Question about Toshiba TN55X81 55" Rear Projection Television
Blue convergence Toshiba TN55X81, what is the part number for this convergence IC (both blue and red)? Thanks a lot!
  • Toshiba Master
  • 8,617 Answers
They should be STK392-110 ICs you can get replacement ICs at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Posted on Jun 04, 2008
SCREEN IS RED/BLUE AND LOOKS 3D
If the picture looks like these
It is a convergence circuitry failure. You can fix it yourself if you have some basic skills on soldering and desoldering parts on the board. If yes, click here and I will assist you further.
Jdvillanueva
Oct 11, 2011 | Toshiba TN55X81 55" Rear Projection...
Convergence is out of whack.
Not a problem, I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which expains how to repair your unit and where to get the parts. If you need more help let me know.
Thanks for using FixYa and for the great rating.
hardrocko
Apr 15, 2010 | Toshiba 51H84 51" Rear Projection...
Red & Blue lines on screen
stk392-110 i think mine was made in 2002 and i also had to replace mine
Oct 26, 2008 | Toshiba 50H72 50" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba Tn55x81 frequent convergence problems especially blue/ red double vision. Plus picture get very blurry at times.
If this only occurs occassionally, it suggests that there are bad connections at the convergence ICs rather than defective ICs. If you can solder, try resoldering the pins on the ICs. That may resolve the problem. These ICs are large, black and attached to a heatsink. They will be marked STKxxx.
Keep us posted.
Dan
Aug 19, 2008 | Televison & Video
Toshiba TN55X81
Blue Convergence IC is bad = change both for reliable repair..
located on largest heatsink on chassis.............T.
Feb 02, 2008 | Toshiba TN55X81 55" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Blue Convergence
Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
http://electronix.com/
Jan 14, 2008 | Toshiba TN55X81 55" Rear Projection...
TN55X81 Rear Projection color separation - convergence problem
You shouldn't need to do a board replacement, all you should need to do is manually tune the convergence.
You can do this with the built-in user tool, but there's also a far more powerful set of options in the service mode. To save you the trouble (I advise doing a LOT of reading before attempting any of this) here's a solid set of various tutorials based on what form of "separation" you have occurring:
http://www.keohi.com/keohiHDTV/brandspecific/toshiba/servicemenu/servicemenu.html
Nov 21, 2007 | Toshiba 55H70 55" Rear Projection...
Convergence problem
Blue convergence IC is bad! Blue CRT OK!
Required for repair---pull chassis,replace STK392-110 X 2.
Re-assemble,adjust convergence as needed.
Oct 12, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba TN55X81 55" Rear Projection Television Logo
136 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
