers
dupina
  • 110 Answers
SOURCE: bmp files
Your CE 200 allows you to do very basic digitizing by using Autopunch. The color difinitions on your bmp. file should be clear, or your results will be poor.
To activate autopunch, click on "create" from the top menu and select "autopunch" from the drop down menu. A new Autopunch wizard menu should open. Click on "next" on the browse to your bmp. file by clicking on "select". Keep on clicking on "next" until you get to the "customize stitch block" menu. Here you are able to remove unwanted blocks or change the stitching order by clicking on a block in the right hand menu and the clicking on the "Remove", "move up" or "move down" buttons.
By clicking on the radio buttons, just below the "move down" button, you can also select between Fill stitch or Satin stitch. When you are happy with your decisions, click on next and click on finish.
That is about all that you can do and autopunch will do the rest. I suggest you import a couple of dfferent clipart images and play around as discribed above to make you familiar with the program. You will also see different results by changing options.
If you are not happy with final results, I suggest you invest in a proper digitizing program, such as Creative Drawings. Visit the at www.drawstitch.com/Creative
Good Luck
Posted on Dec 12, 2008
  • 6 Answers
SOURCE: Feed Dogs on Janome 1600P
I recently purchased a Janome 1600P-DB and in order to do free motion quilting I had to cover the feed dogs with an index card. I also cut a small section out of the card to allow for the thread and needle to move freely. Standard tape was used.
Posted on Oct 21, 2009
Tight handwheel on Janome Vogue Stitch
have you reset the free motion screw in the hand wheel?
Mar 17, 2014 | Janome Sewing Machines
Stitch regulator not working properly
it would be a good idea to have the machine checked, the stitch
length regulator need to be checked to see if it's worn or a gear
that move the part is worn and may need to be replaced.
Oct 23, 2012 | Janome Sewing Machines
Looking for an internet site that offers a patch for Kenmore (Janome)R/W 19000 embroidery software for Windows XP. The orig software is only compatible with Windows 95 and MS Word. Thanks so much.
I was informed there was no patch. The software was formated for windows 95 and will only work with that software. you can pick up a computer for less than 100 with that old windows system-- that is what I did.
May 08, 2010 | Kenmore 19001
I have a windows XP computer and I am trying to get to read r/w
Being as you have xp looks like you will have to go to viking site and download a patch to make it compatable, I have a Janome and when we upgraded the computer I had to go to the janome site and download upgrade, the same would apply to the customizing software I would think.
Nov 24, 2009 | Husqvarna Viking 1
I can't get the correct driver for Janome MC 10001 for Vista 64bi
See if you can run the program in compatibility mode, with win 2000 or xp.
Sep 01, 2009 | Janome Memory Craft 10000
What platform (WIndows XP, etc.) can the 9000 digitizer use?
Digitizer 2000? Or Digitizer 10000?
There's a BIG difference.
So far, it doesn't seem that Janome's put out an update to Digitizer 2000 for Vista (though they have for Customizer 2000), but they have for Digitizer 10000.
However, XP should be fine with Digitizer. You may have to go into your "Properties" menu for Digitizer and set the compatibility back to say, "Windows 95" though.
To do this, right-click on the software icon for Digitizer on your desktop. On the contextual menu will appear several choices - select "Properties" and then click on the "Compatibility" tab on the Properties dialog box. This is where you change how your computer (essentially) recognizes the application.
You may need to experiment with the options. Try "Windows 95" first ... and if that doesn't work, select and try another.
Apr 17, 2009 | Janome Memory Craft 9000 Computerized...
I have a Janome JD 1818. I lost the manual. How
Manualfox.com is a personal Document Search Service for electronic user and service manuals. They help you to save time and money by finding your needed product information.
Feb 22, 2009 | Janome 2049LX Mechanical Sewing Machine
Customizer 11000 does not convert image files to stitch files
I'm assuming you are refering to the auto tracing function of the program. Customiser 11000 is a very limited layout and editing program, it's digitising function is extremely limited.
What is never explained satisfactorily to the purchaser, is the requirement for exceptionally clean artwork. Scanned photographs, colouring book images etc are not clean artwork. You need vector clip art, optomised clip art you find on the web is too "dirty" and needs a great deal of "cleaning" in a graphics program. Use the WMF import function and source a decent supply of WMF clip art. Most commercial clip art collections offer WMF as an option as do the clip art for digitisers sites.
Another reason for your program freezing could be an underpowered video display card, if your computer has a shared graphics card you're underpowered. Also your Ram, Customiser 11000 is a CAD based program which uses a lot of ram playground and a lot of your display cards muscle, whatever the programs specs are, triple them.
Check which version of the program you have, then visit Janome global, select downloads, software , and see if you have the latest version, if not, download the newest version.
Jan 18, 2009 | Janome Memory Craft 10000
Stitch problems
You can adjust the pressure foot(not footpedal)which puts the prsure on the foot by the needle. Also try altering the stitch length. If the stitches are skipping on silky fabric or knitted fabrics try using tissue and sewing onto that directly then tearing it off afterwards.
Nov 12, 2008 | Janome Sew Precise Mechanical Sewing...
MC 10000 Digitizer 10000 Error Message
Try downloading the updates for your software from Janome Global, downloads, software. Version 1 needs patches to make it compatible with XP. The most current Version for the 10000 software is 2.21, and the upgraded program is Digitiser pro/MB , a much more stable and far easier version to work with. The upgrade has to be purchased via a dealer or direct from Janome.
Apr 16, 2008 | Janome Memory Craft 10000
Sewing Machines Logo
209 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
