Question about Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
Canon PIXMA iP4000 Will not print red. Deep clean won t work. Other colors OK. Red ink cartridge is almost full.
  • 5 more comments
  • gadman002 Nov 10, 2008
    I do have the same problem I have replaced the cartridge and gone through about 10 deep cleanings. All I have accomplished is to use up most of the other cartridges. I still can't print reds. Ohter colors look ok at this time.
  • klmickelsen Nov 10, 2008
    My red won't print either and the ink tank is full. I have run all of the cleaning operations and it's not working still.
  • salsas53 Nov 16, 2008
    the same
  • TARSHITO Apr 25, 2013
    yeh i have the same problem with ip4500,4800 and now with 4950
  • Anonymous Mar 14, 2014
    Any documents on the computer that you want to print will not print. The print head nozzles go across the paper but no ink is sprayed onto the paper. I tried the copier feature. It did not work in black ink but did in color ink. I just deep cleaned the nozzles. The printer is about 4 years old but works well.
  • Anonymous Mar 19, 2014
    My Canon Pixma Mp560 printer will not print pink or red colors.
  • Anonymous Mar 30, 2014
    won't print, scan or connect
Remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
Cleaning/replacement of Nozzles of Pixma iP4000 Canon Printer
My Canon Primax ip4000 has stopped printing blue. I've tried deep cleaning and when I print a test page the blue 6c does not appear. Any ideas what the problem could be?
Nov 01, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Ip4000 printer prints but with horizontal lines
Cannon recommend a cleaning process called deep head cleaning
  1. Open the Printers folder.
    - For Windows XP select 'Start', 'Control Panel', 'Printers and Other Hardware', and 'Printers and Faxes'.
    - For Windows versions other than Windows XP select 'Start', 'Settings', and 'Printers'.
  2. Right-click the printer icon and select 'Properties'.
  3. Click the Maintenance tab, and then click the 'Deep Cleaning' icon.
  4. Select the ink tank color(s) for deep cleaning ('All Colors', 'Black', or 'Color').
  5. Confirm the message, and then click the 'Execute' button.
  6. The Power lamp will blink and print head deep cleaning will start. Deep cleaning completes when the Power lamp stops blinking and lights. (It will take about a minute for the Power lamp to stop blinking and light solid.)
  7. Print a Nozzle Check Pattern by holding down the <Resume> on the printer until the Power light flashes twice to determine if further cleaning is necessary. Up to three deep cleanings may be necessary to determine if the print head is working properly
Sep 11, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Red does not print, neither does yellow . have deep cleaned 3 times without changing anything Canon Pixma ip4000
plugged nozzles use a syringe and water to unplug and put paper towel under to catch residue and use canned compressed air to blow out and clean unit!! :)
Jul 07, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Feb 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Canon Pixma iP4000 prints all color prints with a cyan cast.
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Printer problem
Hi , did you check nozzle what color appear , some ink cartidge are old stock and dry , pullout cartridge clean the contact nozzle .
Feb 01, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Magenta won't print?
Take the Caridge out and stand on damp tissue overnight -then see what happens come back and tell us
Apr 13, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
3,402 people viewed this question
old marine
old marine
